Old 08-06-2007, 08:45 AM   #4726
Davidka's Avatar
Trader Rating: 75 (100%+)
Probably not. The Losi uses different bearing sizes than most buggies.
Old 08-06-2007, 08:48 AM   #4727
kjuliussen's Avatar
The bearing for the diff is 8mm inner size. so it's the same as the rest of the cars..
kjuliussen is offline   Reply With Quote
Old 08-06-2007, 08:52 AM   #4728
You might be able to use the Losi bearings on the Tacktyl diff. Let us know.
satoch is offline   Reply With Quote
Old 08-06-2007, 12:31 PM   #4729
RBMike's Avatar
Originally Posted by kjuliussen View Post
Hi.
Does any of you know if any other cars front diff will fit the 8ight?
I'm keen on testing a Tactyl II bbf diff.
I doubt it will work but Please let me know if you make them work. I'm sure the grearing will be incorrect.
For those of you who do not know the BBF tactyl II diffs are amazing. I used to run them in K-cars & later MBX's and if your track has anything BUT a hard pack high traction surface these diffs will make you faster. I don't think anyone is importing these diffs now days but if anyone has any info on how to get them, I would like to hear it. I see on there site the do not offer a diff for the Losi yet.
RBMike is offline   Reply With Quote
Old 08-06-2007, 07:50 PM   #4730
trebor's Avatar
Originally Posted by CaseyP View Post
Casey,
Do you have the setup sheet for the one in the video? Because the one you have a link to is for wet, 30-50 degrees etc... If you could either write one up or link something for that specific setup, Id appreciate it,
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 08-06-2007, 08:41 PM   #4731
trebor's Avatar
Originally Posted by Aaron Waldron View Post
Hey guys, just a couple things I tried yesterday that worked well, so it's worth repeating.
- 37.5 and 54's in the front, 25 and 56's in the rear. Down from 40 and 27.5, seemed to get through rough stuff better without sacrificing corner speed.
- Four carbon shoes with four gold springs in the clutch. Lots of power, great feel, excellent wear!
Aaron Waldron- Hello, do you still run with this set-up? Or does anyone else out there run with the drilled pistons? And if so how do you like it an does it work better than regular "non-drilled" pistons?
Sorry for double posting guys, and gals.
Can someone get me a link to a proven setup that is definitely a nice setup??Please, please?
Feedback
Old 08-06-2007, 10:33 PM   #4732
CaseyP's Avatar
same set up with 15k in the center diff, zero rear camber short ackerman plate zero toe in and losi taper pin slicks. Thats it. This car works great on every surface I have encountered so far.
drilled pistons will be in between pistons as far as pack goes. so a drilled 54 will start out as molded piston (with holes bigger than 54) which is then drilled out with a 54 drill bit. It will be slightly smaller than a molded 55 hole.
more pack , slower dampening
CaseyP is offline   Reply With Quote
Old 08-07-2007, 12:09 AM   #4733
Trader Rating: 96 (100%+)
Can someone get me a link to a proven setup that is definitely a nice setup??Please, please? [/QUOTE]
Rob- use the stock setup and make changes to that.
Last edited by K.Copeland; 08-07-2007 at 07:17 AM. Reason: he threatened to beat me up
K.Copeland is offline   Reply With Quote
Old 08-07-2007, 03:47 AM   #4734
tlxxx4driver's Avatar
K
Just use the setup we did this weekend 100,000 is the center, bacon grease in the rear and pickled pigs feet juice in the front. Shocks use sand fron the beach and clay from the track it was all hooked up....
LOl j/k kidding I will call you later .Dave
Team Losi 8ight
Rb
Airtronics
Byrons Race
Team Glitch
When in doubt blame your roll center
"Damm radio it is glitching again"
tlxxx4driver is offline   Reply With Quote
Old 08-07-2007, 06:48 AM   #4735
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
Originally Posted by tlxxx4driver View Post
K
lol. wow u tried that one as well, what luck did u have with it? i used custard in the front, and it seemed to work. lol.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 08-07-2007, 06:52 AM   #4736
freefallmarine's Avatar
Wow, since it's working for you guy's. Im going to use a maple long john for reciver padding..
freefallmarine is offline   Reply With Quote
Old 08-07-2007, 07:26 AM   #4737
On both my 8t and 8b I had a shock piston come loose and acually flip itself upside down in the shock. One shock pierced the bladder, the other shock was fine. Needless to say, my fastest qualifier with the buggy was with the blown shock.
Old 08-07-2007, 07:33 AM   #4738
That's nut's eddy.! Did you feel the car get upset during the race? Congrat's on the Qual.
Old 08-07-2007, 07:52 AM   #4739
I didnt' notice anything until I went back to the pits.
Just a couple laps into the truggy qual. my truck was not steering like it did before. I knew immediately the servo saver had backed down onto the chassis.
Just a heads up to "us" Losi newbs, use loctite on everything.
Old 08-07-2007, 12:39 PM   #4740
How many of you guy's run your buggy with the plastic chassis brace's? Can you really tell a diffrence?
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
