Losi 8ight building and setup
#4306
Last night, I kept popping the steering rod ends off the ball cups. I already had the Kyosho ends installed. I put new ones on and theys still popped way too easy. So I tried something I saw Steve Slayden do to an 8T in OKC. I used heavy duty Traxxas push rod ends and the balls to make captured rod ends. Worked awesome. In fact, it worked so good I think I found the next weakest link. http://www.amainhobbies.com/product_...oducts_id/7734 I have broke many of these rear hinge pin covers before, so I don't know if it is related to my captured ends or not. anyways, is there something other than plastic for these pieces. I had smacked a wall pretty hard to break it, so it's not like it's weak. Just wondering.
#4307
air8-You know Im having the same problems with the hinge pin brace covers that Im skeeeered to hit hard. Even though I rarely hit anything but puttycats.lol. No, realy though, we need some metal brace covers made because the plastic cant handle the force from all the power of my "Dollar Store" engines.lol.
#4308
lol. I taut I taw a putty tat too. Ya, I have broken those several times before. Actually one time I broke one and didn't have a replacement. So I CA glued a 5-40 nut to the chassis just to hold the hinge pin in. It stayed on the whole rest of the day. When I got home and tore the front end down, I touched the nut with a screw driver and it fell right off. Wheeww. Close. But, I've been looking today and haven't found anything yet. I might have to get creative at work. Yikes.
#4309
NICE!! Let me know what kinda of "danger" you invent.
#4310
Team EAM
This may not be an option for you guys but a VERY good 28.00 fix/upgrade is the M2C plates. They use pivot balls in the hinge pin and are ultra smooth and pivot 10 times free'er than the stock ones. They do not get gritty and bind up at the end of a day like the stock ones either.
And you never have to worry about the covers breaking as they are not used anymore
EA
EA
#4311
EA
EA
#4312
Losi 8ight, National Champion!
#4314
What plastic hinge pin cover problem? I race nearly every weekend in the 10-20 mains and never have a problem. Maybe you should pay attention to the idiots behind you that have a tendency to rear end you and get out of their way...
#4316
If I keep breaking this piece then I need to take the captured rod ends off, put the stock ones on, and let the do the job of popping off to prevent breakage. Sorry for the long post. Didn't want an argument to start.
#4317
EA
EA
Also, if anyone is having probs with the stone filter falling off the metal nipple in the fuel tank, solder it. Someone on here suggested that and it worked great. I used to try to fix this every other weekend but I have 3 gals. on since soldering and all is well.
#4318
The M2C rear toe plate's work great. Adding the weight's to the rear end is like night and day for my Losi.
#4320
front inner plastic hingepin cover problem SOLVED!!!! http://kingheadz.com/
Satoch-Its not the people behind me that are causing it its from the hard hits to the "FRONT" end. Problem solved, so I dont have to worry about anyboy passing. NO-NO! lol.
