Old 11-06-2007, 07:14 PM   #5581
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
But after 9+ gallons it was more than bowed, as the caster was also dramatically changed. The inner and outer hinge pins were no longer parallel or on the same plane.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-06-2007, 07:40 PM   #5582
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Sloppy and damaged, equals bad.
Broken in and free, equals good.
I always run my cars a couple of weekends at club races when they are new, before a bigger event, since they always seem better after half a gallon or so, then a diff oil and shock oil change and we're off!!!
...Jim
W.E.D.
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 11-06-2007, 08:37 PM   #5583
I tried 2 ways to get rid of steering slop to see which is best.I turned brass bushes to fit in place of the steel ones and reamed out the other drag link and fitted 7x3mm bearings. both reduced the slop a lot,to almost nothing.I don't think bearings is the way to go,but the brass bushes seem last pretty good,much longer than the steelAlso replace the outer ball and ends with mugen ones they have less play. Fit a shim under the top bearing posts.
Mater is offline   Reply With Quote
Old 11-08-2007, 09:20 AM   #5584
RCTEN.'s Avatar
Trader Rating: 14 (100%+)
do you happen to have part#s for the mugen parts?
RCTEN. is offline   Reply With Quote
Old 11-09-2007, 04:25 PM   #5585
freefallmarine's Avatar
Man i think its time for me to retire my losi and get a new one...seasons over..
What if the Hokey Pokey is, what it's all about?
freefallmarine is offline   Reply With Quote
Old 11-09-2007, 08:18 PM   #5586
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i rebuilt mine for about 200$ with finding stuff on ebay and bmain. that was a complete rebuild. chassis and all plastics. add another 80$ for shocks
micrors4guy is offline   Reply With Quote
Old 11-11-2007, 08:59 AM   #5587
air8's Avatar
I believe the one I have now will go electric cause it's trashed. Since the truggy roller was a success for me I'll do the same with the buggy. Sucks that you still have to tear them down so much to assure they're built right. But that's what makes for a happy bond between car and driver right? LOL.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-11-2007, 10:01 AM   #5588
I figure ill sell my current chasis for like $250 buck's so someone could get into the hobby cheap. And just put another $250 into it for a new kit. Win, Win situation i guess.
Old 11-11-2007, 10:05 AM   #5589
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Thumbs up
When you do the convertion to your buggy, can you post the parts you had to purchase and total cost of doing it. I might want to do the same later on (for fun) and also get another 1/8 buggy and transfer the nitro engine to that. I'll have the best of both worlds for my buggies (nitro and electric!).
Later and advance thanks.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-11-2007, 10:37 AM   #5590
air8's Avatar
Sure. No problem.
--"U Ain't Fast!!"
Chris Pearce
Old 11-12-2007, 08:30 AM   #5591
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Any one have a good indoor setup they would like to share?
Large track, layout usually flows very well, I think the straight is 125ft or just a little more.
Traction is usually mid to high grip.
DAyton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-12-2007, 09:40 AM   #5592
DAyton
I race at Leisure Hours indoor track which is 75' x 125' and a high bite early in the day then reduces to medium bite for the mains. It flows well also.
My set up is dialed for me:
Front:
Toe: 2 deg out
Ride Height: 25mm
Camber: -2 deg
Caster: 21 deg (I have the upgrade hinge pin holder)
Sway Bar: 2.3mm
Piston/oil: 55/40 wt. losi
Spring: Silver
Droop: 95mm
Ackerman: Long (going to try the short though)
Bump steer: down
Camber link: 2
Shock location: inside
Front Diff: 4k Mugen
RX battery: Losi lipo
Center diff: 7k Mugen
Rear Suspension:
Toe: 3 deg in
Anti-squat: 3 deg
Ride height: 29mm
Camber: -3 deg
Hub spacing: all the way forward
Sway bar: 2.3mm
Piston/oil: 55/30
Spring: silver
Droop: 107
Camber Link: 4/A
Shock location: Inside
Rear diff: 2k Mugen
Engine:
Go Tech 5 port, OS #8 plug, Sportwerks 053 pipe w/"U header"
Clutch:
Losi aluminums w/ 2 black and 2 gold
Tires:
Panther Switch 2.0 clay w/ Proline Grey molded foams
Notes: I also use custom made curved backwards mud flaps that really help with in flight handling and a bit more down force on the straights.
I also use the Losi 8T truggy servo saver spring-this really helped to prevent the tires from pulling to the center when getting on the throttle coming out of a turn when traction is high!
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 11-12-2007, 10:13 AM   #5593
1armed1's Avatar
Front:
Toe: 2 deg out
Ride Height: 25mm
Camber: -2 deg
Sway Bar: 2.3mm
Spring: Silver
Droop: 95mm
Bump steer: down
Camber link: 2
Rear Suspension:
Toe: 3 deg in
Anti-squat: 3 deg
Ride height: 29mm
Camber: -3 deg
Sway bar: 2.3mm
Piston/oil: 55/30
Spring: silver
Droop: 107
Camber Link: 4/A
Rear diff: 2k Mugen
Engine:
Clutch:
Tires:
HAha, that's the track I'm talking about.Thanks for the info.
Who are you?
Later
Dayton
Old 11-12-2007, 01:07 PM   #5594
Now I'm bummed I posted! Should've kept my mouth shut! The competition is brutal enough at LH and I know you're a good racer cuz I remember you now.
I take it all back, my buggy was sliding all over, turned like crap and slapping ass on all of the jumps. Nose high too! LOL!!!!
Bruce Edwards
Bruce Edwards
Thanks to:
Old 11-12-2007, 02:06 PM   #5595
22Racer's Avatar
Trader Rating: 67 (100%+)
Dayton, did you just get an Eight or have you been racing one for a while? We are bummed we can't make it for the big race comming up.
Rex
22Racer is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Chad Millikan
