Old 01-05-2008, 04:12 PM   #5941
air8's Avatar
Originally Posted by Hellsavage View Post
Oke I have my 8ight put together. Now since the lid is stil tranparant I se the throtle linkage is pressing against the lid. Is this fine or do I have to cut a hole at this place.
thanks
mzl Hellsavage
Hmmmm... That sucks. If you never changed the servo brand then cutting the excess would be ok. But, if you change brands anytime down the road you might need that extra 1-2mm. How bad is it rubbing on the body? And are you leaving that 1-2mm of extra play at full throttle? Like when you're full throttle you can still pull the linkage another mm or two? Might have to see what the more experienced racers have done to remedy that one.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-05-2008, 04:14 PM   #5942
tex1's Avatar
Send a message via Yahoo to tex1
If Losi would just take the diff case tool and mold in a metal side plate into that particular side of the slot, it would fix the problem. They could use hardened steel shim material. This is a two operation tool anyways to get the metal bearing supports in.
TEX
tex1 is offline   Reply With Quote
Old 01-05-2008, 04:19 PM   #5943
tex1's Avatar
Put a 3mm spacer under your front body mount and tighten it back down. It will lift the body just enough to clear the pipe nipple and throttle linkages. It also makes the nose fit better without destroying the body.
Fixed.
TEX
Old 01-05-2008, 04:21 PM   #5944
air8's Avatar
Fixed.
TEX
Wow. That was simple. Never dawned on me to do that. Nice tip.
--"U Ain't Fast!!"
Chris Pearce
Old 01-05-2008, 06:40 PM   #5945
dodgeboy93's Avatar
hello guys,
long time reader first time poster... great job guys on this thread so much info if you read it all and apply it we all could be pros!!!!!
i have a question tho #losa9155 quick change engine mount .. can you use a starter box with this part ????
dodgeboy93 is offline   Reply With Quote
Old 01-05-2008, 06:41 PM   #5946
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by dodgeboy93 View Post
hello guys,
Yes, a starter box will work fine.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 01-06-2008, 12:24 PM   #5947
Hi guys, i have a quick question for you.
a few of us are having trouble with the rear suspension binding up after a run. when you press down the back of the car, it stays down. this may be due to dirt getting into the wishbone pivot points, but its happening a lot, to a number of losi 8ights. we have tried reaming the wishbones, and adding a small peice of foam behind the diaphram in the shocks, this has made them slightly better, but it is still a problem. has anyone else had this problem? if so what did you do to cure it?
thanks.
watty is offline   Reply With Quote
Old 01-06-2008, 12:26 PM   #5948
thanks.
get the m2c rear toe plates...it really, really frees up the suspension and you will notice your ride height will remain much more constistant throughout the race day
gtsum is offline   Reply With Quote
Old 01-06-2008, 12:43 PM   #5949
Maximo's Avatar
Originally Posted by sickboy View Post
ninja 2053 twist-lock pipe and long header. kinda pricy, but if you want the best 053 pipe, there it is. i have had mine for over a year, not even one tiny ding on it anywhere. indestructable.
Actually the Ninja 2053 is not a 053...the 2053 is a whole different tuned pipe...the 053 is a 2 chamber pipe, the 2053 is a 3 chamber........... as well a 053 makes more power and TQ then a 2053.....
Maximo is offline   Reply With Quote
Old 01-06-2008, 12:55 PM   #5950
yep, what he said^^^^^^^
Old 01-06-2008, 02:02 PM   #5951
speedy2's Avatar
M2C also makes rear suspsion rods that are 0.2 mm thinner
and free up the arms...
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 01-06-2008, 07:43 PM   #5952
Integra's Avatar
thanks.
i say bent hingepins....thats the only real way the rear end would lock down like that...Unless its the shocks or something...but i have a feeling your rear inside and outside pins are Bent to all hell.
Old 01-06-2008, 07:51 PM   #5953
RETRO RC's Avatar
Default suspention binding
there are a couple of things you need to check,
#1 as mentioned above hingepins check both inner and outer for bends.
#2 shock seals - as these get old they tend to become hard and restrict the movent of the shock shaft, especially with ultimate shock seals.
#3 the shock shafts may also be bent
in the past if I've found my shocks not returning properly these are usually the reasons
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 01-06-2008, 07:57 PM   #5954
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
short video of a lap at my local track my friend shot before the battery on the camera went dead. Was only able to get about a lap and a half. Batterys die when he goes to flip me back over.
http://www.youtube.com/watch?v=A5gg8Bqu93A
micrors4guy is offline   Reply With Quote
Old 01-06-2008, 09:59 PM   #5955
ShotGunn's Avatar
Hey if i bought a losi 8ight pro an put a rtr motor mount on it with a roto start engine, would it work.
I hate the starter box idea
ShotGunn is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
