Old 11-05-2006, 01:31 PM   #616
Trader Rating: 14 (100%+)
Makes sense Captain..
ldawg is offline   Reply With Quote
Old 11-05-2006, 03:23 PM   #617
Aaron Waldron's Avatar
My brake cams were not bound up. The heat is really the last thing I can think of. Losi sells Nomex heat shield material, so I will try that and report any results.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 11-05-2006, 04:18 PM   #618
the buggyman's Avatar
make sure you cut a hole in the scope on the side of the body. It lines up perfiect with the servo. I did that today and the heat was dramatically reduced and actually almost non existant. I don't think this has to do with anything except the heat. There is no more stress on these then any other car. I haven't had a problem but feel more air flow will help dramatically. I do however have a bent front CVD and that sucks, but the car does handle like no other.
the buggyman is offline   Reply With Quote
Old 11-05-2006, 05:17 PM   #619
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
There is one thing. The throttle return spring on the carb side is real strong if you use the one from the kit. I used a Losi gas truck return spring that is wrapped around the throttle linkage rod and crossed over to the first motor mount screw on the left side. This spring no longer applies pressure to the servo once the carb is closed. This allowes me to use a very light spring between the servo horn and the carb.
The servo does not have to work hard at all to hold center.
I say this because I have noticed a lot of guy's cars buzzing when they turn their cars on next to me.
When I changed from the stiff springs my servo stopped buzzing.
When you activate the brakes the servo is going to work easier being that it is now only over comming a very light spring on the throttle side. I'm thinking of eliminating the spring on the rod all together.
I'll check my servo case temps this week during the races and let you know what I find.
Good stuff Aaron.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 11-05-2006, 05:20 PM   #620
SupermaxxRich's Avatar
Good stuff Aaron.
TEX
post a pic for everyone
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 11-05-2006, 05:41 PM   #621
tex1's Avatar
Wink
This is a pic of the Losi return spring that attaches the throttle linkage arm to the motor mount.
The spring on the rod is a very light Traxxas spring.
I think I may run without it this week. Then there would be no strain on the servo staying centered. It will make brake activation easier as well.
Hope this helps,
TEX
Losi 8ight building and setup-rc-stuff-007.jpg   Losi 8ight building and setup-rc-stuff-008.jpg
www.indyrcworld.net
(972) 271-4844
Old 11-05-2006, 05:47 PM   #622
tex1's Avatar
Red face
Sorry about the mess. Just came from the battlefield.
www.indyrcworld.net
(972) 271-4844
Old 11-05-2006, 07:43 PM   #623
R40Victim's Avatar
Vindication at last!... Nah, sorry to hear your servo took a dirt knap on any raceday...I've been lucky with mine. Mine seem to survive every race, but during practice, they kick the bucket. I'm hoping the insulation and rubber mounts do the trick, at least untill we figure out what's happening.
R40Victim is offline   Reply With Quote
Old 11-06-2006, 12:01 AM   #624
Like I said...the irony did not escape me. I thought it was pretty funny on my way off the drivers' stand.
The argument about the servos getting too hot is a pretty good one. I guess it didn't really cross my mind that heat would cause the motors to fail..."too hot to touch" is usually 200 degrees or hotter.
www.liverc.com
Old 11-06-2006, 06:01 AM   #625
i did the same thing with my servo too Aaron, just don't want to "burn" up a $110 servo.
o.s. power is offline   Reply With Quote
Old 11-06-2006, 01:22 PM   #626
Oh trust me, I know what you mean. I don't run for Airtronics...haha. I understand that gets expensive.
It doesn't look at all like my servo was hitting the chassis, except for maybe in one little spot. The spacers from the Jammin' car look to be a little bit taller, so it'll lift the servo a tad bit higher. Other than that, I'm going to try some heat shield and see if that works.
www.liverc.com
Old 11-06-2006, 03:38 PM   #627
Oh trust me, I recognized the irony right away. Just because something may be wrong doesn't mean everything was right on my car. There's no way that a certain brand car can systematically destroy servos. I was laughing to myself all week that it was only a matter of time before my own servo blew up. It's obvious that this IS a problem and not just a fluke and we'll figure it out, don't worry.
And you can say "I told you so". I deserve it!
Honestly, I think it's a good thing that I was able to replicate the problems other people have had (thank goodness it was a club race!), because now I have a basis from which to trouble-shoot my own problem...which will hopefully create a fix for everyone else that has had throttle servo failures.
along with the fix how about some servos from losi?
while we are talking about servos, anyone send in 357 or 358 for repair? how much have you had to pay for repairs?
sksaha33 is offline   Reply With Quote
Old 11-06-2006, 04:35 PM   #628
Trader Rating: 39 (100%+)
I just got my 360 back from repair and there was no charge since it was under warranty. The servo was plain defective...it failed after 2 tanks of fuel and it was shimmed and the EPA precisely set. The Futaba 9451 i'm using for a replacement is still going strong and I may keep using it for the indoor season.
Just of curiosity, how many of the failed servos were Airtronics?
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 11-06-2006, 05:06 PM   #629
R40Victim's Avatar
All mine were JR; three Z590s, a standard(airplane servo, wasn't even metal geared), and the Z650 didn't die, it just twitched real bad. The Z590 in it now survived a race and a day of practice. My next big race is this Saturday... I'll post if it survives...
Old 11-06-2006, 07:13 PM   #630
no offense R40, but maybe if you stepped up to a better servo, you might not have any problems
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
