Old 09-16-2007, 06:20 PM   #5116
nitro rat's Avatar
Trader Rating: 5 (86%+)
thanks for your fast reply. the back end of it keeps pushing out around the corners and when you take the stutters you need to go really slow otherwise it just flips and turns around.
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 09-16-2007, 06:21 PM   #5117
nitro rat's Avatar
set up is standard
thanks
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 09-16-2007, 06:24 PM   #5118
nitro rat's Avatar
if you could pm me the setup you think would help that would be great
thanks
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 09-16-2007, 08:09 PM   #5119
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You may want to put Aaron Waldron's setup on. He posted a few pages back the changes he's made to the setup from stock. I haven't run on a track like what you're describing so I really don't have a specifice setup for you. Someone else may though.
Jon Kerr is offline   Reply With Quote
Old 09-16-2007, 08:11 PM   #5120
Jon Kerr's Avatar
Default Now I need some help
I posted a thread about this in the Engine's forum but it doesn't get looked at as much. So I'm hoping you guys can help. Here's the thread I posted:
Originally Posted by Jon Kerr View Post
I'm running an OS EB Mods V-Spec .21 in my 8IGHT. I've got about 3/4 gallon through it. So far every race day, I've gone through a P3 (the plugs EB says to run in the engine) plug. And they're not burning up. The elements are breaking. Twice I've had them break in the middle of a main where the car will stall, then when it won't start again, we pull the plug out and the element is broken. Every other time, it's after the main, I go to put after run oil in and check the plug and it's broken. The engine runs great, but what's the deal? I'm still not really clear on the different plugs. Is a higher number hotter or colder? Would you run a colder plug in hot humid weather? etc... It's been really hot and humid around here lately (100+ and very humid) so I don't know if the P3 is too hot of a plug for that kind of weather or what. I was running O'Donnell 30% and I've started running Nitrotane 30% and it's done it with both fuels. I've got a bunch of Orion Turbo 6 plugs that I could use. I ran one in a qualifier and not having time to tune the needles, it ran like crap. Would that be a better plug? Is it a hotter or colder plug.
Sorry for the rookie questions. Still trying to wrap my head around tuning nitro engines.
Anyone have any ideas?
Old 09-16-2007, 08:27 PM   #5121
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
If the element broke, pull the engine apart and check for parts of the element within and in the bearings. ANY debris in the engine can cause havok and kill plugs, AND performance.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-16-2007, 10:48 PM   #5122
nitro rat's Avatar
ok thanks for your help mate
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 09-17-2007, 04:25 AM   #5123
Suspended
Send a message via AIM to Nay0k
For the record, I've been running a P3 in my standard VSpec all summer - not once has an incident like this happened despite the fact I'm pushing 300 degrees with my engine (usually around 285-290), though it usually only gets up to about 85-90 on the hottest days here. If I were you though I would do what rezenclowd3 said as well as trying a P6.
Nay0k is offline   Reply With Quote
Old 09-17-2007, 04:54 AM   #5124
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
hey jon are you running the extra head shim?? sounds like a classic case of over compression.Try adding the supplied additional head shim and that should fix it,if you are over compressed.
The plug is right i have run many v-specs from stock to JP Modified to the Speed version.I have run P3's in every single engine,i tried many other plugs but the P3 ran the best in every condition.
hope i helped , let me know if it fixes your problem
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 09-17-2007, 05:05 AM   #5125
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
Jon -
The plug thing is mechanical. You should be OK with the shim after a good tear down and cleaning. I don't run these motors but there are some local OS guys that only run the P3 and nothing else.
Hyper is on the money.
Nitro Rat -
Do you want to have a setup sheet from our latest ProSeries race? Our track was a lot like what you are describing. Dusty and the bumps would throw you around on your nose.
Let me know and I'll get one posted.
TEX
tex1 is offline   Reply With Quote
Old 09-17-2007, 12:02 PM   #5126
Suspended
Doesn't sound like Jon Kerr needs the extra shim, he said he's ran two different types of 30%...so I would assume he already had it on there.
Old 09-17-2007, 08:19 PM   #5127
anyone know how to make the aluminum rear chassis brace fit on the 8ight rtr? i've already ground off the lower right support wedge on the motor backplate and it's still a little off. anyone else had this problem?
smuller81 is offline   Reply With Quote
Old 09-17-2007, 10:08 PM   #5128
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
Default 8ight setup
Just thought I would repost this for any noobs out there. Good setup info.
Losi 8ight building and setup
oldguyzrule is offline   Reply With Quote
Old 09-17-2007, 10:26 PM   #5129
CaseyP's Avatar
Hey Jon sounds like high compression as well. the higher the number the colder the plug. the P3 is the plug of choice untill it gets super cold outside then you will want to try a p4 just a tad colder.
let us know if the extra shim helped.
CaseyP is offline   Reply With Quote
Old 09-18-2007, 02:08 AM   #5130
Hi all
I see the a lot of you are using the T3/A3 block in the rear, BUT, i saw in an erlier posting, that if the track became messes up (big holes, bumpy) during a raceday, going back to T3/A2 was the thing to do.
I thought that when the track get messed up, more antisquat was the way to go? am i wrong?
Another thing, what should i change from a standard setup (race roller), to make the car beahave better when track gets messed up, big holes, kraters etc
Finken is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
