Old 10-12-2007, 09:39 PM   #5326
RcOneNitro's Avatar
Trader Rating: 61 (98%+)
Default Need some advise on setup...
Motor:
O.S. Speed 21VZ-B V-Spec Speed Competition Engine with Magnesium Head
or
Ninja MR21 B01A 5 port Competition Engine
Pipe:
OFNA Jammin JP-3 Hard Anodized Off Road Tuned Pipe
or
TSAIS Hard-Anodized 1/8 Off-Road Competition Pipe
Which engine is easier to tune? I heard that you have to use a heat gun to turn over the Ninja. Any advise would be great...
RcOneNitro is offline   Reply With Quote
Old 10-12-2007, 10:48 PM   #5327
V-Spec speed and a 2050 pipe.
Dave.H is offline   Reply With Quote
Old 10-12-2007, 11:38 PM   #5328
cornerspeed's Avatar
Speed and 2050 or 2060. Extremely easy to tune. Just don't lean out the bottom too much.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-13-2007, 12:14 AM   #5329
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
Speed V-spec with a 2060 it is a monster and super easy to tune.
DO NOT get the magnesium head its crap and does not work,get an aftermarket head or the new speed aluminium head.
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 10-13-2007, 12:16 AM   #5330
I forgot to add that most engines need to be heated up , And all engines SHOULD be heated up during break in.It makes the rods life much easyer and keeps your frustration to a mimimum lol
Old 10-13-2007, 08:43 AM   #5331
sport10's Avatar
[QUOTE=bohdi;3760839]
Originally Posted by buckeye-mac View Post
whats up with the losi starterbox's, are they that bad. Stores are practically giving them away.
i have the same question! I just got one and I have to do numerous things just to get it to work with my buggy. I have the 8 RTR. here is what Losi tells me I have to do before it will work and maybe some one can help me with this.
1. cut the chassis?? read an earlier post on shaving the starter wheel-SOLVED!
2. buy new motor mounts (Losi A9154) to lower the motor (stock Mach 427) so the flywheel is lowered. The problem I see here is that the motor has the spin start backplate and this will physically not fit. Can I just remove the spin start backplate or do I need to put a new backplate on? Is there a fix?
Do I need to get a new motor? I'd rather sell the brand new Starter box.
Please help!
You can either get a motor designed for starting on a starter box or convert the 427 by adding the optional backplate. I sold my 427 and got a .21 (much better mileage).
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-13-2007, 08:45 AM   #5332
I second this statement.
Donny Vinkemulder
TLR Driver
Old 10-13-2007, 01:21 PM   #5333
RcOneNitro's Avatar
Thanks for the feedback...
I bought the OS engine (NIB) and used JP-3 to run in my 8B. Plus I just bought a 8B with a (NIB) Ninja .21 and used Tsais pipe from a friend that needed the money.
I guess I will run the OS engine and JP-3 for now. If anyone has a 2050 or 2060 for .21 let me know how much you want for it.
If anyone is interested I will sell:
Ninja MR21 B01A 5 port Competition Engine -- NIB
TSAIS Hard-Anodized 1/8 Off-Road Competition Pipe -- Slightly used
Losi 8ight Pro w/ 2 sets of tires and clear body & painted body--NIB
Old 10-13-2007, 04:40 PM   #5334
[QUOTE=sport10;3761781]
Do you know which backplate to get? They all look the same size to me but th ebig issue is WHY would losi sell a starter box that you would need to modify in any way to work with their buggy?
bohdi is offline   Reply With Quote
Old 10-13-2007, 07:20 PM   #5335
Originally Posted by atown117 View Post
I'm getting a new buggy soon... So I was wondering if you guys could tell me the pro's and con's of the 8ight. Any help will be appreciated thanks.
Pros:
Fast, quick, jumps like a kangaroo on crack, is very precise..it CAN out handle about anything out there....tough as nails too (at least for me it was).
Setups - responds very well to adjustments
Cons:
Precise - it goes both ways...it can be squirrely to drive - you can make 3-4-5 great laps, then have 2-3 bad ones, and still think you are fast, but you look at the clock and you lost 2 seconds a lap. For a some people, it is a great buggy, and if you are a smooth driver, you should do well. if you like to nail it hard, slide into the corners and throw it around, it will not be the best bet for you imo.
Setup - very picky on setup (throttle especially). I did all the mods and spent HOURS setting up my EPA's, linkages, making sure I was parralel on the horizontal and vertical planes, etc, etc, and ran my 8ight for 7 months with no issues...I finally burnt out a throttle servo, but that was because the carb locked up - funny thing is this was my 3rd carb that locked up on this buggy....the throttle setup needs to be 100% exact for it to work correctly..I likely had it at 90% correct and thought it was good...my carbs tell me other wise (you can see scratches and gouges in the carb slide from it pulling against the idle screw)
Quality - mine was fine, but I am hearing of a rash of issues with diff cups, etc going bad in a 15 minute race..not sure if they did a bad run of plastics or what?
Good luck with whatever you decide!
gtsum is offline   Reply With Quote
Old 10-13-2007, 11:57 PM   #5336
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
What sort of brake bias are you guys setting up your 8 with? I tried several bias adjustments today and was hard to get it comfortable, it seems to really stand on its nose a lot like the front end is to soft even with less front bias it still dives under hard braking making it a bit taily in the rear end, i have the kit setup still atm, just starting to get myself familiar with this buggy.
NJA82 is offline   Reply With Quote
Old 10-14-2007, 01:03 AM   #5337
nitro rat's Avatar
Trader Rating: 5 (86%+)
Motor:
or
Pipe:
or
Motor:
BOSS Competition Engine
Pipe:
OFNA Jammin JP-3 Hard Anodized Off Road Tuned Pipe or LRP
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 10-14-2007, 09:24 AM   #5338
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
^^^The boss engine is the same as the Ninja, just a different cooling head. Same as the Falcon...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 10-14-2007, 11:53 AM   #5339
Registered User
Kendall Welch's Avatar
If I am on a bigger track where it is harder to see your car due to depth perception I usually run around 50/50 bias to calm the car coming in the turn. But if you are on a really small track with lots of 180 degree turns, then I run 30/70 to get around the tight turns better
Kendall Welch is offline   Reply With Quote
Old 10-15-2007, 05:52 AM   #5340
hey just though i would share a pic of my new body and my car after a rebuild before a state event this weekend.a local racer painted the body for me,he did a great job i reckon.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
