Old 01-09-2008, 09:57 AM   #5986
Integra's Avatar
tdeal823...look into Mc2....Mitch makes some Wicked parts and stands behind his stuff 100%...i run all his toe plates and i love em.
Old 01-09-2008, 11:10 AM   #5987
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by tdeal823 View Post
I think what TEX is saying is that sometimes loose is fast.
The car needs some give to it to compensate for inconsistant ground/traction.
Kind of like having to much traction on the rear and you traction roll vs. a bit loose and getting a bit of slide.
I can see it but I myself have been hunting down all the loose points on the steering and trying to make them a minimun.
Exactly. RC Cars usually need a touch of slop in them to an extent. Even electric TC's are built with a little bit of slop in them to make them easier to drive.
Jon Kerr is offline   Reply With Quote
Old 01-09-2008, 01:41 PM   #5988
BOOST's Avatar
I also agree with this, I have no problem keeping on the race line lap after lap.
BOOST is offline   Reply With Quote
Old 01-09-2008, 04:14 PM   #5989
Hellsavage's Avatar
Do U people meen Losi made it sloppy on purpose?
The 8T I have is a lot less sloppy then the brand new 8B I recieved this week.
I think the tollerance on the bushing is to big.
When I have some spare time I am gona make me some Bronze bushings that will fit in the plate without having to dremel or anything. Just a direct fit.
When I have theme I wil post theme.
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 01-09-2008, 05:42 PM   #5990
mzl Hellsavage
Why would you waste the time making a bronze bushing that already exists? Just drill the ackerman with a 1/4" bit and buy the bushing from McMaster-Carr as I posted several pages back.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 01-09-2008, 05:43 PM   #5991
cornerspeed's Avatar
Originally Posted by tex1 View Post
I spent a lot of time on this car. Hours and hours to take out the slop. When I finally got it, it sucked. It became darty on the track. I went back to stock and was very happy. Use good lithium grease on the steel to steel connection and call it a day.
TEX
I 100% agree with this. I did the same thing and the car was hard to drive and had slow/inconsistant lap times.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 01-09-2008, 05:51 PM   #5992
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
OK, guys. Got a new Losi 8 race roller in today. Haven't opened the box yet, but is there anything to change or check before I run it? I have the usual stuff to check, but I'm not sure if there is any issues to look out for on this model right out the box.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-09-2008, 05:57 PM   #5993
air8's Avatar
Add a little tire glue to the tires, just to be sure.
Add loctite to the CV set screws.
Pull the diffs and check for full
Use a little loctite on the engine mount screws, and other metal fasteners
Don't let the servos over work themselves. Set the EPA
Start here. There is a ton more stuff to bullet proof the car.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-09-2008, 06:24 PM   #5994
what experiences have you guys had running the losi inserted rear toe plates?
I was thinking they would be a good investment but I would think that the inserts would still wear. can you buy replacement inserts like you can for the arms? if so please provide a part # because I could not find the #
Thanks guys for the info
The inserts hold up really good. The repacement inserts part # is LOSA1756. Has all the inserts included. My experience with the Losi plates are they raise the roll center of the car in the rear. So, if you need more steering, they would work well.
The M2C plates lower the roll center on the rear. At least with the plates I have tried. Add's rear traction on loose tracks.
Donny Vinkemulder
TLR Driver
Old 01-09-2008, 06:28 PM   #5995
The race roller has a different set-up. Made to be easier to drive hard or really rough tracks. Look at the recommendations on the set-up sheet included with your car. It has some suggestions to help it steer more. Give the Roller set-up a try for a while then maybe make some changes here or there. One at a time. Then down the road, try the standard set-up from Adam Drake or Mike Truhe.
Donny Vinkemulder
TLR Driver
Old 01-09-2008, 06:29 PM   #5996
ezveedub's Avatar
So basically check for the mis-built stuff you can expect in a complete pre-built roller. I assume these already have the improved shock seals.
Old 01-09-2008, 06:32 PM   #5997
BOOST's Avatar
I wouldn't go as far as saying 'mis-built', but just check, my 8t was built just as good as I would have done it but I still checked the metal to metal screws, set screws...definately the tyre gluing!
And it will have the white o-rings for shocks!
Old 01-09-2008, 06:55 PM   #5998
air8's Avatar
Yeah, I didn't mean to imply mis-built. Over time you will develop a routine to checking over your machine. These are simply some things I do once in a while to make sure I don't have a DNF. Just a couple basics.
--"U Ain't Fast!!"
Chris Pearce
Old 01-09-2008, 07:35 PM   #5999
ezveedub's Avatar
I figured so. I have other cars as well, so I will be seeing how this car compares now since it has been out for a while and some improvements have been made. After seeing where this thing is made on the box it came in, I started wonder "Uh-oh". I have heard the stories first hand on the RC8 and seen some of it. I started wondering if I should be checking more than I usually am used to. I usually trust 2 people, one is me, and other is NOT the guys building it!
Old 01-09-2008, 08:17 PM   #6000
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
ezveedub-will you be at the battle at the beach in march?
micrors4guy is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
