Old 02-27-2008, 04:03 PM   #6286
Suspended
Trader Rating: 440 (99%+)
Hey guys what brakes are most of you using? I am on my 5th Losi 8ight and it seems like every one I have problems with the stock brakes. I don't know if my pad to caliper clearance isn't right or what. But I always try to set it to where at idle there is NO drag at all on the brakes. But even like that my pads seem to be dragging and even when I apply the brakes they don't stop the buggy like they should. Seems like no braking power even with a high torque servo. I even tried the trinity spring things and it didn't seem to change anything. Actually it seemed to make it worse. I have a new set of Advantage Drilled brake discs here but when I went to put them on they fit REAL loose over the diff outdrives. They had tons of slop so I put the stockers back on for now.
Just looking for opinions that may help me......
MattP is offline   Reply With Quote
Old 02-27-2008, 04:17 PM   #6287
losimark's Avatar
I use the ofna ( ofn 40044)brake springs and leave very little gap between the calipers.
If you have to much gap they will bind when you accelerate and decelerate or when you tilt the car back or forward.
www.fthobbies.com
losimark is offline   Reply With Quote
Old 02-27-2008, 04:37 PM   #6288
Suspended
I think what you said is what's happening to me. I'm paranoid about having the brakes too tight so I always back off the calipers. I just took the center diff out of the buggy and took a look. It looks like I had too much of a gap between the discs and calipers.......
Old 02-27-2008, 04:54 PM   #6289
cornerspeed's Avatar
Make sure there is .5mm clearance between pads and rotors. The newer HD brake disc from Losi work well also. I just ran them at the Nitro Challenge and worked awesome.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-27-2008, 06:10 PM   #6290
losimark's Avatar
so you put them to the test with all that mud.
www.fthobbies.com
Old 02-27-2008, 06:31 PM   #6291
AZRCaddict's Avatar
It was only muddy on intermediate buggy qualifying and the first few truck mains. I had the upgraded discs on my truggy and they worked really good.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 02-27-2008, 07:23 PM   #6292
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
Lars- What's up with the whole Blue compound? I thought it was supposed to be super special dialed for 1/8 outdoors, but then these new tires are only available in red and silver...
D Hunt 3 is offline   Reply With Quote
Old 02-27-2008, 10:18 PM   #6293
I was fortunate that the track wasn't that muddy during my run. I felt bad watching a lot of racers standing in line to the hose to rinse off thier cars.
Donny Vinkemulder
TLR Driver
Old 02-28-2008, 07:52 AM   #6294
Lars Johnson's Avatar
Send a message via AIM to Lars Johnson
I know all the GRP tires are coming in Blue compound, and XBT's and Step Pins are too. They just might not have the Eclipse's done in blue yet, i'm not sure.
Team Associated / Reedy / AKA / Futaba / OS Engines / Byrons Fuel / www.steelescycle.com
Lars Johnson is offline   Reply With Quote
Old 02-28-2008, 09:06 AM   #6295
Registered User
Kendall Welch's Avatar
This probably has already been brought up before. Is blue between red and silver? I guess I have never really known!
Good job at the Nitro Challenge, Lars! If you are coming over to MN again this summer bring your stuff again! It was a blast racing you!
Kendall
Kendall Welch is offline   Reply With Quote
Old 02-28-2008, 09:16 AM   #6296
someone posted this on sgrid yesterday, i copied/pasted it.
Silver: An excellent all-around tire compound. Silver compound tires
work best in situations where the Red compound tires provide too much
grip. You will commonly use Silver front tires to help desensitize the
front end and take steering away.
Red: Red compound tires are widely used on hard-packed outdoor
racetracks. Losis red compound tires provide exceptional bite and
tread life. The Red compound is softer than the Silver compound, yet
slightly firmer than White.
White: Tires molded from the White compound rubber will have increased
grip when compared to the same tire in a Red or Silver compound. If
you are searching for more grip on one or both ends of your vehicle, a
White compound tire will yield more traction.
Pink: Pink compound tires are the hot ticket when racing on tacky
indoor tracks that have a lot of traction. If youre racing on a track
that calls for a low-profile pin, give the pink compound a try.
Blue: Designed to handle the rigors of 1/8-scale nitro racing, blue
compound tires provide a competitive advantage to nitro fanatics.
T Green is offline   Reply With Quote
Old 02-28-2008, 05:22 PM   #6297
I talked to Adam about the blues. In Losi tires they would still be a harder tire than reds. In the GRP tire they would be softer and maybe closer to a red.
indaway is offline   Reply With Quote
Old 02-29-2008, 08:43 AM   #6298
Kendall
Thanks dude, that is definitely a race that everyone should do sometime. I'm going to try to make it up for another series race this year, just gotta figure out when it works. To me, the Blue's work similar to Silver's, with a lot more longevity. I think in certain situations where a blue groove starts showing up, where a red tire would be fastest, a silver would work well - a blue would work similarly to silvers with a longer tread life. Obviously it won't react the same in some areas, but as far as tread life goes, a Blue should outlast everything. I know that the blue XTT's that come with the 8-T worked great at my local track Rat Raceway, which can be abrasive on tires; they far and away outlasted Gators and CrimeFighters.
Old 02-29-2008, 11:56 AM   #6299
Suspended
Just an update on the brake situation:
I took the center diff out and measured the clearance I had and it was right at 3 times what is required. It was 1.45mm instead of the .5mm it needed to be. I put it at .5mm and put a new set of Advantage brakes on and fine tuned the linkage and now it's perfect. It doesn't drag at all at idle or WOT and the brakes will lock up if I need them to. I set the brake bias about 70r/30f so I can let the brakes help the buggy rotate.
Back to the tire talk:
The stock xtt truggy tires worked well for me too. They have tons of traction and a long life too. I'm hoping the xbt buggy tires that came on my race roller buggy work just as well.
Old 02-29-2008, 05:10 PM   #6300
RCcrackHABIT's Avatar
Originally Posted by rescuemann View Post
I have also replaced the stock rear differential plastic bearing shrouds (don't remember the official term) and it seems like the gears are not meshing as well as they were before i removed them. It seemed to go back together well. Does anyone have any ideas or have they came across this before? I am still learning this vehicle.
Mine did the same thing, they are not all the way in. I had to dremel part of the insert surface. I think the inside. Take it apart and have a look.
Anyone got a part # to make the front rod ends captured????
RCcrackHABIT is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
