Old 09-18-2007, 03:02 AM   #5131
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
hey casey the next coldest plug is the p6 there is no such plug as a p4
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 09-18-2007, 03:20 AM   #5132
OS does make a P4. I have several of them.
kmorast is offline   Reply With Quote
Old 09-18-2007, 03:22 AM   #5133
http://osengines.com/accys/glowplugs.html
pretty sure they dont mate
Old 09-18-2007, 03:22 AM   #5134
Originally Posted by Jon Kerr View Post
I posted a thread about this in the Engine's forum but it doesn't get looked at as much. So I'm hoping you guys can help. Here's the thread I posted:
Anyone have any ideas?
To me it looks like your running your engine to lean. The first sign of a lean engine is broken elements on the glow plug.
Old 09-18-2007, 03:29 AM   #5135
Pictures speak louder than words.
Old 09-18-2007, 03:33 AM   #5136
where did you get them from?
fair enough mistake ive never seen one and os dont even have it on their site
intresting,thanks for sharing that
Old 09-18-2007, 03:39 AM   #5137
They came out at the same time as the Speed engine. I bought these at Spiral RC in Tokyo. I just looked at A-main hobbies and found them on there website. Should be easy to get anywhere. The new aluminum head speed comes with the P3.
Old 09-18-2007, 03:43 AM   #5138
Ok cool,that motors unbelieveable...im currently running the Aluminium head speed and its crazy! going close to 13 min tank times
Old 09-18-2007, 03:50 AM   #5139
I'm still in the process of breaking mine in. The power seems very good especially down low. But I will say the scream it has at top end sounds killer.
Old 09-18-2007, 03:56 AM   #5140
Yes the engine sounds very different to a stock motor on the same pipe,ive noticed top end the speed has a wicked scream!!, over all sounds much 'deeper' and 'raspy'.Crazy power though you will like it
Old 09-18-2007, 04:42 AM   #5141
Hi all
I see the a lot of you are using the T3/A3 block in the rear, BUT, i saw in an erlier posting, that if the track became messes up (big holes, bumpy) during a raceday, going back to T3/A2 was the thing to do.
I thought that when the track get messed up, more antisquat was the way to go? am i wrong?
Another thing, what should i change from a standard setup (race roller), to make the car beahave better when track gets messed up, big holes, kraters etc
Finken is offline   Reply With Quote
Old 09-18-2007, 04:56 AM   #5142
I use antisquat to tune how the car turns. I've found that more antisquat allows the car to steer into the corner harder and rotate a little quicker. Less antisquat settles the car down some going through the corner. Less antisquat will also give the car a little better straight line traction. I don't normally change antisquat based on the bumps unless it's causing a problem on the track.
Old 09-18-2007, 05:52 AM   #5143
tex1's Avatar
Send a message via Yahoo to tex1
Post
Finken-
You are thinking right. More antisquat will help in the bumps if you have the traction. When you load the front of the car (like going into a turn) the increased antisquat will take away side bite in the rear. However, the higher antisquat value will let you accelerate through the bumps and keep the car flat.
Bottomline- if you like to drive on throttle, run antisquat.
If you drive with a lot of brakes or you are on the brakes in a bumpy section, run less antisquat.
Hope this helps,
TEX
<----- Not done yet!
tex1 is offline   Reply With Quote
Old 09-18-2007, 06:46 AM   #5144
tex1's Avatar
Cool Steel flywheel.....
Originally Posted by KForce View Post
to all that bought flywheels can you leave me some trader feedback and i will do the same for you thanks!
kyle
Kyle -
I sent you a PM.
Thanks,
TEX
Old 09-18-2007, 07:52 AM   #5145
KForce's Avatar
Trader Rating: 2 (75%+)
tex back at ya
and 13minutes runtime? maybe with a pitstop in between or on a track with a 50 foot straight. my speed will barely make 10 indoors and outdoors barely 8:30-9. or maybe ya got the savage 200cc tank in there :P
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
