Old 09-27-2007, 08:02 PM   #5221
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
what are you looking to gain/loose. we need to know what you want the car to do more or less of before we can help you.
micrors4guy is offline   Reply With Quote
Old 09-27-2007, 08:46 PM   #5222
cornerspeed's Avatar
Originally Posted by RETRO RC View Post
hey guys need some help with a rough track setup. currently using Adam drakes neo buggy with 45wt /55 front and 35wt/55 rear, red springs on front and green on rear, 5-7-2 diff oils.
the track is tight outdoor med to high bite hard packed clay and rough
any help would be cool
thanks Adrian
I believe that there really isn't a way to set a car up for a rough track. I really have tried. The only success that I have had was to change my driving style. Most of our tracks around here start off smooth and well groomed, but then turns to hell by the second qualifier and worse for the mains. It really is a matter of avoiding the potholes and changing the racing line. In other words, adapt to the track. Also you have to drive slower and let the car do the work. Let it glide over the rough with low throttle input. Guide it around the rough stuff if possible. The 8 has to be driven a lot less aggresively then any other car, so try to drive calmer. If you crash less over the rough stuff, then your results will be better.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 09-27-2007, 09:13 PM   #5223
sport10's Avatar
thanks Adrian
Try the 2-A rear camber location. It really seems to settle the rear of the buggy in the rough stuff more. Also going down to 5K in the center might help. I also notice that you are using quite abit of damping in the shocks. Why not try 30w/55 27mm ride height in the front and 25wt/56 28mm ride height in the rear.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-28-2007, 01:44 AM   #5224
RETRO RC's Avatar
I'm a smooth driver that likes to drive the same line from lap to lap what
I'm finding is that I'm not able to stay on the power in sections of the track from 1 lap to the next as on 1 lap the buggy seems to find the holes to easily and "trip itself up" and not the next
I'm running 27mm front, 29mm rear ride height with droop at 95mm front, 106 rear and 3/3 in the rear
what I'm not sure of is if the dampening to stiff causing the buggy to kick up or -to much droop - not enough ride height etc causing the buggy to get a wheel caught in ruts etc
So I really just wanted to see what others where running on rough tracks to compare and or try different setups that have worked for others
RETRO RC is offline   Reply With Quote
Old 09-28-2007, 02:06 AM   #5225
speedy2's Avatar
a friend of mine coming from mbx5R
drives now 10000/7000/5000
and feels at last, good about the 8ight
says it drives like the other cars now...
speedy2 is offline   Reply With Quote
Old 09-28-2007, 02:22 AM   #5226
RETRO RC's Avatar
why would you want it to feel like other cars on a fast smooth track no one can touch me with it -but on a rough track the consistancy becomes an issue for me
but I'm willing to try almost anything once
Old 09-28-2007, 05:21 AM   #5227
RETRO RC's Avatar
anyone looking to buy the adjustable hingepin brace set check this price out 1/2 the price of anywhere else
http://www.losipartshouse.com/servle...r-Hinge/Detail
just ordered a set for the 8T already have ECKTEC on the buggy
just went to get a set of fronts and they've put the price up only paid $16.95 for the first set now they are $29.05 bugger should have got them all at the same time
Old 09-28-2007, 05:29 AM   #5228
sport10's Avatar
If your damping is too stiff you are not getting the full benefit of your suspension. Being too stiff in the rear will cause the back to kick because of too much pack.
Associated B44
Associated B6
Old 09-28-2007, 06:20 AM   #5229
tex1's Avatar
Send a message via Yahoo to tex1
Post
Retro,
You might consider changing the neutral ride height setting. Get your front up and your rear down. That alone will tame the car quite a bit when going through the rough stuff. If you run stiffer springs in the front it won't dig in and swap ends on you.
I have found the Losi likes 5K-5K-3K when running on very rough tracks. Any wheel that hits a rough will now not diff out and make the car twitchy. You will see greater on power steering to power out of stuff.
Roll center adjustments should be personal preference and will not have as big of an overall effect as the neutral camber setting. To keep the tire off the edge more you might consider running -2 camber where yo might have been running -1 before.
I like to add down travel to 97 & 108 but I run stiffer sway bars. This seems to work for me but it might not be for everybody.
Tires, tires, tires. You need to run a set that will not catch an edge. This is the biggest thing you can do.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 09-28-2007, 07:17 AM   #5230
PTP Racing's Avatar
Ive got a set of the Lunsford titanium hinge pins and turnbuckles I wanna sell. They were installed but never seen the track. I want $55 shipped I just spent $75 + shipping for them. Email ptpracing@msn.com
PTP Racing is offline   Reply With Quote
Old 09-28-2007, 07:21 AM   #5231
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Then put them in the classified section . Being they are used and not NIP only worth half .
Briguy is offline   Reply With Quote
Old 09-28-2007, 08:16 AM   #5232
PTP Racing's Avatar
Is that an offer for $37.50 or are you a moderator? I'm confused.
Old 09-28-2007, 09:19 AM   #5233
Kcdzim's Avatar
Send a message via AIM to Kcdzim
He's not a moderator nor was it an offer. He's pointing out that it's not appropriate to list items for sale in this thread AND that you're asking price is unrealistic.
Kcdzim is offline   Reply With Quote
Old 09-28-2007, 10:01 AM   #5234
PTP Racing's Avatar
How many posts should we make about it? I get it....You dont want them.
Old 09-28-2007, 07:48 PM   #5235
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
Briguy and KC- Do you guys have an 8ight buggy? Or are you just moderating? LOL
Miller- See you tomorrow, ill have to check out how much lighter the car is if you installed the lunsford setup.
Tex- Good info for rough track setup. I have been to a few tracks where I have struggled to get the car to settle down and stay with the track, instead of being thrown around by the bumps.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
