Old 10-08-2007, 06:31 PM   #5296
Originally Posted by J.Wright View Post
So what is the best li poly reg for my 8ight ? I am running the Losi li polys? and are you guys using one switch? I have seen a couple of guys 2 switches one switch for the reg and one for the batteries that looks like a drag.
Jim
I'm not going to claim it's the 'best', but I've run the Novak regulator for over a year now and it's worked fine. I like the switch Novak puts on it too. I don't think you can crash hard enough to get that switch to move on it's own.
I have no reason not to recommend it.
Mine is tucked into the receiver compartment along with the receiver. I'm not sure I'd put it there unless running a 2.4GHz receiver, as the regulator could cause interference on the 75 or 27 mHz frequencies if it was really close like that.
Walt is offline   Reply With Quote
Old 10-08-2007, 06:40 PM   #5297
air8's Avatar
Here's another. I've been using Protek 6.5v 5amp in my buggy and Muchmore 6.5 7amp in the truggy. I prefer the Protek because it is smaller than the Muchmore. I had to do some cramming to get the Muchmore to fit. On the truggy I moved the PT to the battery box and moved my on/off switch to a piece of lexan hung off the side of the electronics tray. This opened up the RX box a lot.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-08-2007, 07:21 PM   #5298
Registered User
Kendall Welch's Avatar
Originally Posted by vones View Post
1 Q's when you build the shocks do you make them to hve any rebound? If yes, how much 1/2 to 3/4?
Sorry for the late response, I usually have 1/3 rebound back.
Kendall Welch is offline   Reply With Quote
Old 10-08-2007, 07:36 PM   #5299
xlgraphicspro's Avatar
Originally Posted by lanerbrainer205 View Post
Hey everybody do yall think it would be possible for me to get my 8ight's chassis Linex'ed (spray on truck bed liner) and if so how long should it last? I have a REALLY local place here in Dalton, GA and I think I am gonna call up there today to ask their opinion... and price!
I understand trying to protect your chassis, but why coat the underside of your nice shinny beautiful aluminum chassis with a layer of lin-ex or Rhino-lining? That's like some one trying to protect the side of their new house by slapping molten Tar all over it. Plus it would almost double the weight of the chassis.
I have an easy solution for this, but I just haven't gotten off my A$$ to do something about it. I can take my chassis to work and vacuume form a lexan cover over the bottom of it. I can even make it to attach by the side chassis guard mounting holes.
Best thing, is you could cover up the hole under the spur gear and prevent little rocks from jamming into your spur, and potentially chunking out some teeth on your clutch bell. Oh yeah, you could even paint it to match your paint scheme.
I think I'll finally get off my A$$ and try it instead of just talking about it!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 10-09-2007, 10:30 AM   #5300
Please do! I would love to have one!!!! PM me when you get a few made please.
lanerbrainer205 is offline   Reply With Quote
Old 10-09-2007, 10:42 AM   #5301
jimbal's Avatar
Wow make me one too and some spares. How much????
Team Associated SC10 4x4 | Losi 8ightB 2.0
E-Flite CX2 | E-Flite 120 SR
--Jim Balazic
jimbal is offline   Reply With Quote
Old 10-09-2007, 11:56 AM   #5302
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow
If you do make one successfully, count me in as well.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-09-2007, 01:17 PM   #5303
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Oh ya , I want one too!
Briguy is offline   Reply With Quote
Old 10-09-2007, 06:46 PM   #5304
Any one try these yet? Looks like the ticket for the 8T. The steering link seems to pop off fairly easy.
http://www.teamcrc.com/crc/modules.p...prodID=7718959
insideline is offline   Reply With Quote
Old 10-09-2007, 07:34 PM   #5305
Default lexan undertrays.
I'll see what I can do to get some made. Does anyone know where I can attain some Brand Name Lexan? I've tried the knock off stuff and haven't had much luck because it bubbles up yoo much. I have had sucess with a plastic called PETG. but it's not as flexable as lexan.
I'll do some prototyping here in the next week or so!
Old 10-09-2007, 08:25 PM   #5306
22Racer's Avatar
Trader Rating: 67 (100%+)
You can get lexan at www.mcmastercarr.com and many screws, body clips etc.
As for the Crc steering ends, I just use the ones that are for the inside with a 5-40 flat head.
Rex
22Racer is offline   Reply With Quote
Old 10-09-2007, 09:54 PM   #5307
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
Originally Posted by Brian Miskolczi View Post
Sensitive.
Ive been running the front camber link in the lower hole and it has worked out very well. Anyone who hasn't tryed it should try it out.
ANyone have a setup for there 8ight on a super high bite clay track?
My favorite is Front=54/40--silver spring--Middle on tower, inside on arm, inside hole on tower for camber link, short ackerman plate
Rear=56/25 or 22.5---black springs---Middle on tower, inside on arm, inside hole on hub, outside hole on tower, hubs all the way back.
Diffs=3-5-1 or 4-7-2
Black is offline   Reply With Quote
Old 10-10-2007, 04:32 AM   #5308
Just picked up an 8ight, plan on running a M8 radio, and wanted to know what Airtronics servo's you guys recommend for this buggy? Trying to build up something that a month later I won't feel like I should have spent a little more on something better.
I am thinking 94758Z High Speed Digitals, but is there something that would be better suited for this application?
Torque: 115 oz-in
Speed: .06 sec/60 (torque and speed measured at 6V)
TIA.
rm25x is offline   Reply With Quote
Old 10-10-2007, 06:40 AM   #5309
tex1's Avatar
Send a message via Yahoo to tex1
Wink You might not want to do that......
Absolutely stay away from the Airtronics servos. They are very sub par to what you can get else where. If anyone debates this then I post some great pictures. Run the Futaba, Ace, KO or JR high end digital servos with coreless motors and you will be much more bullet proof.
The Futaba BLS 9451 brushless servos are proving to be the ticket right now for both steering and throttle for the 8ight buggy.
Futaba S9451 coreless for throttle.
Futaba S9351 coreless for steering.
These are the best servos we have used at the shop and we sell them all. No where near the problems we have encountered elsewhere.
I run an M11 with Spectum and they run great outing after outing.
TEX
tex1 is offline   Reply With Quote
Old 10-10-2007, 09:01 AM   #5310
Hellsavage's Avatar
Hi I am new to this thread and I have a question.
I know its been asked a few times but this thread has so mush posts I dont know where to look.
I am gone buy me a 8T race roller fore the 2008 season. I want to know wat the basic Hop Ups wil be to make it Bullit Proof and race ready.
I was thinking of the KHZ long motor mount.
Some CVD condoms.
Anything else?
thanks Hellsavage
Hellsavage is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
