Old 09-21-2007, 09:21 PM   #5191
RETRO RC's Avatar
Originally Posted by tex1 View Post
Finken-
You are thinking right. More antisquat will help in the bumps if you have the traction. When you load the front of the car (like going into a turn) the increased antisquat will take away side bite in the rear. However, the higher antisquat value will let you accelerate through the bumps and keep the car flat.
Bottomline- if you like to drive on throttle, run antisquat.
If you drive with a lot of brakes or you are on the brakes in a bumpy section, run less antisquat.
Hope this helps,
TEX
<----- Not done yet!
hey tex,
yes and no to the post above, if the track has only small bumps yes more antisquat but if the track is quite rough then less antisquat
[quote] It depends on how big the bumps are, really. More anti-squat will make the car jump higher, which also means it will bounce the car around more on big bumps. It will give the car more forward bite which could help get through smaller bumps better, but that's about it.
Anti-squat means the rear end of the car will be bound up on-power. That's a bad thing when you're going through bumps.
Aaron Waldron
RETRO RC is offline   Reply With Quote
Old 09-22-2007, 06:49 AM   #5192
Davidka's Avatar
Trader Rating: 75 (100%+)
Less anti squat has the bump handling effects Aaron mentioned and the only thing I would add is that some tracks get rough enough that the ground bumps can cause chassis slap, in that case stay with some anti squat and work with the bumps in another way.
Another effect of anti squay to take into account is it's effect on traction. This was touched on before but I think I have a simple explanation. Running less anti squat gives more off throttle side bite. The best example I can think of is higer speed turn entries (sweeper turns). I find that less a/s makes the car more stable on these types of turn entry. More a/s helps the car to square up off the turn better on throttle. If you have too little the car will feel less locked in on throttle.
Old 09-23-2007, 10:00 PM   #5193
What do you guys think...is the 8ight good for blown-out tracks.Where can I download some setup sheets.Also,I read on this forum that the 8ight has problems with servos blowing due to vibration.Has anybody replaced the drag link bushes with bearings.Check my mod on the brake links
Mater is offline   Reply With Quote
Old 09-23-2007, 10:05 PM   #5194
air8's Avatar
Springs huh? I have always like the feel of fuel tubing. Also the servo problem is not from vibration. EPA set correctly, no spring binding from throttle return spring, servo spacers used to raise servos off chassis, and quality servos. I saw someone a few pages back said to use fuel tubing on the outside collet for the throttle linkage.
For the blown out sections of a track I just pin the throttle and glide over it. i feel the buggy works great everywhere.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-24-2007, 04:31 AM   #5195
Hmmm, i saw this on another thred in this forum:
"In the N/w the Mugen rules, and most has given up on the Losi due to it poor performance on rough tracks and other issues.... "
"A lot of guys around here are dumping their 8ight's same reason when the track gets blown out the losi cars get real incosistant thats why i sold mine plus im just an A.E. fan. but the losi cars are good in the right hands"
I thought the Losi was the King of blown out tracks????
Finken is offline   Reply With Quote
Old 09-24-2007, 04:46 AM   #5196
I've run the Kyosho, Mugen and Losi. I would say the Mugen works best in the rough. The Kyosho with the new big bore shocks looks a lot better now through the bumps than it did with the standard shocks. When the track gets blown out I raise the ride height on the Losi slightly so the front doesn't dig in. I run on some pretty rough tracks and don't feel I'm at a disadvantage. But I do know that the Losi will out perform the others on the jumps.
kmorast is offline   Reply With Quote
Old 09-24-2007, 06:00 AM   #5197
Yip, I feel the same.I dumped the Mugen on Thursday practice, Friday got the setup ok on the 8ight and on Saturday qualified 5th,could have been 3rd.I like the feel of the 8ight,it has more corner speed and to me it seems that it was better on the ruff stuff as well.Some guys here run them with very little droop, is that the way to go?I need some setup sheets.
Old 09-24-2007, 12:20 PM   #5198
Suspended
Send a message via AIM to Nay0k
Yeah I do this myself too on rough tracks and I feel the same way regarding the other cars, though I'm going just by looking where cars seem to bottom out the most etc. Haven't driven a Mugen or Kyosho. I feel the 8ight is a great all around car.
Nay0k is offline   Reply With Quote
Old 09-24-2007, 06:58 PM   #5199
22Racer's Avatar
Trader Rating: 67 (100%+)
Nice racing with you this weekend Lars! Not one of our best Minnesota tracks but our series is a blast. Which tires worked best last weekend? Kendall (my son) was running Chrime fighters up front and Bowties in back. His setup is posted on mnnitroseries.com if you wanted to look at it. Hope you had a good time!
Rex
22Racer is offline   Reply With Quote
Old 09-25-2007, 12:44 AM   #5200
air8's Avatar
How do you people have the brake bias set? I've had mine set to more front braking cause I'm a crappy driver. But now that I've learned how to race 8th scale I'm going to start dialing in more rear brake. I like how it slows down very straight and under control, but I think I can cut a little more time by swinging the rear a bit.
--"U Ain't Fast!!"
Chris Pearce
Old 09-25-2007, 05:31 AM   #5201
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I set mine to grab the rear first with little brake applied and then the front when full brake is applied . This way I can slide around a corner if I need to or use full brake when slowing down at the end of the straight .
Briguy is offline   Reply With Quote
Old 09-25-2007, 07:29 AM   #5202
free2day77's Avatar
I run more front than rear. If I run more rear than front, the rear likes to try and push through or around the front.
free2day77 is offline   Reply With Quote
Old 09-25-2007, 07:51 AM   #5203
Steve Walters's Avatar
40F/ 60R for me.....
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 09-25-2007, 08:28 AM   #5204
captain america's Avatar
Er... With regards to the 8ight starter box, I've read on other forums that people have been complaining about burning out its motors in a ridiculously short period of time. Is there any truth to the opinions muttered that it's not a good starter box?
captain america is offline   Reply With Quote
Old 09-25-2007, 09:00 AM   #5205
I used it on a new JP engine last week with no problem.A few other guys at the track have not had problems either.
indaway is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
