Old 11-22-2007, 09:49 AM   #5626
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Originally Posted by Jon Kerr View Post
Fiberglass discs are easy to keep like new. When they glaze over, just take some 600 grit wet dry sand paper, spray some motor spray on it, and rub away until the paper is dry. This gets rid of any glazing but doesn't take off much material. You will want to double check your pad setting just in case though. I needed to tighten up just a touch once after 5 or 6 times.
This is what I do and works great .
Briguy is offline   Reply With Quote
Old 11-22-2007, 10:40 AM   #5627
Trader Rating: 39 (100%+)
I haven't had much luck with my stock brake disks...they disintegrated after a few gallon. I installed Avid disks and they have been working awesome and brake fade is minimal.
ridgewaybodies is offline   Reply With Quote
Old 11-22-2007, 11:18 AM   #5628
air8's Avatar
What do you mean they disintegrated? Like, they fell apart? Or crumbled/flaked apart?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-22-2007, 12:45 PM   #5629
i'm looking for tips as to remove the flywheel from the engine i have the nut removed and the the flywheel still aint budging any help is appreciated
vroom88 is offline   Reply With Quote
Old 11-22-2007, 01:20 PM   #5630
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
use a screwdriver and pop it off
pink_sleeve is offline   Reply With Quote
Old 11-22-2007, 01:24 PM   #5631
cornerspeed's Avatar
Pictured is a Craftsman generic puller. It works fine for me. There are also 1 or 2 other RC companies that make/sell specific pullers for flywheels. I know you can see them on A-Mainhobbies.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-22-2007, 05:21 PM   #5632
The fiberglass layers flaked apart. If I still have them, i'll take a picture of them. Can't remember off hand if both did or not.
Old 11-22-2007, 05:22 PM   #5633
Head down to your local AutoZone or Pepboys and ask for a battery terminal puller. They are like $5.
Old 11-22-2007, 06:03 PM   #5634
Stock Losi brake disks after like 4 gallon...
Old 11-22-2007, 07:46 PM   #5635
RETRO RC's Avatar
damn and I thought mine where bad!
thanks for the imput guys hopefully get it sorted as we've got the National champs overhere in 4weeks time
thanks Adrian
RETRO RC is offline   Reply With Quote
Old 11-22-2007, 09:21 PM   #5636
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
Default shims
I have a race this weekend and while putting in new clutch bearings i missed placed the shim that goes agianst the clutch nut and the rear clutch bell bearing.....will the bearings last thru the weekend without it?
jbmccoy205 is offline   Reply With Quote
Old 11-22-2007, 10:07 PM   #5637
air8's Avatar
FIND THAT SHIM!! J/K. Make sure that the CB is not rubbing on the flywheel. Make sure the gear mesh is set well. As long as these are set correctly, you should be ok. Also make sure the CB and the spur gear are aligned as well as you can.
--"U Ain't Fast!!"
Chris Pearce
Old 11-28-2007, 12:44 AM   #5638
jbmccoy205's Avatar
Will the extra 2mm on the hex bolts for the wheels make that much difference in the handeling of the car? I m sure its been covered on here but dont have time to search it......thanks
Old 11-28-2007, 01:11 AM   #5639
air8's Avatar
Are you referring to the extended hexes? It will make a difference but ends up coming down to how you prefer the buggy to handle. Some people use them and some don't. If you're interested, try them and report back. From what I've heard it takes away some steering and edginess, making for more stability on rough tracks.
--"U Ain't Fast!!"
Chris Pearce
Old 11-28-2007, 03:34 AM   #5640
freefallmarine's Avatar
I use the mugen 2mm wheel hex's. I calms the car down when the traction is low. When its sticky though, and the car is tight, ill switch back to the stock losi hex's to get the steering back.
What if the Hokey Pokey is, what it's all about?
freefallmarine is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
