Old 01-09-2008, 08:23 PM   #6001
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by micrors4guy View Post
ezveedub-will you be at the battle at the beach in march?
Not sure! I drive a lot, but thats a far drive in Florida! I haven't been to the pan handle since I picked up my S4 in Mobile, Alabama. I have 3 tracks to chose from here in SoFla. Miami, Mills Pond and Coral Springs. On road, Coral springs, Royal Palm Beach and Homestead.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-09-2008, 08:28 PM   #6002
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i hear yah, i mistaked ft. lauterdale for ft. walton. Me and 506 of my friends are making the trip from louisiana for the race. Its the same week as spring break for us and my b-da is that sunday
micrors4guy is offline   Reply With Quote
Old 01-09-2008, 08:42 PM   #6003
ezveedub's Avatar
Hey, It ain't spring break unless its SoFla baby!
Finally got it out of the box. Gonna go over it now. I guess it will drop the Axe Rossi X1 EVO Cobra in it.
Old 01-10-2008, 08:12 AM   #6004
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by rezenclowd3 View Post
The keyed insert hole must be drilled out to make it round, if one wants, a dremel may do the trick.
I dremeled the hole to get rid of most of that flat spot to keep the drill bit from "walking" when I did this mod... but then drilled it with a 1/4" bit. I also "crimped" the bushings in place with vice-grips to keep them seated firmly... other than that, I did the mod the way satoch described it. Great idea!
BTW y'all need to listen to what Tex is telling you about this car, for several reasons...
1) He's scary fast with this car.
2) He knows what modifications and settings work
3) He's not your average joe off the street... he holds multiple patents for mechanical stuff in another hobby sector.
Brad
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-10-2008, 04:01 PM   #6005
I think what Tex was trying to say was that he liked stock better because it was kind of more exponential in handling and steering. Kind of like in FL when its 100% sand you just kinda lean back pin it and enjoy the ride even though you are kind of loose and wander a good bit...
lanerbrainer205 is offline   Reply With Quote
Old 01-11-2008, 12:54 AM   #6006
ezveedub's Avatar
Hey guys, I was checking a few pages here but didn't see much. Is the rear CVD shaft known for popping out of the center diff cup? My rear axle's drive pins are at the edge of the outdrive. Seems like when this gets worn, it may pop out. Thinking about installing a washer between the axeshaft and rear case diff pinion bearing to move it further into the diff outdrive.
Old 01-11-2008, 12:56 AM   #6007
BOOST's Avatar
Nah it will be fine, both of mine look the same and have never had a problem with either of them.
BOOST is offline   Reply With Quote
Old 01-11-2008, 01:06 AM   #6008
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
Default Yep.
Case a 25 footer at top speed and it will!!.....Happened to me twice WITH Kings Head braces. Although, it was a one of a kind retarded jump that launched you about 12-15 feet straight up and you either had to land in the flats or try to downside a small triple about 25 feet away.........it can happen.
oldguyzrule is offline   Reply With Quote
Old 01-11-2008, 01:19 AM   #6009
ezveedub's Avatar
I just loosened the axle set screw and moved the CVD shaft forward. Wasn't much, but a bit better. I see me cutting the pinion notch more to get it to go in to a "good" position in the drive cup. Compared to my other cars, this looks odd. Mugen had front axles pop out depending on how wide the track is set to, so they made 3mm longer "option" front cvd shafts. Maybe this is something for Losi to revise.
Old 01-11-2008, 01:40 AM   #6010
BOOST's Avatar
Wouldn't moving it forward mean that the pinion gear could move back and forth, possibly grinding into the ring gear????
Old 01-11-2008, 01:50 AM   #6011
ezveedub's Avatar
Not if you put spacer in between the CVD and bearing. This would keep the pinion from moving.
Old 01-11-2008, 01:51 AM   #6012
BOOST's Avatar
Yep that will do it!
Old 01-11-2008, 02:05 AM   #6013
ezveedub's Avatar
Here is what I did. If you want to know the details, LMK, as there is a .3mm Kyosho shim placed in between the washer and the bearing to prevent any issues with the washer rubbing the bearing races and damaging it.
As you can see, the CVD is now "plunged" further into the outdrive cup.
Losi 8ight building and setup-img_0737.jpg   Losi 8ight building and setup-img_0738.jpg
Old 01-11-2008, 02:08 AM   #6014
BOOST's Avatar
Right on looks factory.....you should get some cvd condoms for them. They are great for keeping dirt out and set screws in!
Old 01-11-2008, 02:16 AM   #6015
ezveedub's Avatar
Thinking about it. I might just heat shrink it for now. I got some areas to look over, like the battery tray area. I had a friend destroy his battery with that screw hump area. Its need more padding on top of that.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
