Old 10-23-2006, 01:43 AM   #466
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
YEP I SURE DO
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 10-23-2006, 02:18 AM   #467
Aaron Waldron's Avatar
Ghost - Are you SURE that parts failure could've have been caused by a not-tight screw, or cracked and injured from an earlier accident.
You can't drive it like your old car...because it's not your old car. Take a deep breath and re-learn 1/8th scale off-road, and you'll find that the car can be driven hard, just not like your "other" buggy.
Don - Did you find what might've caused it?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-23-2006, 02:24 AM   #468
cornerspeed's Avatar
No, I am building the car. It came that way out of the package.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-23-2006, 02:26 AM   #469
Ask for Jeremy or Bill.
www.liverc.com
Old 10-23-2006, 03:47 AM   #470
my losi on the weekend
Old 10-23-2006, 08:27 AM   #471
Trader Rating: 14 (100%+)
is there any way to change the caster on an 8. looking for some mid corner steering. getting a push.
jlo8864 is offline   Reply With Quote
Old 10-23-2006, 08:54 AM   #472
Well I only wrecked like 4 times and they were not hard I just didn't think that was bad to run three 10 min heats. But what's up with the alum bracces I can see from my body that I'm getting flex.
Ghost06 is offline   Reply With Quote
Old 10-23-2006, 08:57 AM   #473
Also what shock set up are you guys running I'm getting more of a skip to mine on blown out tracks where I seen one guy's 8ight run so smooth over the same part.
Old 10-23-2006, 09:05 AM   #474
Trader Rating: 28 (100%+)
Sounds weird, but limit your travel on blown out tracks. (droop screw)
FlyByWire is offline   Reply With Quote
Old 10-23-2006, 09:34 AM   #475
Well what shock oil should I run I seen where one guy was running green springs front and rear and his looked pretty good. I couldn't ask anyone about set between running two classes and pitting.
Old 10-23-2006, 10:10 AM   #476
weliin's Avatar
Could be how you are building your shocks. You can build a shock with 35wt oil and 55 piston and it handle the track differently from the next guy's just because you may have built it with more or less rebound than the other racer.
weliin is offline   Reply With Quote
Old 10-23-2006, 10:59 AM   #477
Originally Posted by Aaron Waldron
909-390-9595
Justed called them. They are sending one out today. Thanks.
Donny Vinkemulder
TLR Driver
Old 10-23-2006, 02:47 PM   #478
Don - Not a problem, glad you got taken care of. Who did you talk to?
jlo - I included a couple possible setup alternatives in my PM to you. I don't think caster is the adjustment you're looking for.
Ghost - It's always possible that something went wrong in the manufacturing of the part that broke, but I have yet to hear any of those kinds of stories so far with the 8IGHT stuff. I hear the "I barely crashed!" line all the time..but parts crack in big wrecks, and then break at very weird times. Also, if a screw came loose (or wasn't tight enough to begin with) it will put added stress on certain parts.
Like what was said, your shocks may have too much rebound, or you may need to limit your droop, which will stop the tires from falling into the holes and keep the car flat. Try messing around with both of these variables and see what works best for you. I am running 40 wt. with 54's in the front and the stock pistons with 37.5 in the rear right now, with stock springs.
It may also be how you're driving. Try to hit rough sections of the track with speed and maintain a constant speed through the bumps. This will allow your suspension to travel freely.
www.liverc.com
Old 10-23-2006, 04:57 PM   #479
not to dog the car one bit,
but has anyone noticed what a pain in the dick it is to get the f & r diffs out?
o.s. power is offline   Reply With Quote
Old 10-23-2006, 05:33 PM   #480
[QUOTE=Aaron Waldron]Don - Not a problem, glad you got taken care of. Who did you talk to?QUOTE]
I talked to Bill. Helpful and said the part would ship out this morning. Do you know if that would come from Chino or Horizon? Just wondering if if I might see it tomorrow. I would like to get the car together and run it this weekend.
Donny Vinkemulder
TLR Driver
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
