Old 12-30-2007, 07:37 PM   #5851
JWRockman's Avatar
I haven't used shims yet but I bet the Sportwerks shims work on the crosspins in the diff. Look up Sportwerks Turmoil in www.Horizonhobby.com or www.sportwerksrc.com
Rockman
JWRockman is offline   Reply With Quote
Old 12-30-2007, 07:40 PM   #5852
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by Hot Rod RAC3R8 View Post
hey,
always run 2 o-rings under where battery is. put it imbetween the chassis and the tray on the rear screw. ppl always blow out throttle servos by not putting them under it. and dont torque down on the screw cause that defeats the purpose of having the o-rings there.
I don't use the Orings under the battery box and have been fine. It is NOT needed as long as you have make sure there is no binding at all, and that your EPA is set right.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-30-2007, 07:50 PM   #5853
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
hey,
People have been blowing throttle servos because they don`t get the throttle linkage exactly right and/or they don`t adjust throttle throw on the radios . I know at least 15 racers plus myself that don`t run the o-rings and have had the buggies for well past a year on the same servo and still going .
Briguy is offline   Reply With Quote
Old 12-30-2007, 07:56 PM   #5854
Integra's Avatar
X2 the O ring trick is a Lazy Man's way of doing it....essentially slappin a Bandaid on a serious wound....when in reality it should be Disinfected and stiched up so Nothing happens down the road.....HOW are u suppos to keep a Loose screw in anyways ?
Old 12-30-2007, 07:56 PM   #5855
A problem I had when I ran the Airtronics servos is that the throttle/ brake linkage sat too low. The adjustment collars would hit the servo when applying the brakes. The fix for that was to put a washer between the servo horn attachment and servo horn. My Futaba BL451s don't need any adjustments, just make sure the EPA on the throttle side is less than full extension of the carb.
Old 12-30-2007, 08:36 PM   #5856
joecool's Avatar
Trader Rating: 19 (100%+)
Default a new race roller for sale
does anyone want to buy a brand new sealed in box race roller buggy. how much do you think i can get for it? i would like to get around 580? if anyone is interested pm me or just post that you want it. here is a pic of it. make me an offer for it!
joecool is offline   Reply With Quote
Old 12-30-2007, 08:41 PM   #5857
joecool's Avatar
Default here is the picture
sorry i forgot to post the pic
Old 12-30-2007, 08:42 PM   #5858
sickboy's Avatar
Trader Rating: 72 (100%+)
$580 aint gonna happen. i would suggest about $450 shipped would be the going price.
sickboy is offline   Reply With Quote
Old 12-30-2007, 08:56 PM   #5859
joecool's Avatar
that sounds super cheap.... if anyone can make an offer for 475 i will ship it to them. ANY TAKERS? thats a super good deal for an unopened losi 8ight. i will also accept a trade for an rc8 in an unopened box.
Old 12-30-2007, 09:02 PM   #5860
Briguy's Avatar
Bmain has them for under $440
Old 12-30-2007, 09:03 PM   #5861
Briguy's Avatar
Not super cheap , that`s reality .
Old 12-31-2007, 02:10 AM   #5862
Hellsavage's Avatar
Originally Posted by Walt View Post
You didn't mention the pipe and header. I run the C6 and bought it as a package with their 01351-192P manifold and 01351-2045p pipe and LOVE it. I also run the engine with the 6.5mm venturi in it. Still makes as much power as an off-road track can handle, and I get great fuel mileage (12 minute runs on the current track layout, that is admittedly a 'low power' layout).
Since you run the 8T you probably already stock the rear-outer hinge pins. Those bend pretty easily.
Its the engine and pipe combo I will be using So it will run C6 BB with 2045 pipe and the 92mm mainfold
Originally Posted by air8 View Post
Not sure what others do for the shock boots, but I use party balloons (animal making balloons) that I cut to length. A bag of 100 is $8 and they last longer than the losi shock boots.
Hellsavage--if you do the captured steering link, remember that the front inner hinge pin cover becomes the next weakest link. I used the KH aluminum cover on my 8 and 8T. But if you don't do the captured link, then you will be totally safe. And remember to heatshrink the center CVD's
I will be getting the CVD condoms but they are soldout at Amain.
The captured rod end I will be doing when it becomes a problem. The buggy is a car with a lighter wheel base. So I will test it first.
Originally Posted by satoch View Post
Hell savage: Party balloons don't work IMO. They bunch up and limit down travel. I use Thunder Tiger accordian boots. They work much better, are easy to get on/off for cleaning and don't rip.
Forget Losi inner steering rod ends-they break. Go with Kyosho P/N KYO1296
If you're getting a C6 get the RB 2045 pipe with the 92mm & 98mm headers. Yeah, they're stupid expensive but nothing else works as well on that motor.
Also, get the Dynamite long lasting aluminum shoes. Everything else wears out way too fast.
Heat shrink doesn't last on the cvd's. Get the CV Condoms- a must have.
I am running a Werks 4 carbons and it lasts forever. Just make sure U use locktite on the nut after it is set to the proper settings.
I look in to the Kyosho rod ends it might be the trick.
To all thanks fore the reply
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 12-31-2007, 04:25 PM   #5863
Trader Rating: 26 (100%+)
449.00 at amain plus another 40 off spending over 400.00. thats 409.00.375.00 shipped would be a deal
eddie10 is offline   Reply With Quote
Old 12-31-2007, 04:46 PM   #5864
Joe Cool,
Eddie is right sorry man, you must have over paid when you got it.
If you want to go 375 shipped let me know.
cfish8u2 is offline   Reply With Quote
Old 12-31-2007, 05:42 PM   #5865
Mcfly's Avatar
hi guys, trying to go better this year with the losi 8 and have heard some people overdrive the front, has anyone here tryed it, and if its worth trying what do i need for it?
Mcfly is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
