Old 11-12-2007, 02:26 PM   #5596
mremtr's Avatar
Dayton , the car should be dialed right out of the box. You might need to adjust droop and ride hight for that track, try the shocks as they are first, then if you find you need something different have at it , but I bet it goes really good right off, just change the tires, those CF's are for a wicked abrasive surface. Good luck
mremtr is offline   Reply With Quote
Old 11-12-2007, 04:23 PM   #5597
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Thanks mremtr,I can't wait til it gets here.
Rex it's a shame you guys can't make it, but I know where you will be
I have a couple friends Headed up for that race.My car should be here thursday,I'm going from the Jammin to this car so I think I'll like it.
Bruce, I'll see you at the track.lol
later
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-13-2007, 10:38 AM   #5598
Race-Wright's Avatar
Well Bruce it looks like you just went from the C main to the D main.
Race-Wright is offline   Reply With Quote
Old 11-13-2007, 11:03 AM   #5599
LOL! One bad day of qualifying and they never let you live it down.....
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 11-14-2007, 07:49 AM   #5600
1armed1's Avatar
Bruce the C at a clube race?
I know in the winter the comp is very brutal there.
The only time I went up last winter for nitro I was on an A main run each qualifier but small mistakes would blow it for me.
I qualified 7th in the B, my time was only 1.2 seconds off from the 5th qualifier in the A.
If I remember right, 5th in the A through 9th in the B all qualified within 1.5 seconds, now that's some good racin.
I think there was close to 60 buggies that day.
later
Dayton
Old 11-14-2007, 06:43 PM   #5601
tdeal823's Avatar
Trader Rating: 30 (100%+)
I just got my hands on a new Race Roller. I was thinking of running it box stock for the frst run of the day minus some tire droop and ride height changes.
Does any of you guys know the Shock setup(pistons,oil) and diff oils of the race roller?
Thanks guys I for the info. I just wanted to try it that way before I changed to something different.
tdeal823 is offline   Reply With Quote
Old 11-14-2007, 06:53 PM   #5602
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
look in the back of the manual it should have the set up in there.
micrors4guy is offline   Reply With Quote
Old 11-14-2007, 07:18 PM   #5603
tdeal823's Avatar
Right is the "Standard Setup" what the race roller is???
Old 11-14-2007, 07:20 PM   #5604
i beleve the only difference is the diff oils. and i think the race rolder is at 563?
Old 11-14-2007, 07:33 PM   #5605
air8's Avatar
Shocks=Front-RR(Race Roller) has 56p and 40wt oil. Rear-RR has 56p and 25wt oil. RR diffs come with 3,5,2.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-14-2007, 07:34 PM   #5606
tdeal823's Avatar
thanks thats what I wanted. That way I can document things.
Old 11-14-2007, 07:46 PM   #5607
air8's Avatar
Sure. But isn't this in the manual? Losi is pretty awesome when it comes to this part of the manual. Or were you just wanting to know the difference from the original kit?
--"U Ain't Fast!!"
Chris Pearce
Old 11-15-2007, 03:02 PM   #5608
tdeal823's Avatar
I bought one of each a pro kit for parts and a race roller for this coming weekend. I just was wondering if the setup sheet that came with my race roller was accurate to the car. The camber, caster and toe are all close to the RR setup sheet I just wanted some reassurance as to what the oils were. That way I knew what to start changing IF I wanted the car to react differently I will be on a indoor high traction techinal track.
thanks again
Old 11-15-2007, 03:59 PM   #5609
mremtr's Avatar
1armed1, I forgot to tell you that the engine mounting holes are retapped for the 4 metric screws that are in the bag , they should work fine for you ,as they fit the engine holes better Hope it is what you expected ? good luck
Old 11-16-2007, 03:51 AM   #5610
Unhappy Overall Shock lengths When building?
Does anyone know how far in the shock shaft should be screwed into the shock bottom as i have screwed mine in so that it just covers the threads and the shock piston is level with the top of the inside of the shock.
However this means that the piston pushes on the bladder inside when at full compression. Is this right as when i screw the shafts in further i can't get enough shock length for the droop settings. The manual does not really say where everthing should end up of overall lengths etc.
Any help appreciated as i can getting p*ssed off trying to set my rebound
losi8lunie is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
