Old 10-23-2007, 08:17 AM   #5461
sport10's Avatar
Originally Posted by rfy View Post
Hi all,
Has anyone made a reverse thread shock bolt/screw..need for the front right and rear left shock..these have a tendency to back off/out half way into a one hour main. thanks
On the bottom of the front and rear a-arms is a small hole for a set screw to lock in the lower shock screws. Just add the right size set screw and you are set.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-23-2007, 12:20 PM   #5462
bloodrush's Avatar
Originally Posted by Briguy View Post
What is your "budget" ? Prices can range depending on what each persons term of budget is .
about $100 for 2 in or in about 50 for 2 servos cant aford much more at the mo saying that though i have had the spektrum z270 and z590 since new about 10 months with no problems ,until a told a mate at the track that i had had them that long and halfway round the next lad my steering died then this week the other one died lol me and my big mouth
bloodrush is offline   Reply With Quote
Old 10-23-2007, 02:02 PM   #5463
Trader Rating: 37 (100%+)
Losi 8ight RTR Question.
Do you still have to do that o-ring or some kind of mod to stop from damaging servos?
Other then replacing the steering servo how reliable is the buggy? I plan to do occasional racing otherwise just messing around with it...aka bashing :P
How well does the roto start thing work in firing up the buggy?
Nexus is offline   Reply With Quote
Old 10-23-2007, 02:04 PM   #5464
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
does anyone know the internal gear ratio of the 8ight? im converting mine electric and need some help in choosing a pinion.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 10-23-2007, 02:06 PM   #5465
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I believe the O-ring deal was for the truggy . If the servo and linkage is set correctly you shouldn`t have any servo problems . I`m running the same servos and been over a year .
Briguy is offline   Reply With Quote
Old 10-23-2007, 02:17 PM   #5466
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
I've been running the orings under the radio tray still with zero issues. I just do it as a precautionary measure.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 10-23-2007, 05:00 PM   #5467
johnkemp's Avatar
hi i am about to order my losi eight i was wondering what parts people are breaking so i can keep a few spare and when buliding it if theres any thing i should do thats not said in the manual thanks
johnkemp is offline   Reply With Quote
Old 10-23-2007, 06:00 PM   #5468
brad996's Avatar
hey guys I was woundering if you all have alot of play in your diff and what you have done to stop it or is it normal
brad996 is offline   Reply With Quote
Old 10-23-2007, 10:08 PM   #5469
air8's Avatar
The diff ratio is 3.30:1 The ring gear is 43T and the pinion is 13T.
Johnkemp--set the EPA correctly. That's about all you need to worry about. Add some heatshrink to the front and rear CVDs.
brad996--if you feel the play is excessive try some shims. Are you checking this backlash with diff fluid in, or is it dry? I've not heard of too many people having diff problems. Actually I have about 12 gallons on mine and they seem ok. But if they ever blow up then I'll know. lol. Original gears, cases, ring, pinion. New seals every now and then though.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-24-2007, 04:44 AM   #5470
The play you're seeing might be due to wear/slop that tends to develop between the diff-carrier bearings and the diff-housing (I think it's only a problem in the rear?)
Losi makes aluminum parts to go there now, which I think are a worthwhile upgrade. LOSA4430.
Walt is offline   Reply With Quote
Old 10-24-2007, 06:06 AM   #5471
Originally Posted by Merciless View Post
Hey stay away from the Team Magic X5 Turbo II worst product I've ever had the misfortune of purchasing. On mine the belts striped there teeth twice then i put in a COMPLETE new internals package and it done it again (to be fair all replacement parts were supplied by TM free).
At this point i decieded not to use it again, REMOVED the motors, installed them in my old mugen box. I now have a box that'll turn anything over fast enough and with enough torque to RACE with
I'm sorry but I never had a problem with TM X5 turbo.
Break in and 1 one year of running.
The belts are still in like new shape.
Nicolas
kawaz is offline   Reply With Quote
Old 10-24-2007, 06:09 AM   #5472
Hello,
Have you any news about the new rear hub carriers from trinity for le losi 8ight ?
They should be in store now...
Thanks, nicolas
Old 10-24-2007, 07:42 AM   #5473
Kawaz- The trinity aluminum hubs for the 8T and 8B should be shipping to distributors now.
Old 10-24-2007, 07:45 AM   #5474
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
yay. cause i tried to pre order them and it was a 5-$ min order and i didnt want anything else
micrors4guy is offline   Reply With Quote
Old 10-24-2007, 06:56 PM   #5475
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
Whats up guys?
Just getting back from a 2 year break. Was running the 777 before, but just took the plunge on the Losi 8. Local track owner had one back then and I had a chance to drive it abit. It felt killer back then...so that was enough for me to buy one hehehee.
I know there is a ton of useful information through out this entire thread...but is there a condensed version someone could fill me in on?
thanks again guys!!!
supralative is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
