Old 07-09-2007, 06:32 PM   #4381
Originally Posted by yourtxlender View Post
Need some advice on the 8ights shock spring retainers. At least one comes off everytime I race. They don't seem to be damaged or out of shape at all but they are older. I saw Fioroni has the aluminum ones but $46 for 4? would it make a difference?
The only solution I've seen is guys drilling a hole through them and then using a very small zip tie to secure it to the spring.
satoch is offline   Reply With Quote
Old 07-09-2007, 07:13 PM   #4382
Aaron Waldron's Avatar
Twist the spring cup so that the notch faces out, towards the wheel. If you don't do this, the spring cup will hit the arm at full compression, and pop the cup off of the shock.
Once you twist them into place, you shouldn't have to keep twisting them back, they will stay put.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 07-09-2007, 07:19 PM   #4383
Davidka's Avatar
Trader Rating: 75 (100%+)
I have mine like that, one still came off this weekend. I think it's the bladders sliding up the shock end when the shock rebounds from the vaccuum that occurs when the air is blown out of them quickly when they bottom out.
Old 07-09-2007, 07:45 PM   #4384
Try pulling the shock boot up a little further, so there's still slack in it when the shock is fully extended. The shock boot shouldn't be pulled tight when the shock extends.
Also, if you're running a lot of downtravel and not much spring preload, that will cause them to pop off. They need spring pressure to stay in place.
www.liverc.com
Old 07-09-2007, 07:49 PM   #4385
Davidka's Avatar
I do that. I am just thinking that when the shocks bottom out it squeezes all the air out and when the shock extends the boot doesn't extend with it and crawls up the shock end. I am going to try balloons instead of the stock boots. The boots are too delicate anyway.
Old 07-09-2007, 07:51 PM   #4386
Haha, now that's a phantom problem.
Are you going to use balloons in place of the shock boots, or over the spring?
www.liverc.com
Old 07-09-2007, 08:10 PM   #4387
Davidka's Avatar
No kidding! You'd think the spring would be enough to keep them down. If they (Losi) would increase the thickness of the rubber a little bit I think it would fix it. It would make the boots tougher too.
I am going to use them in place of the boots. I test fit one and they are tough to stretch over the lower cap but it gives a better fit at the ball end. We'll see how they hold up. Oh, they come in all kinds of corny colors. I think I'll do pink, it's the new black.
Old 07-09-2007, 08:56 PM   #4388
ReVhEaD's Avatar
i used the same method as you... coz Losi one is not thick enough.... but my shock piston screw came off from the shaft couple of time... i already cleaned the shaft and used blue thread lock, but still came off....
Team C-NETIC
ReVhEaD is offline   Reply With Quote
Old 07-09-2007, 09:12 PM   #4389
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I use the tko balloon set. Its OK, but the rubber dries out in a day. They are a PITA to put on, but at $5 for a 100 or so, I'd rather use them. The losi ones were easier to put on, but not $5 easier and did not last that much longer. I might try pre-filling the balloons to stretch them out, then installing them. Might make it easier.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 07-09-2007, 09:19 PM   #4390
My buddy uses the Thunder Tiger boots. They are like an accordian. They are a tad bit thicker and work great. I tried balloons. Forget it!
Old 07-09-2007, 09:30 PM   #4391
revhead - Did you clean the screw? Put a dab of loctite on the screw, and then roll the screw on your finger to wipe the excess loctite off. This will leave loctite only in the troughs of the screw threads. Then crank it like heck!
If you haven't, you may want to try a new screw and/or shaft. The threads of one might be bad.
David - You can try gluing the shock bottom to the shock end. It's not uncommon in gas truck to use a dab of glue, enough to hold it on there, but not enough that you can't pop them apart to disassemble the shock.
www.liverc.com
Old 07-09-2007, 10:50 PM   #4392
what about those outer wears shock covers are those any good?
vroom88 is offline   Reply With Quote
Old 07-10-2007, 05:46 AM   #4393
thanks for the help. I have used ballons for a while now and I would say they work great. Of course I'm the one with the retainer problem though.
yourtxlender is offline   Reply With Quote
Old 07-10-2007, 08:13 AM   #4394
RBMike's Avatar
triple post sorry
RBMike is offline   Reply With Quote
Old 07-10-2007, 08:13 AM   #4395
RBMike's Avatar
triple post sorry, my network has issues.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
