Old 12-21-2007, 06:08 AM   #5776
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Originally Posted by W.E.D.Jim View Post
+1
There are NO R/C cars/trucks made in the U.S.A. any longer! At least since Thunder Tigers aquisition of A/E. Even some of the items on Japanese R/C cars are made in Taiwan or China nowadays, since it's all about the profit in business. If the market value for an item is $500 and you can make it in the U.S. for $430 or make it in China for $81 it doesn't take a rocket scientist to figure out what will happen.
Of course we don't hold China/Taiwan/India and similar countries to the same standards we empose on our own manufacturers.
Labor Laws
Human Rights
Enviornmental regulation
Taxation
Property values
Unions
Annual cost of living raises
Kind of tips the scales....Yet, some want to impose more rules and regs in our own borders, while they shop at Wal-Mart for overseas merchandise.
ODD, unless damaging our long term soverinty was the goal?
Sorry for the long post, got rolling, .
...Jim
W.E.D.
i thought XFACTORY was
pink_sleeve is offline   Reply With Quote
Old 12-21-2007, 05:42 PM   #5777
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by satoch View Post
I already solved the ackerman slop problem.
1)Drill the ackerman holes to 1/4" and then press in sleeve bearings:
From McMaster-Carr: SAE 841 Bronze sleeve bearings p/n 6391K113
2)Then drill those out to 5/32"
3)Next insert new shoulder screws: McMaster-Carr: p/n 93985A524
Put a drop of after run oil on and you're done.
Ok, I just did this mod, except I couldn't find the McMaster-Carr parts... I just got some equivilant bushings/bearings. 1/4" OD, 1/8" ID, 1/8" long or "thick."
I altered the process SLIGHTLY.
1) I dremeled the flat spots out of the holes first, to help keep the drill bit from "walking" off-center.
2) Then I drilled the 1/4" holes.
3) Tapped in the bearings with a hammer. NOTE: 1/8" bearings are slightly "longer" than the thickness of the ackerman... this comes in handy, as I will explain in a moment.
4) Drilled the centers to 5/32. One of them "spun" in the ackerman, so I clamped a set of "Vise Grips" on it, and drilled.
5) Since I didn't like the fact that the fit was loose enough for the drill bit to spin it, I gave that a little thought... hmmm... I decided to "compress" the bushings with the vise grips to expand them in the holes in the ackerman for a tighter fit. Works like a champ! Drilled to 5/32" and installed. Now I have nice, tight fitting bushings that are flush with the ackerman plate on top and bottom.
6) Installed the bolts and put a drop of after-run oil. Nice, tight steering and no binding. Great!
We'll see how long it holds up in race use.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-21-2007, 09:16 PM   #5778
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Pink_sleeve, haha, some of their car is, the Associated and TL parts they buy to complete their "conversions" are from the same source as A/E and TL, China, or Taiwan.
Doesn't make anyone bad, just business.
...Jim
W.E.D.
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 12-21-2007, 11:59 PM   #5779
What do you think about this?? I just got an 8ight, are there any problems with the diffs that this might solve?
http://www.neobuggy.net/modules/newb...#forumpost9143
JimmyL is offline   Reply With Quote
Old 12-22-2007, 12:02 AM   #5780
tex1's Avatar
Send a message via Yahoo to tex1
Actually....LOL......
Associated/Thunder Tiger is from China.
Losi/Sprotworks is from Taiwan.
I think the reason the X cars cost as much as they do is the shipping those guys must pay to get the parts to make them run.
Being honest with customs......Priceless!
TEX
Good point Jim.
tex1 is offline   Reply With Quote
Old 12-22-2007, 12:08 AM   #5781
tex1's Avatar
Thumbs down
I'm calling shens on that mod!
The problem they are showing the picture of is because the cup rotated in the housing, not because it didn't. They had something hold up the driveline elsewhere to cause that.
Wow!
TEX
Old 12-22-2007, 12:10 AM   #5782
freefallmarine's Avatar
Shananagins!!!!! hahaha.... Happy Holiday's Tex ol' buddy!!!
What if the Hokey Pokey is, what it's all about?
freefallmarine is offline   Reply With Quote
Old 12-22-2007, 09:32 AM   #5783
Geo Y-Rock's Avatar
I'm a machinist and I think that looks cool. But in my opinion, you just have to maintain your stuff and problems in this area won't occur. Even with this mod, you will still need to maintain your diffs. One thing I see as a problem is now he's created larger openings for dirt and dust to get in to the modified area. The radius of each roll pin creates a gap. The stock design is better for keeping dirt out. Bottom line...Clean your diffs every now and then. My 2 cents
Sponsored by: Team Losi ~ Nitrotane ~ Spektrum Radios ~ GRP Engines ~ Upgrade/Rc Id ~
I got 99 problems, but a b!#ch ain't one!
Geo Y-Rock is offline   Reply With Quote
Old 12-22-2007, 01:58 PM   #5784
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
Originally Posted by buckeye-mac View Post
I did take it apart, the gears looked fine. I have been told they just need to break in a little for the first few tanks
Is it the rear gearbox or front gearbox that feels tight? With metal gears there should be no need to break them in, they should have the perfect mesh from the get go, try loosening the screws on the gearbox cases off 1/2 turn and see it it helps, i had a bit of trouble with the rear bearing inserts seating properly, the alluminum ones fixed the problem and the car has perfect smooth gear mesh everywhere before i even cranked the engine over.
NJA82 is offline   Reply With Quote
Old 12-22-2007, 08:30 PM   #5785
...Jim
W.E.D.
just curious. where is Kyosho and Academy made
Old 12-23-2007, 04:56 PM   #5786
Pink_sleeve, to tell the truth, i'm not positive, but from friends in the industry I know the Kyosho stuff is "Mostly" made in Japan and the Academy is "Mostly" made in Taiwan.
I would assume some of those companies items may also be made in China, Indonesia, etc. as others are doing, to help shave costs/increase profit.
I even noticed in the Harley Davidson stores that they have alot of "Chrome Goodies" made in China, or similar countries. LOL
The way of the world I suppose, only consumers can determine if it is the way to go, since we are all so cost concious. I guess this is how it is accomplished.
...Jim
W.E.D.
Old 12-24-2007, 10:19 AM   #5787
Hi, i have just built my losi 8ight and set it up on adam drakes set up for rough tracks. i set the droop as he recomends, by measuring the shocks. the front seems fine , but he says the rear shock length is 106mm. with this setting, it seems the car has little or no rear droop. surely this cant be correct? am i missing something here, or is that actually how he runs it?
thanks.
watty is offline   Reply With Quote
Old 12-24-2007, 10:56 AM   #5788
MikeFriery's Avatar
Trader Rating: 19 (100%+)
thats how most people run it.. measuring from the center of the screw and the shock mount
MikeFriery is offline   Reply With Quote
Old 12-24-2007, 12:52 PM   #5789
Ah, you measure from the center of the screw - center of shock mount. that will make a difference. i measured total shock length.
Old 12-24-2007, 02:49 PM   #5790
tex1's Avatar
Thumbs up
Yeah... measure from the center of the top screw to the center of the bottom screw to get your measurements. It is different if you have differing shock locations from the one he is calling for.
I find that 108mm is the good setting for me on the low side with 110mm being the high side figure.
Rear droop makes a bif difference in this car.
Shins CARL! That is what that was!
HAPPY HOLIDAYS!
See you in Jan for the Ice Breaker??
TEX
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
