Old 08-16-2007, 08:25 AM   #4846
RBMike's Avatar
Originally Posted by K_B View Post
Has anyone used the Robinson CBs yet? I bought one and in my first race I snapped a tooth off Of course, I could have had a mesh problem, but I've run about six gallons through the car on the stock 'bell with no problems so I'm pretty sure the mesh was ok. The motor hadn't shifted or anything like that during the race.
I've been running them for gallons now, no problems. I'm also running the spur. I broke teeth out of 3 of the losi cb's, that's why I swithched.
RBMike is offline   Reply With Quote
Old 08-16-2007, 08:39 AM   #4847
associatedguy's Avatar
KForce, you're going to want switches or soemthing like that. I prefer pink tapers, but others have been running inside jobs.
associatedguy is offline   Reply With Quote
Old 08-16-2007, 09:55 AM   #4848
jimbal's Avatar
Has anyone had thier center diff go out on them? I just found out my problem with no power to the rear diff in which I thought it was a clutch issue. I found that one of the slots the spider gear fit into was stripped or notched so the gear set that drove the rear was disengaging.
Team Associated SC10 4x4 | Losi 8ightB 2.0
E-Flite CX2 | E-Flite 120 SR
--Jim Balazic
jimbal is offline   Reply With Quote
Old 08-16-2007, 10:03 AM   #4849
vr6
Trader Rating: 22 (100%+)
my center diff when out, but i think that it had a leak because when i opened it up, it was completely dry. did roast my gears also. broke the case and bent the pins
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 08-16-2007, 10:12 AM   #4850
xlgraphicspro's Avatar
I hope you guys replace your diff fluid regularly? That's the only reason besides a stripped screw, that a diff should implode like that. Or if it's so old that it just wore the gears out. But I wouldn't be concerned about that until you've run about 10 gallons through your car.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 08-16-2007, 10:49 AM   #4851
air8's Avatar
Damn, more maintenance. I've got about 11 gallons on my car now. Not once has any of the diffs leaked. I replace the fluid every 8th weekend. We used to race Fri, Sat., Sun. So 24 races basically and I'd replace the fluid. But it always looked like I had just put it in. These losi diffs are great. I was worried coming into 1/8 scale that they would be a problem area for me. Cause I lack on regular maintenance. It gets hard to keep up sometimes. No problem. Original diff gears, cases, and gaskets. I bought the Losi gaskets a loooong time back and haven't opened them yet. I'm just waiting to see how long they last. I have replaced both front and rear outer bulkheads cause of crashing. No problems with the diffs though. I don't know what dirty/burnt diff oil is supposed to look like. I assume blackish or brown. IDK.
air8 is offline   Reply With Quote
Old 08-16-2007, 11:20 AM   #4852
KForce's Avatar
Trader Rating: 2 (75%+)
aeguy: yea we ran switches there for the first round. but hey i am a crcrc guy you already know i will have mucho switches with me
cya tomorrow in the am
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 08-16-2007, 11:30 AM   #4853
freefallmarine's Avatar
Anyone replace the pin's on the cv's? Mne look real good but the pin;s have a directional flat spot from the drive cup's.
freefallmarine is offline   Reply With Quote
Old 08-16-2007, 11:44 AM   #4854
Dan Reino's Avatar
Freefall, I buy the Mugen pins. They work perfect. It is a biatch getting the original one's out, but once you do, the mugen's go in and out very easy. And no I have never had any fly out. Have been replacing them for 5-6 friends around locally.
The Mugen pins come in two sizes, small one's for the center and longer one's for four outside hubs. Got them from Amain. 10 pins for about 5 bucks.
I use a small socket with hole just big enough for pin to slide out, put it in my vise, heat um up w/ heat gun, and press um out. you could buy a Hudy dog bone press from Stormer if you have money to burn......Amains got a bonesaver that looks good too.
This will save your dog bones and out drives from wearing out.
Dan Reino is offline   Reply With Quote
Old 08-16-2007, 11:48 AM   #4855
Once again Dan, Your the man!! Ill shoot you a call this evening..
Old 08-16-2007, 02:23 PM   #4856
tex1's Avatar
Send a message via Yahoo to tex1
Red face
Carl,
I have a tool set you can use anytime you want. I use it to replace pins all the time for people.
It is the Hudy one.
Let me know and I'll meet you to get them replaced.
TEX
tex1 is offline   Reply With Quote
Old 08-16-2007, 03:31 PM   #4857
Cool, Thank's Tex. Do you have any pin's in stock? Ill be down tues.
Old 08-16-2007, 04:55 PM   #4858
trebor's Avatar
Make some for me too Carl.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 08-16-2007, 04:59 PM   #4859
Send me some drive's...Ill chrome them too.. Got to get your bling on.
Old 08-16-2007, 05:56 PM   #4860
tex1's Avatar
Talking
We got em! Come on with your bad self.
TEX
OUT!
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
