Old 11-01-2007, 06:02 AM   #5566
tex1's Avatar
Send a message via Yahoo to tex1
Wink Buggy body fit.
The hole thing comes from the body riding to snug to frame. All of them seem to do it. I took a 3mm spacer and glued it under my front body mount post to raise it slightly. It works much better now. Linkages do not hit and the nose of the bodies fit better. It also provides some relief from your pipe catching the body with the air fitting.
All around it is a much better fit than the stock placement.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 11-01-2007, 09:25 AM   #5567
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
J Concepts. Hands down it fits tighter than the rest, and helps keep dirt out from the front and sides. I have been running the same body since february and it is just starting to crack in a couple of places. I use shoe goo all around the bottom, around the body mounts, and I watch for where the body makes contact with anything else after the first few uses, and smear shoe goo over those too. The body is very strong.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 11-01-2007, 09:46 AM   #5568
Kcdzim's Avatar
Send a message via AIM to Kcdzim
Originally Posted by T Green View Post
from what i have seen the proline crowd pleazer has an issue with the throttle/brake linkage rubbing the body.
It's true that the CP rides lower through the servo brace and kicks up at the batt box, but it's not too much more than the losi body or the jconcepts.
However, if you use JR servos, you'll notice it bigtime, because JR mounting eyelets are a good 2 mm lower on the servo case, setting the throttle linkage that much higher (possibly higher still if there is an angle up from the carb).
I'm now running a futaba throttle servo and it fits cleanly underneath with minimal rubbing.
I still prefer the proline body over the JConcepts based on looks, but I dont think either has any particular advantage over the other and I've seen both run and mounted. There isn't a significant difference in how much dirt you get in there, in my opinion, as the mounting tolerances are pretty much identical. The Losi body absolutely has the shortest lifespan though.
Kcdzim is offline   Reply With Quote
Old 11-01-2007, 04:16 PM   #5569
Originally Posted by NJA82 View Post
Definately!! When are they going to come out with some alluminum bellcranks that run proper ball bearings on the drag link, instead of those crap sloppy bushings... I have seen an upgraded drag link for sale on A main hobbies site but it doesnt look a whole lot better.
Kingheadz came out with an ackerman/drag link for the Jammin' buggy that used a flanged bearing but the bearings failed if I'm not mistaken. The bearings couldn't handle the axial load and would fall apart.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 11-05-2007, 10:02 AM   #5570
air8's Avatar
How is the race roller setup compared to the kit set up? Is there a lot of difference in the way it drives? I'm thinking next year I might start with the roller and see how things go. My truggy has done very well so I'm not too scared to try the B-roller.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-05-2007, 04:34 PM   #5571
RETRO RC's Avatar
hey Air8,
as I understand it the race roller and the kit are identical except for
1. the tyres supplied and colour of the rims
2. the race roller comes pre assembled
3. price the roller is dearer because it comes pre assembled
so if youv'e got the time I would suggest the kit
hope this helps
Adrian
someone might know of other differences also
RETRO RC is offline   Reply With Quote
Old 11-05-2007, 05:47 PM   #5572
Suspended
Send a message via AIM to Nay0k
Originally Posted by o.s. power View Post
Who's the retard now?
You are still, because you're telling me to replace something that isn't needed to be replaced yet when other things that should be spent, could be replaced.
Oh, and 9 out of 10? Looks like the 1 came up for me.
Nay0k is offline   Reply With Quote
Old 11-05-2007, 07:40 PM   #5573
air8's Avatar
Thank you. I meant to say the suspension set up difference. I think the 8 I have now is going to be electric for the winter. It's actually an excuse to buy a new buggy. LOL! So is the race roller set up a lot different, or a little bit different?
--"U Ain't Fast!!"
Chris Pearce
Old 11-05-2007, 09:10 PM   #5574
RETRO RC's Avatar
I don't know about the factory set up on the RR but you can set it up to anything you wan't just as you can with the kit because they are the same chassis
so if you like the set up you have on your current 8 just right it down and make the changes to the new car when it arrives
Adrian
Old 11-06-2007, 02:00 PM   #5575
tonyy's Avatar
Send a message via AIM to tonyy
Originally Posted by ridgewaybodies View Post
I've heard of others using Kyosho rod ends and balls to tighten up the steering and provide longevity. Not sure of the part numbers though.
i did that tomy car works good try it!
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
www.paintmonsterairbrushing.com
tonyy is offline   Reply With Quote
Old 11-06-2007, 04:53 PM   #5576
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
the car handels just fine with the slop in it
micrors4guy is offline   Reply With Quote
Old 11-06-2007, 05:00 PM   #5577
tonyy's Avatar
thats what iam talking about:
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
Old 11-06-2007, 06:32 PM   #5578
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Most cars usually handle better with a little (not excessive) slop in it. Too little and the car will be very unforgiving. We even build a little slop into on road cars so they're not so overly sensitive to imperfections in the track surface.
Jon Kerr is offline   Reply With Quote
Old 11-06-2007, 06:42 PM   #5579
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
I agree with the above statement, but there is a time when slop should be removed by replacing rod ends, hubs etc. In hindsight, I should have sold my 8 and bought a new one, as I have just spent a little over $500 recently replacing almost every part. At least it was fun! Mine was bad...there was no need for a digital servo or even a high dollar steering servo: I had about 10 of slop or more. It was at the point that there was no use trying to setup a precise trim. My A arms were actually bowed
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-06-2007, 06:44 PM   #5580
the new arms accually bow after little use. the older ones lasted longer.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
