Old 12-11-2007, 06:11 AM   #5716
Originally Posted by RETRO RC View Post
the radio trays are the same but you'll have to reset the end pionts and trim settings from one vehicle to the other everytime you change it over
Adrian
Originally Posted by lanerbrainer205 View Post
Yep I bought the integy alum. steering components, put in brass bushings or w/e on the ackerman and where the four other bearings go on the steering rack. Now I have no slop at all.
I wonder if by doing this mod, basically adding front end weight changes the way it handles. Does it?
cota348 is offline   Reply With Quote
Old 12-11-2007, 06:46 PM   #5717
RETRO RC's Avatar
TBO I don't think there would be enough of a weight change to make a difference.... but I've been wrong before
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 12-11-2007, 06:53 PM   #5718
air8's Avatar
It will change but not much. And it shouldn't affect ride height. The losi buggy is sensitive to ride height changes, so keep track of that and you should be fine. I'd be worried about the extra weight making the rear loose. I haven't used them, so I also am not exactly sure.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-11-2007, 07:09 PM   #5719
RETRO RC's Avatar
hey Air8
here's a link to our National champs web site for this weekend
http://www.hrccc.co.nz/2007_nationals.php
there is a live link on there so you can check out the racing as it happens, pics of the track etc etc
just to let you know we are a few hours ahead of you guys over here in New Zealand as it's 4PM on wenesday as i write this
Adrian
Old 12-12-2007, 02:35 AM   #5720
air8's Avatar
Retro, cool site. A few hours ahead??? More like 19 hours ahead. Right now this post is at 0430 AM here in Kansas, USA.
I like the switchback, and raised corners, and double-hairpins. Tracks like that give a great challenge and it's fun.
--"U Ain't Fast!!"
Chris Pearce
Old 12-12-2007, 07:15 AM   #5721
Here is a race, if you donīt mind to travel.
http://www.venezuela-rc.com/foro/viewtopic.php?t=3140
Check it out
Old 12-12-2007, 10:26 AM   #5722
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
how often do you guys change bearings and which ones? my el-8ight is getting kinda squeaky with a 2.5hp electric motor in it. i checked the diffs and the still hold up, so i think its a bearing problem.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 12-12-2007, 10:59 AM   #5723
Integra's Avatar
Avid bearings are my #1.....or Protec....or Boca even has a Buck a bearing deal for most sizes...and ill change out my bearings halfway through the season...sometimes sooner if something feels notchy or sqweeky....and at a 1$ a peice its a good idea.
Old 12-12-2007, 11:03 AM   #5724
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
most of the time a squeeky bearing is from the universals. but i normally change a bearing when i fell it get gritty.
micrors4guy is offline   Reply With Quote
Old 12-12-2007, 03:26 PM   #5725
this will fix the all the premature wear on the cvd's and bearings. I have been running them for some time.
http://techtalk.teamtrinity.com/tt/s...ad.php?t=13717
Chad Phillips is offline   Reply With Quote
Old 12-12-2007, 03:38 PM   #5726
Integra's Avatar
Where do u get em ?
Old 12-13-2007, 05:23 AM   #5727
They should be out by xmas. you can pre order them from Trinity. They are made out of harder steel as well. the only thing that will wear out i the bone itself and the pin that holds the bone in to place.
Old 12-13-2007, 10:27 AM   #5728
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Will they only be standard length or the 2mm longer ones? I have the extended ones on my car.
Now we need a fix for the center diff case wear.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-13-2007, 01:43 PM   #5729
working on rear coupler that is 3mm longer so the bone sits deeper in the center diff outdrive. and we have this....
TRI43104 Losi rear hardened hinge pins - new rear hinge pins that are stronger than stock hinge pins. Last 10 times longer than stock pieces. Consumers will be able to purchase these in shops for around 13 dollars
Old 12-13-2007, 02:46 PM   #5730
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
The center diff is the same as the front and back as well. I have problems with all 3 wearing fast, like I said earlier. I don't mind too much, as the parts are cheap, but still I am not a fan of spending a small fortune on one part.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
