Old 12-27-2007, 09:57 PM   #5791
Hello i'm a new 8ight owner. where can i get set ups? not too many on the losi home page anyone have links or web page on any Adam Drake or any other good set ups?
THANKS
kahuna2793 is offline   Reply With Quote
Old 12-27-2007, 10:14 PM   #5792
cornerspeed's Avatar
THANKS
The basic all around set-up is the Adam Drake Nats set-up. Should be up on the Losi web-site.
When you understand your track type/surface and when you run your car, ask here for any advise that you may need. Lots of good help and info here.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-27-2007, 11:49 PM   #5793
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
Ok guys got a bit of a problem here.
The clutch bell bearing my Truggy collapsed and the outer race is stuck in the flywheel. I’ve tried getting a small hook underneath it but it just bends the hook outa shape.
Anyone got any ides about how to get out cause I cant get the flywheel off my engine with it in there
Lewis Hewett
12a_rx2 is offline   Reply With Quote
Old 12-28-2007, 03:43 AM   #5794
zigzag84's Avatar
hi
do you have news about problem of diff ???
Do you shim it ?
Caster K8T Pro
RB C6 BBT7
KMW Product BB Shocks
Mugen option parts
Proline LPR + Bowtie
Body Symbio T2
http://truggy-france.com/autres-truggy-f13/truggy-caster-k8t-maj-10_04_08-caro-symbio-t2-t3063.htm
zigzag84 is offline   Reply With Quote
Old 12-28-2007, 07:31 AM   #5795
The clutch bell bearing my Truggy collapsed and the outer race is stuck in the flywheel. Iíve tried getting a small hook underneath it but it just bends the hook outa shape.
When mine got stuck I took a small screw driver or something you can in from the backside like a punch, and just tapped it out. They can be stubborn sometimes, but patience is the key.
Watkins4x is offline   Reply With Quote
Old 12-28-2007, 07:31 AM   #5796
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Originally Posted by zigzag84 View Post
hi
Do you shim it ?
Looks like it wasn`t put together correctly and not so much a shim issue . .
Briguy is offline   Reply With Quote
Old 12-28-2007, 09:01 AM   #5797
chuckinator's Avatar
hi
Do you shim it ?
It looks more like a maintance issure more than building it wrong. It pretty hard to mess a diff up building it. Losi is aware that the diff cases and are working on a fix.
chuckinator is offline   Reply With Quote
Old 12-28-2007, 09:40 AM   #5798
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
You should be checking your diffs after every day of racing. When at a big club race like Revelation when there is a large enough break, I will also quickly check the diffs then as this will harm the diff gears. Like I said previously, usually I have to toss 1-2 diff cups every race day, but they are NEVER that bad. Usually mine only get bad enough where you can just start to feel the notch the cross pin makes.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-28-2007, 09:48 AM   #5799
Jon Kerr's Avatar
That's so strange because I've been running the car for at least a couple of gallons and there isn't even hardly any wear on mine. I know guys who have run the same diffs for 4+ gallons without any problems.
Jon Kerr is offline   Reply With Quote
Old 12-28-2007, 09:52 AM   #5800
Ill try to take a pic next time I change my diffs and show the wear that I change them at. Like I said before, I've tried shimming the diffs several ways or not shimming, and some other odd little tricks...must be the insane traction plus a C6BB I just bought 8 diff cups by the way..... I hate running out and having to borrow one at the track right before the race...no LHS here...
Old 12-28-2007, 12:17 PM   #5801
air8's Avatar
Man, that sounds like way too much work and wear. Do your front and rear diffs suffer from the same?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-28-2007, 12:40 PM   #5802
Trader Rating: 39 (100%+)
The center diff takes the most abuse.
ridgewaybodies is offline   Reply With Quote
Old 12-28-2007, 02:10 PM   #5803
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
ok i cant seem to find this in the thread but i know its there. the only differences in PARTS between the rtr and kit/pro roller are the front and rear shock towers, shock caps, hubs, and the chassis correct? or am i forgeting some?
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 12-28-2007, 02:17 PM   #5804
sickboy's Avatar
Trader Rating: 72 (100%+)
........hinge pins, clutch shoes, toe plates, shock shafts and motor mounts. It also does not come with the option shock springs and sway bars.
sickboy is offline   Reply With Quote
Old 12-28-2007, 02:30 PM   #5805
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
The people that are having issues with their diffs... and be honest now.... Do you use that throttle/brake as an on/on switch? Your either on the 100% gas or on the brakes? Just curious.
I got my 8ight used. It does not appear that the diff housings were ever replaced. I've put 3, almost 4 gallons on it... to the point the chassis is nearly wore out from myself and the previous owner... and I haven't had one issue with them.
I have my 8ight T... not nearly as much time on it... 2 race weekends... and no issues there either. But I'd hope not with how little time I have on it.
I really dont get the guys that bash the Losi. All year, I broke 3 tie rod ends, one inner hinge pin. One servo in the beginning because I didn't set it up right... not because the car blew it up. Two of those parts were because my receiver batt went dead and the throttle pegged wide open. Vspec stuck wide open hitting a full size parked car = broken parts on any car.
XMSRacing is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
