Old 12-04-2007, 08:26 PM   #5686
cornerspeed's Avatar
I have got about 3 gallons on the Losi Carbons with Gold springs. They still were not worn and the size was about the same as new shoes.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-04-2007, 10:52 PM   #5687
air8's Avatar
That's awesome!! I'd be happy with one gallon like Jon. I have only used 4 KH 7075. I was going to see how I liked the 4 carbons soon. I'm glad to hear they don't go out after a few qualifiers.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-05-2007, 06:45 AM   #5688
I'm planning on getting an Eight and had a couple of questions:
Is there any talk of a new version being released in the next couple of months - an Adam Drake edition, for example? I'm wondering if it's worth waiting a while as I won't be running it until the spring.
Also, what are the most common screw sizes. It looks like 3/32 and 5/64. I ask because I'll need some new standard size hex drivers.
Thanks.
Helios/KO 2.4
Mugen MTX-4 // Losi 8B // AE B44 // Mini-Z 2.4 // Axial AX10
jon123 is offline   Reply With Quote
Old 12-05-2007, 07:26 AM   #5689
Integra's Avatar
Thanks.
I doubt there will be a "Drake" version out at all...seeing as adam runs Very little as for Hop-ups...and its basically a Team truck outta the box....If u check any of the losi set-up's...they dont derive from the box stock set-up very much....and for the Wrenches....get a nice 4 peice kit....Losi's driver kit is Real Nice...i use Integy and they have lasted me Multiple seasons.
Old 12-05-2007, 09:05 AM   #5690
Greg Etter's Avatar
Jon Kerr and Cornerspeed,
When you guys are talking about the "carbon" shoes those are the same as the "composite" ones that come in the kit right? Just making sure that there is not some updated set of shoes that losi has come out with. It's time to change my shoes.
Thanks....Greg
Greg Etter is offline   Reply With Quote
Old 12-05-2007, 10:31 AM   #5691
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
Greg they are the same shoes
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 12-05-2007, 05:24 PM   #5692
Thanks....Greg
Yes, the kit composite shoes. I really see them lasting for 5+ gallons. The springs, uh, I don't know. But the shoes I have been running have the same springs for a long time. They don't even mushroom out.
Donny Vinkemulder
TLR Driver
Old 12-05-2007, 06:13 PM   #5693
air8's Avatar
Thanks.
I highly recommend checking into the Bullit wrenches. They are so bad a**. It's worth it to get a good set of wrenches for working on 8th scale stuff. These bullit wrenches can be used in a hand held cordless 1/4" driver for faster teardowns. I'm the only one around locally to have them but at least one to two people use them every weekend. Just look into them. See what you think.
--"U Ain't Fast!!"
Chris Pearce
Old 12-06-2007, 09:14 PM   #5694
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Just aquired a used losi 8ight and im just wondering what the width of the losi front arms should be (Losi 8ight Buggy). What i mean is how many mm are the arms length sideways where it slides onto the hingepin, because the arms seem to be floating on the hingepin a fair bit with 1 side alot worse than the other which leads me to believe that possibly the arms plastic has compressed. Is this a common problem? Can you shim them so the arms sit tight on the hingepin.
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 12-06-2007, 09:57 PM   #5695
air8's Avatar
I'd say just make sure the holes in the arms, the hinge pins, and the F/R hinge pin holders are clean. That will do a lot for you to start with, having the arms move freely. But if the arms are warped, then maybe check into a new set. I don't know the measurements, sorry. I'm not to that level of skill yet. LOOOONG way to go yet.
--"U Ain't Fast!!"
Chris Pearce
Old 12-06-2007, 10:02 PM   #5696
rcstunt101's Avatar
i cant see how the holders are going to affect it as the arms seem 3 or so mm's short to fill the space on the hingepin
Associated TC5R
Associated B4
Yokomo B-max4
Old 12-06-2007, 11:55 PM   #5697
air8's Avatar
I'm just suggesting to have a clean and free suspension. No binding. That should be the only worry. If you feel the excess play is too much, try to take one of the arms to a LHS and compare them. Replace if necessary. Other than that, I don't know what to suggest. Sorry.
--"U Ain't Fast!!"
Chris Pearce
Old 12-07-2007, 01:27 AM   #5698
freefallmarine's Avatar
Anyone try the trinity rear hub's?
What if the Hokey Pokey is, what it's all about?
freefallmarine is offline   Reply With Quote
Old 12-07-2007, 03:13 AM   #5699
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
Rcstunt101: If there is excessive play on one side, just use some thin 3/16" axle shims from a Losi or any other brand shim kit you can buy and simply shim them until there is no play, this is common practice and i do it with all my cars, its cheaper than replacing the arms all the time, that sort of wear is very common in off road and is normal.
NJA82 is offline   Reply With Quote
Old 12-07-2007, 03:37 PM   #5700
i have a XXXCR for sale with the orion 4800mah and the novak 3.5 brushless system and a 7.5 extra motor and a bunch of extra parts. you can e-mail me at fastaschvy@yahoo.com for more info and a price.
Fastaschvy is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
