Old 10-23-2006, 06:26 PM   #481
Sofast-NT's Avatar
I don't think it is a prob gettn the diffs out. My jammin cr and kyosho sp2 were took about the same amount of time to remove because I had the captured hinge pins, and still had to remove the entire assembly.
I like how the inner pins are captured with a molded palte, instead of having a nut and pin to remove.
Sofast-NT is offline   Reply With Quote
Old 10-23-2006, 08:24 PM   #482
cornerspeed's Avatar
Is there any final word on what clutch springs to use? I will be running at ARC. Anyone know the web-site for ARC?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-23-2006, 08:29 PM   #483
D_Ames's Avatar
Send a message via AIM to D_Ames
http://www.arcraceway.com/
They've been talking about changing the Race times for Saturday. It's best to call.
Dave
D_Ames is offline   Reply With Quote
Old 10-23-2006, 09:53 PM   #484
Aaron I know what you mean about saying you didn't have a big crash this was my first time running the car and the only time it was on the roof was from traction rolling. And the jump I came off was landed perfect. But I do have some droop and I seen the marks in the chassis from the screws but I still have the green and silver springs but I put k2 softs and took alot of preload out of it and that helped with the traction roll and I could take the turn twice as fast as I could with my jammin. I'm not downing the car just need the help on setup cause I can only make it to the track on race day and that's it.
Ghost06 is offline   Reply With Quote
Old 10-23-2006, 09:54 PM   #485
Also what are the losi silver tire are they soft cause I like them but after three 10 min heats they were done.
Old 10-24-2006, 12:05 AM   #486
Aaron Waldron's Avatar
Don - Not sure why the part would come from Chino? Losi and Horizon share a building in Ontario.
Adam has suggested composite shoes with black springs and the aluminum shoes with gold springs.
o.s. power - It's not terrible...there's a little more disassembly required but I don't think it's that awful.
Ghost - Were you having the traction roll problems with the stock tires? The Step Pins are a bit taller than say, a Crime Fighter, and they'll traction roll easier.
I'm running 40 wt. oil in the front with 54's, and my car could be driven into the corners like crazy without flipping. If your buggy still traction rolls with smaller tires, and with this front shock setup, let me know and I'll come up with other ideas.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-24-2006, 02:58 AM   #487
JBRacing's Avatar
Does anyone has a clue when the aluminium option parts shuold be out for sale?
JBRacing is offline   Reply With Quote
Old 10-24-2006, 08:07 AM   #488
Trader Rating: 22 (100%+)
I had this same problem at BOW race and Ron reccomended that I add droop to the car. That seemed to fix the traction roll problem. This car keeps getting better and better. Another thing that I did to make the car drive a little easier was swapped the shock springs around, green springs in the front and silver in the rear.
sand geek is offline   Reply With Quote
Old 10-24-2006, 08:20 AM   #489
The simplest of things makes this car go really fast.
Homer Allman is offline   Reply With Quote
Old 10-24-2006, 11:43 AM   #490
JB - Not sure. What do you think the car needs? I think most of the aluminum upgrades are for those customers who just GOTTA have some "bling" on their cars. The included equipment, namely the plastic chassis braces, serve a function to the handling of the car.
sand geek - Ron's pretty darn helpful, isn't he? An awesome guy, for sure. Did he have you add droop all the way around, or just to either the front or rear? I've always liked my cars with minimal droop and I think it helps maintain corner speed. More rear droop should help the car turn, while I'd think that more front droop should make the car easier to drive.
www.liverc.com
Old 10-24-2006, 01:36 PM   #491
Trader Rating: 39 (100%+)
I hear you on the bling! I ran King Headz aluminum braces on my SP2 for one race and absolutely hated them. Went back to Kyosho HD braces. They just made the car so rigid and stiff which made the car hard to drive. I doubt i'll try them on the Losi...it handles so well as it is, why change something that works.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 10-24-2006, 03:45 PM   #492
He is really helpful. I think I might have worded that incorrectly. I decreased droop all the way around, limited it to help increase the corner speed. I was not using the droop screws at all before he looked at the car. DOH!
Old 10-24-2006, 05:42 PM   #493
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
well today i went and ran my car. and changed the stock slutch shoes after a gallon and a half. they still have life in them just have to be cleaned up. in their place i put the m2c soft regualr shoes with gree springs and the losi carbon shoes with black springs and even tho I am running the same spring setup the new clutch is way snapper!
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 10-24-2006, 07:13 PM   #494
Has anyone mounted a Ninja motor in their 8ight yet? I can't seem to get it to fit.
*Topher* is offline   Reply With Quote
Old 10-24-2006, 07:42 PM   #495
I am running the ninja motor in my 8ight. Only thing I had to do was rotate the carb a bit since I took it out of my mbx5. The rubber boot on the carb was hitting on the center diff top plate. Motor works great in the car.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
