Old 01-17-2008, 09:13 PM   #6046
cornerspeed's Avatar
Originally Posted by ALJR View Post
Is there a way to adjust the rear diff gear mesh? I just receied my new 8ight Race Roller and the mesh between the ring/pinion is horrible!
I took it apart once already to see if there were a shim I could remove. There were none that I could see, nor any way to losen the gear mesh...
Is this normal? The front and center diffs feel fine. The rear seems to be out of round because it seems fine half way around. The other half feels like its full for sand...
Any sugestions?
It will go away after a couple of runs. They have all done that.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-17-2008, 09:21 PM   #6047
nta01's Avatar
Trader Rating: 19 (100%+)
Any sugestions?
Same thing with my race roller I just got. It appears that dif housing was slightly molded out of spec. When put together, the ring/pinion gear mesh is to tight. All I did was took a piece of blue shrink wrap, split it down the middle and placed it in the left side front half of the receiving groove. This shims it slightly enough to pull the ring gear away from the pinion. It works fine. I will probably buy new dif cases prior to my next oil change.
Tom
nta01 is offline   Reply With Quote
Old 01-17-2008, 09:47 PM   #6048
Be sure the inner pinion bearing is pressed all the way into the diff case. If you shim it out and the bearing is not set all the way in and you run it for awhile the bearing may set it's self and you will have a very sloppy mesh.
gasser is offline   Reply With Quote
Old 01-18-2008, 04:42 AM   #6049
Hellsavage's Avatar
I have the same gritty rear diff. How many gallon til it goes away?
Does the case of the 8T fit?
thanks Hellsavage
Hellsavage is offline   Reply With Quote
Old 01-18-2008, 06:47 PM   #6050
Can any one else verify this? I would hate to munch brand new diff, only to shell out another $40 for a R&P gears...
I have never seen a 1/8 buggy diff that didn't have room for adjustment w/ shimms
ALJR is offline   Reply With Quote
Old 01-18-2008, 07:11 PM   #6051
thanks Hellsavage
It should go away after 2 to 4 tanks. Are you greasing the ring and pinoin gear teeth? Do you have too much end play for the pinoin shaft thru the bearings in the case? Should have very little to no end play. The bearing plastic inserts could be shaved down some where they contact the flange part of the diff bearings if there is excessive plastic flashing.
Donny Vinkemulder
TLR Driver
Old 01-19-2008, 02:16 AM   #6052
Default sloppy ackerman plate
Hi Guy's
Do any of you know were you can get an after market ackerman plate with bearings or bushings in it to replace the stock ackerman plate.
Were can they be purchased from ?????
Or modify the original ackerman plate.
BUNDY is offline   Reply With Quote
Old 01-19-2008, 09:00 AM   #6053
MaxxBashers's Avatar
Trader Rating: 107 (100%+)
Originally Posted by BUNDY View Post
Hi Guy's
I've been looking all over for the Eck Tec ones and they are out of stock. Anyone want to do the mod to a couple and sell them?
Eric "EJ" Jordan
MaxxBashers is offline   Reply With Quote
Old 01-20-2008, 02:28 AM   #6054
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
New paint.
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 01-20-2008, 12:46 PM   #6055
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
just a general question for all here-
im looking to get the 8ight-t for a truggy this upcoming summer and was wondering should i get the rtr and part it out to go electric or get the race roller and go electric right away?
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 01-20-2008, 03:37 PM   #6056
Just do the mod yourself. I spelled it out awhile ago. It's super easy.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 01-21-2008, 07:31 AM   #6057
Race-Wright's Avatar
could you spell it out again with some picks this time?
Race-Wright is offline   Reply With Quote
Old 01-22-2008, 03:36 PM   #6058
Smoothone's Avatar
Can anyone tell me what the total caster on the eight buggy is. I mean kickup + caster when I say total.
Smoothone is offline   Reply With Quote
Old 01-22-2008, 05:16 PM   #6059
SteveJa's Avatar
Trader Rating: 17 (100%+)
Yes... I did this and it is great.......only one problem... the bolt almost hits the top plate.....
SteveJa is offline   Reply With Quote
Old 01-22-2008, 05:37 PM   #6060
air8's Avatar
20 degrees
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
