Old 01-01-2008, 09:01 AM   #5881
mandy116's Avatar
Trader Rating: 20 (100%+)
Hey fellas i just bought the losi lipo rx battery and regulator with swith, instructions say to disconnect battery from the regulator after use to avoid over dischargeing the battery. do i have to actually disconnect the plug or is turning the swith to off enough? thanx for the help
mandy116 is offline   Reply With Quote
Old 01-01-2008, 09:03 AM   #5882
mandy116's Avatar
switch, I meant to say switch.
Old 01-01-2008, 09:13 AM   #5883
disconnect the battery from the regulator, the switch still allows some 'bleed off' when not in use
lovell is offline   Reply With Quote
Old 01-01-2008, 09:49 AM   #5884
I never disconnect my lipo. It stays in the box. You just need to wire things properly. It's Battery to Switch, Switch to Regulator, Regulator to Receiver. My buggy was just sitting for 3 weeks (first time ever) and evrything is fine. I'm charging it up right now for tomorrows racing.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 01-01-2008, 11:47 AM   #5885
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
lovell is right, disconnect the lipo from the regulator. It does allow a slight discharge even when off.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 01-01-2008, 11:51 AM   #5886
Originally Posted by rockfordccinc View Post
thanks everybody but if i were to use the 9000s what would be a good choice in the jr family of servos for the throttle.
Anything with a torque above 120oz/in and preferably a transit speed of .15 or faster. I use the Futaba BL451 for both duties and its great, previously I had used Airtronics 358s. 2 of my other Losi buddies use JR 9000Ts. Just buy what you want, but its always better to have more than enough torque than not enough, as then the transit speed is also killed, and a high likelyhood your servo may burn itself out.
Old 01-01-2008, 01:11 PM   #5887
air8's Avatar
With lipos it's always safer to unplug the battery from the switch. But I sometimes unplug them and sometimes don't. Besides it's not that hard to unplug a battery.
A note on servos: I was using servos from different manufacturers last summer and I learned that using the same spline count can save frustration. Especially when short on time. I'm sure this should be common knowledge, so I guess this is for new drivers. It's a lot of work to try your servos in different spots if the spline counts are not the same. I swap servo locations sometimes to get a different feel from the vehicles and it was too much work. So now I have settled on one servo to serve as throttle and steering. I use the servos with 200@.10.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-01-2008, 07:15 PM   #5888
SteveJa's Avatar
is there a setup sheet that you can edit (type into) then print out, there is one for most others, but I have not seen one like this for the 8ight..... I know you can save them, but when you write like me it is much better to type it out then write it out....
SteveJa is offline   Reply With Quote
Old 01-01-2008, 07:21 PM   #5889
I too am interested in an editable PDF setup sheet.
Thanks for correcting the spelling SteveJa ;-)
Old 01-01-2008, 07:28 PM   #5890
SteveJa's Avatar
my writing and my spelling are the same.....
Thanks...
So is there one out there ?
Old 01-01-2008, 09:26 PM   #5891
BOOST's Avatar
You could download one from Losi and see if you can edit it, worth a try!?!
BOOST is offline   Reply With Quote
Old 01-01-2008, 10:14 PM   #5892
SteveJa's Avatar
does not work, pdf files will not let you do anything to them, unless you have the full program.... the other ones I speak of only let you type in them, then print them out.. when done, you cant save them...... this is fine, but you cant even do this with the one for the losi... just print it out and write on it....
Old 01-02-2008, 09:03 AM   #5893
Jon Kerr's Avatar
http://setups.rccars.com/
Todd Hodge gave me this site. It's great.
Jon Kerr is offline   Reply With Quote
Old 01-02-2008, 03:04 PM   #5894
SteveJa's Avatar
thanks.......but you cant edit the losi 8 setup from that site....
Old 01-02-2008, 03:08 PM   #5895
Matt Howard's Avatar
so now your back to the Losi? Man, I can't keep track of you guys anymore
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
