Old 07-02-2007, 07:40 AM   #4321
Trader Rating: 14 (100%+)
Originally Posted by air8 View Post
Also, if anyone is having probs with the stone filter falling off the metal nipple in the fuel tank, solder it. Someone on here suggested that and it worked great. I used to try to fix this every other weekend but I have 3 gals. on since soldering and all is well.
that happened to my friend yesterday and was making his motor run like crap, it looked as though the filter was falling apart!
o.s. power is offline   Reply With Quote
Old 07-02-2007, 08:54 AM   #4322
sickboy's Avatar
Trader Rating: 72 (100%+)
Originally Posted by trebor View Post
Sickboy- Thanks, thats exactly what Im looking for! They are nice too! I did notice Fioroni has some adjustable front ones too but for the fr & rear its $90. Way too much $$ for me.
Satoch-Its not the people behind me that are causing it its from the hard hits to the "FRONT" end. Problem solved, so I dont have to worry about anyboy passing. NO-NO! lol.
The plastic insert on the Fioroni piece costs more than the King Headz piece. Fioroni sure is $proud$ of thier stuff.
sickboy is offline   Reply With Quote
Old 07-02-2007, 10:44 AM   #4323
trebor's Avatar
Yes, the Fioroni pieces are definitely sweet but me poor right now so Im gonna have to wait. So you have the ones for the front, right? How does that work? adjustable? must be a good option to have to work with.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 07-02-2007, 02:14 PM   #4324
freefallmarine's Avatar
Man i just saw the goodies from Fioroni on Amain..There stuff look's Hot!! Im sure the 8 with all that stuff on would look awsome. But with the price of all that stuff combined it's like a new motor. And like you guy's i rather have go, than show.. Unless there's a sale..hehehe....
freefallmarine is offline   Reply With Quote
Old 07-02-2007, 02:35 PM   #4325
Also running the M2C plates on both ends of the car. What does adding the weights to the rear do for the car? I have them, but haven't tried them yet.
Stealth_RT is offline   Reply With Quote
Old 07-02-2007, 02:47 PM   #4326
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
It should give you more forward traction.
EA
EAMotorsports is offline   Reply With Quote
Old 07-02-2007, 06:37 PM   #4327
Straightline, that'd be great. But, would it give you more on-power push coming out of a turn? That wouldn't be so good, need more on-power steering as it is.
Old 07-02-2007, 07:13 PM   #4328
trebor's Avatar
EA
I personally love the M2C weights. It seems that the buggy is more planted.
Feedback
Old 07-03-2007, 02:42 AM   #4329
The rear end doesn't wash out during cornering any more. It's much stablier during breaking and cornering. I put the whole 1oz on it and went from there. If the track's got good bite and your rear end is getting too much bite you can remove a 1/4oz of weight at a time to keep the front end from pushing to a minimum.
Old 07-03-2007, 11:01 AM   #4330
Default Help
This may sound stupid to all of you that got the experience building the 8ight.
I can't get the steering servo in place, it is an ACE 1015, way to tight and the servo wire gets in the way if I try to push it in place.
What is the trick?
cota348 is offline   Reply With Quote
Old 07-03-2007, 11:24 AM   #4331
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
team dremel!!!! FTW
you need to dremel a couple mm's on both sides of the radio tray for the servo to fit in.
micrors4guy is offline   Reply With Quote
Old 07-03-2007, 05:52 PM   #4332
air8's Avatar
Originally Posted by micrors4guy View Post
team dremel!!!! FTW
Yep, that's probably the best way. I actually got mine to fit without the dremel, but the heat sink fins took some plastic with them. So I basically crammed it in there. My 8 needed this servo from the beginning. It turns so well, that I would get in trouble with slower servos. With the speed of this one I could correct in the middle of a turn and end up looking like I was driving good.
air8 is offline   Reply With Quote
Old 07-03-2007, 06:17 PM   #4333
Guys, I've stripped both of my clutch pins that came with my RTR when I was trying to replace the RTR aluminum clutch. Do you guys have any ideas on how to remove the pins? The guy who made the rtr kit must screw the pins ridiculously tight and added too much loctite PLEASE HELP!
THanks
kmaheartless is offline   Reply With Quote
Old 07-03-2007, 06:17 PM   #4334
joecool's Avatar
Trader Rating: 19 (100%+)
my stock losi clutch has had it. the shoes are really thin. im going to buy some king headz or m2c aluminum. do you guys have any good suggestions with a good set up? i run on an outdoor track with a bunch of tight corners and one long straight.
also im going to get a new rb c6bbt7. amianhobbies has 2 different moded versions, one by hotmods and one by ceopower mod. anyone know which one i should choose? im leaning towards the hot mod cause i have seen a hot mod novarossi p5 running really strong. gemmie your opinions.
joecool is offline   Reply With Quote
Old 07-03-2007, 06:58 PM   #4335
THanks
once again team dremel FTW lol.
take a cut off wheel and dremel a slot in the head of the clutch pins, then heat up the pins with a lighter to break down the locktite on them a little and it will com off with a flat head screw driver.
I have been running m2c soft light shoes with green and gold springs on a vspec. getting arround 2 gallons of life out of then with good smooth feel.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
