Old 07-21-2007, 11:22 PM   #4561
JBRacing's Avatar
Dose anybody know if the GS and Losi diff oils are the same.
If not, what is the difference?
JBRacing is offline   Reply With Quote
Old 07-22-2007, 12:34 AM   #4562
freefallmarine's Avatar
Im sure there's a minute differance. But if you use the same brand oil(weather,GS,Losi,Etc.) for all the diff's youll be fine. Iv'e mixed diffrent companie's before in a pinch,(mugen,and kyosho oil.) but could'nt tell a diffrence.
freefallmarine is offline   Reply With Quote
Old 07-22-2007, 11:49 AM   #4563
air8's Avatar
Ok. say you set camber and toe. But with the play in the linkages, how do you know where you're at? Example; you set the front for one degree of camber. But with play, it is at most 3* and minmum 1*. What do I call my setting? 3* or 1* I just use the RPM gauge, with rims only on, and drop the car 6" to the table. Then adjust the links to get my reading and go. But when I get to the track, the expert drivers usually say that my camber looks way off. So then I adjust it by my eye and it looks like too much. So I'm lost on how to get in the ballpark. I'm not looking for spot on cause I don't need it to the gnats ass perfect. I'm just looking for other people's way of doing. Thanx
air8 is offline   Reply With Quote
Old 07-22-2007, 12:18 PM   #4564
Trader Rating: 27 (100%+)
Send a message via Yahoo to HECTICRACER
i wanted to know what 3 shoe set up works on the 8
fly wheel
shoes
springs
clutch bell
thanks for the info
B-MAIN HOBBIES #1 FOR GREAT DEALS
HECTICRACER is offline   Reply With Quote
Old 07-22-2007, 01:04 PM   #4565
Trader Rating: 42 (92%+)
i used to run kyosho flywheel,clutch shoes,with eight clutchbell
that is the best setup
icemandolmite is offline   Reply With Quote
Old 07-22-2007, 02:13 PM   #4566
g26er is offline   Reply With Quote
Old 07-22-2007, 03:00 PM   #4567
mbunker's Avatar
Trader Rating: 29 (100%+)
Send a message via MSN to mbunker Send a message via Yahoo to mbunker
fly wheel
shoes
springs
clutch bell
thanks for the info
I run the same setup as ice except I run the Ofna narrow 13T clutch bell. I think the kyosho clutch bell was link $25 at the lhs. I did try the losi bell but it just looked to awkward in there and came too close to my fuel tank. With the Ofna CB, it looks how it's suppose to. Also I didn't have to do anything in the way of crazy shimming with the King Head motor mounts, but I've seen this same setup done with the stock losi motor mounts also.
~Michael Bunker
~Michael Bunker~
_______________________________________
Special thanks to my beautiful wife Brittany whom I love very much!
AE FT SC10/ AE FT SC10 4x4/ Team Durango DNX408T
mbunker is offline   Reply With Quote
Old 07-22-2007, 04:28 PM   #4568
Ephidelt490's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Ephidelt490
I used to run my old Xray clutches on the 8ight using the stock engine mounts. Only need a couple shims behind the collet to get it like a normal buggy.
Ephidelt490 is offline   Reply With Quote
Old 07-22-2007, 04:38 PM   #4569
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
I'm fairly new to this nitro stuff and stumbled across vented clutchbells. I'm totally paranoid about heat. Are vented CBs worth it or are they just kind of a gimmick? I know I'd have to switch out the stock clutch setup and was considering either the fiorini (fioroni? firorinorinoroni???) adjustable clutch or maybe that RMV clutch...
K_B is offline   Reply With Quote
Old 07-23-2007, 06:22 AM   #4570
tex1's Avatar
Send a message via Yahoo to tex1
Talking
Vented clutch bells are cool if you run aluminum shoes. They shed the heat and contaminates will not bother how the shoes grab.
Run sealed bells if you run carbon shoes.
Just temp the bell after your runs and find what works for you.
3-Shoe? - Kyosho or Mugen carbons. The Kyoshos cost more but last forever. You also have to modify the flywheel a little. Run the required 1.0mm springs. I always run the Losi clutch bells so you don't have to put the motor in weired positions.
You might consider the Works clutch if you want something different. 2 Roulon and 2 carbon shoes works very well on slick or short tracks. 3 Roulon and 1 carbon if you are hooked up and can put the power down.
Gold spring 1.25 mm from flush w/ loctight.
This clutch gives a definite advantage to me in ease of the drive and wear.
It gives up nothing on the track.
You will soon learn why all of the onroad guys run Roulon.
TEX
tex1 is offline   Reply With Quote
Old 07-23-2007, 09:09 AM   #4571
J.Wright's Avatar
Default Engine help
Tex
The wife and I raced our losi 8ight buggys this weekend ( I broke in both heats and the main. This car has bad juju) and after the race she comely walked in to the hobby store and bought herself a Losi 8ight truggy,,, didn't say a word to me just bought herself a truggy and now she needs a engine I know nothing about 1/8 scale buggies and less about truggys what kind'a power plant would you recommend for a novice truggy racer?
Jim
J.Wright is offline   Reply With Quote
Old 07-23-2007, 09:29 AM   #4572
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
I would still buy a .21 engine. Look @ the RB S5 and S7, or the Novarossi 21BF, Picco P7-R Evo 2. If it were me, I would stay in the $200 or slightly above price range....
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-23-2007, 10:04 AM   #4573
thanks guys for the clutch set up info. i had tried the mugen flywheel and it fit perfect with the losi cb .but i used the alum. shoes (in my 8t) after 1 run they were beat pretty bad ,then i noticed that the center diff was ripped apart by a rock that got stuck .i went and order the kyosho flywheel i try the ofna, losi cb's but it would not work .so this was my conclusion
mugen flywheel
kyosho shoes
1.0 springs
losi cb
it seen to line up perfect
Old 07-23-2007, 10:39 AM   #4574
Is there anything wierd you need to do to make the werks or 3 shoe work on the losi?
camshaft is offline   Reply With Quote
Old 07-23-2007, 10:52 AM   #4575
Merciless's Avatar
Send a message via ICQ to Merciless
Hi All,
Just had my first weekend with the 8ight b Was pretty good too. I did have a couple of problems though, in the rough stuff the rear seems to be bottoming out and bouncing up, it also has a tendancy to roll over in the corners if i hit any sort of bump or rut.
I started out with a box set-up(barring tires, as i'm racing on grass in the UK angle spikes are far better) and ended up with the front shocks mounted outer most top and bottom and the rear out on the bottom and middle top.
I was thinking of changing pistons guessing that 55 + 54 RE SMALLER THAN THE STD. 56'S so maybe 54 front and 55 rear ??
also can anyone list the springs for me hard to soft as i have no idea on losi springs. As i was also going to change front and rear for harder ones.
You think im going in the right direction guys ??
Cheers
Rod
Merciless is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
