Losi 8ight building and setup
#4473
im am haveing the same problem (finding info)...there doesnt seem to be an 8ight T thread and wondering if there is any setup info for an 8ight T here. tryed to do a search but it just brings up 8ight stuff.
i have a not to bad setup for my truggy right now but i like to compare to others to see if im in the same direction. looking for a medium bite and rough track setup
#4474
I've been running my T as it came out of the box. Stock setup, stock parts, stock everything. Seems to work just fine
#4475
This is for the 8T. Hope this helps. But the locals around me run it completely stock. They play with shock oil and pistons a little bit. Not much.
#4477
Any of you 8ighter's plan on going to the Futaba Challenge in L.A.? Hope to see you there..
#4478
#4479
#4480
Well when you go over a bump in the track the rear end of the car should not bounce so high that the car flips forward smacking the wing & the motor upsidedown on the ground. The car never did that when the hinge pins were not bent Sooo I don't think I'm being "too anal". In 10 years of 1/8th scale off-roading, I never had another car do this. I think I understand how a off-road car should handle. And for the record my rear end "felt" free with the shocks off as well. I changed the hinge pins & it is fine now. As for feeling your suspension with your hand at zero miles per hour, you cannot always feel problems that occur at speed.
#4481
8ight RTR clutch
So I was running my 8ight buggy through the yard and it stalled... when I went to restart it I noticed the wheels spun with the spin start. I knew right away that it was the clutch so I tore it down. I pulled the clutch bell off to find it tore up preaty badly the clutch shoes have grinded into it really bad. My question is my rtr only has 2 clutch shoes is it possible to put 4 in? I see that drake runs 4. do i need to change any thing to make it work?
#4483
I have been running the Truhe setup, but I changed the center diff fluid to 1500 and moved the rear hubs more center.
#4484
#4485
yes!
