Losi 8ight building and setup
#5836
Sorry Air8, I just expanded the third picture a saw the shims, maybe something that came from the RTR, but my pro kit never had them.
Anyway, after so much talk about the wear of the diffs I took mine a part yesterday just to check, no doubt there is some wear, they been there since July, probably replace them before next season, but the wear in mine is nothing to worry about it.
Just my 2 cents
Just my 2 cents
#5837
mine came with no spyder shims either.....i dont feel it makes that big of a difference.
#5839
file the tip of the screw so its not a Blunt end...make it pointy and itll go in like butter...like u already stated about 6-7 posts up...Problem solved...what shoes are u eating through ?
#5841
ya i could see that....6061 tends to do that....and if ur not careful and ur clutch gets REAL hott...those shoes can melt and curl up pretty bad Junking the shoes pretty quick...i suggest some Dynamite shoes or some KH or M2C 7075's whch are guarenteed to last at Least a couple Hard race weekends.
#5842
Okay I just bought me a race roller. Am I missing something.
It will get a RB C6 and 2 ACE 1015 servo's.
1 x LOSA1700 Team Losi Front Suspension Arm Set: 8B
1 x LOSA1722 Team Losi Rear Suspension Arms: 8B
1 x LOSA3505 Team Losi Differential Seal Set: 8B/8T
1 x LOSA5426 Team Losi 15mm Shock Boot Set (4): 8B/8T
1 x LOSA6050 Team Losi Steering Ball Set 6.8mm: 8B/8T
1 x LOSA3521 Team Losi F/R CV Driveshafts (2): 8B
1 x LOSA3526 Team Losi Center Front CV Driveshaft Assembly: 8B
1 x LOSA4430 Team Losi 8ight Aluminum Rear Gearbox Bearing Inserts: 8B/8T
1 x KHZ-KP-215 King Headz Team Losi 8ight/8ight-T Extended EZ Change Motor Mount
1 x LOSA4441 Team Losi 8ight Servo Saver Top, Aluminum: (8B/8T)
1 x LOSA99032 Team Losi Aluminum Servo Arm: Futaba
1 x LOSA0801 Team Losi 8ight 1/8 4WD Competition Buggy Race Roller
2 x LOSA4442 Team Losi Aluminum Center Front Diff Bearing Adapter: 8B/8T
I hope it will be here in 2 weeks. By then I have my first ever buggy race.
I come frome Truggy 8T and before that Hellfire SS.
I use the radio geare frome the truggy and swich between.
mzl Hellsavage
Forgot to say Futabe 3PK as radio gear.
mzl Hellsavage
#5843
i have had the center diff cup go bad in one day also. i think that it really depends on how rough your track is. on my home track which is very rough i get about half a gallon out of the center and rear diff cups. the last race i went to i put in new diff cups before the race and they showed almost no wear from the race. the major difference was that the track was relativitly smooth.
#5844
mzl Hellsavage
mzl Hellsavage
Since you run the 8T you probably already stock the rear-outer hinge pins. Those bend pretty easily.
#5845
Not sure what others do for the shock boots, but I use party balloons (animal making balloons) that I cut to length. A bag of 100 is $8 and they last longer than the losi shock boots.
Hellsavage--if you do the captured steering link, remember that the front inner hinge pin cover becomes the next weakest link. I used the KH aluminum cover on my 8 and 8T. But if you don't do the captured link, then you will be totally safe. And remember to heatshrink the center CVD's
#5846
Integra: I would love to prove it to you somehow, but I can't. I honestly only get 1-2 meets out of my diff cups. There is NO reason for me to lie about this....
#5847
Hell savage: Party balloons don't work IMO. They bunch up and limit down travel. I use Thunder Tiger accordian boots. They work much better, are easy to get on/off for cleaning and don't rip.
Forget Losi inner steering rod ends-they break. Go with Kyosho P/N KYO1296
If you're getting a C6 get the RB 2045 pipe with the 92mm & 98mm headers. Yeah, they're stupid expensive but nothing else works as well on that motor.
Also, get the Dynamite long lasting aluminum shoes. Everything else wears out way too fast.
Heat shrink doesn't last on the cvd's. Get the CV Condoms- a must have.
#5848
I've been running the losi all year and had great success with the first generation car. I had a second generation kit and it seemed that the plastic in the diffs was a little softer. After about a month of racing the diffs were notched where the crosspins sat in the groove, it looked like they were wearing sideways. All three diffs. I notice event he arms from the first gen car were a tougher material. I think they just changed the plastic mix, or had a bad batch of plastic. I replaced all three diff cups with no problems yet. Needless to say that some people are experiencing this, and it is true. Hopefully they are working on it.
#5850
hey,
always run 2 o-rings under where battery is. put it imbetween the chassis and the tray on the rear screw. ppl always blow out throttle servos by not putting them under it. and dont torque down on the screw cause that defeats the purpose of having the o-rings there.
