Old 07-10-2007, 08:15 AM   #4396
RBMike's Avatar
This has NEVER happened to me even once and I pay NO attention to which way the notch faces. Possibly because I'm using Mugen shock boots? Also my home track is very rough so I use max down travel & a very soft set-up.
RBMike is offline   Reply With Quote
Old 07-10-2007, 08:28 AM   #4397
RBMike's Avatar
Aaron has there been any changes to the rear outer hinge pin? Or should I make my own?
Old 07-10-2007, 08:45 AM   #4398
cornerspeed's Avatar
I can vouch for this. There are new outer rear hinge pins. They are a dull silver color and they are much better.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-10-2007, 09:48 AM   #4399
trebor's Avatar
Are they the same part #?
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 07-10-2007, 10:22 AM   #4400
Matt Howard's Avatar
yes, it's a running change like the shock O rings were.
Matt Howard is offline   Reply With Quote
Old 07-10-2007, 10:24 AM   #4401
RBMike's Avatar
Thanks Cornerspeed
Old 07-10-2007, 10:37 AM   #4402
Has anyone tried dissconecting the rear brace to get some more flex?
Dale.0 is offline   Reply With Quote
Old 07-10-2007, 12:56 PM   #4403
gearheadz80's Avatar
That would be crazy IMO. Take a crash and land on the wing, u will more than likely fold your chassis plate
gearheadz80 is offline   Reply With Quote
Old 07-10-2007, 01:00 PM   #4404
xlgraphicspro's Avatar
Umm, Err? Why? You might cause the chassis to flex so much, that your clutch bell will hit your gas tank and cut a nice hole in it. Or your rear drive shaft will bottom out in the center diff outdrive and possible snap a rear drive shaft.
I see nothing but postential problems with this Idea. Plus that much flex would hurt more that help.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-10-2007, 01:10 PM   #4405
Well if you look at Jesse Robbers set up thats what he recommends. I was just wondering if anyone has tried it. I doubt that without it the chassis will "fold" or put a hole in the tank. It doesent support the center of the chassis anyway.
Old 07-10-2007, 01:29 PM   #4406
Davidka's Avatar
Trader Rating: 75 (100%+)
It won't have as big an effect as you might think. Notice how short the rear brace is? From the front bolt of the rear brace to the rear bolt of the front brace is un supported. It would only increase the flex a tiny bit I think.
Old 07-10-2007, 02:23 PM   #4407
RBMike's Avatar
I've seen 2 (different guys) Mugen chassis bent because the one of the screws holding the rear chassis brace had broken and gone un-noticed. I think the car will handle OK without it but if you have a tumbling crash you may be in trouble.
Old 07-10-2007, 05:37 PM   #4408
Why don't 1/8th gas buggies have rear tires wider than fronts like fwd 1/10th electrics?
satoch is offline   Reply With Quote
Old 07-10-2007, 07:26 PM   #4409
vones's Avatar
Originally Posted by ReVhEaD View Post
i used the same method as you... coz Losi one is not thick enough.... but my shock piston screw came off from the shaft couple of time... i already cleaned the shaft and used blue thread lock, but still came off....
rim the piston holes that goes onto the shock shaft such that it's slighlty bigger then the screw thread size...fixed it onto the shock shaft b4 the screw....
as for the shock retaining caps...I use a bit of shoe goo where the spring sit on the caps...works for me...
vones is offline   Reply With Quote
Old 07-11-2007, 01:50 AM   #4410
freefallmarine's Avatar
Can you use a losi/mugen,kyosho,etc clutchbell with the Robinson Racing spur gear? Or do you have to pair them together?(RR bell and spur.)
freefallmarine is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
