Old 06-26-2007, 04:23 PM   #4246
Originally Posted by RBMike View Post
I burn just over 2 gallons a month or 1/2 a gallon per weekend & I run every week. I do not use grease or lube on the cvd's.
wow rbmike! You certainly do not lack for track time do ya?!
gtsum is offline   Reply With Quote
Old 06-26-2007, 04:25 PM   #4247
Trader Rating: 28 (100%+)
This is probably the wrong place to ask this... but maybe some of you guys have owned both.
Wondering how the MBX5R drives in comparrison to the 8ight. I am getting back into the hobby and was driving an 8ight when I got out.. Have heard good things about the Mugen, but have never driven one.
FlyByWire is offline   Reply With Quote
Old 06-26-2007, 05:49 PM   #4248
Hello
I have some questions about building the differentials for the 8ight. I notice there is two different slots for the planetary gear axle on the differential housing, one deeper, and one shallower. Should I place the bottom planetary axle on the deeper slot or on the shallower slot? Or does it even matters?
Thank You.
kmaheartless is offline   Reply With Quote
Old 06-26-2007, 05:51 PM   #4249
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Imo, the 8ight has more on power steering, but is a little less forgiving for an aggressive driver. It also jumps awesome and has mucho turn in steering.
I would give the edge to the Mugen on rougher tracks, or low traction tracks.
But the truth is they are all so close it is going to be driver error and mechanical failures that seperate everyone, just like it usually is in 1/8th scale!
...Jim
W.E.D.
www.wedjim.com
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 06-26-2007, 05:58 PM   #4250
...Jim
W.E.D.
www.wedjim.com
Thats about what I was thinking, Jim. I noticed with the 8ight, it likes to be driven like a 4wd mod..
Old 06-26-2007, 06:19 PM   #4251
Originally Posted by kmaheartless View Post
Hello
Thank You.
no one?
Old 06-26-2007, 06:22 PM   #4252
no one?
You need the lower gear in the deeper slot.
Old 06-26-2007, 07:24 PM   #4253
Flybywire - thanks! argg.... I need to take it out and rebuild it again
Old 06-26-2007, 07:39 PM   #4254
It should be the only way the gears will seat into the case...
Old 06-26-2007, 09:02 PM   #4255
Actually it seats into the case either way... So that is why I am confused
Old 06-26-2007, 09:10 PM   #4256
Kcdzim's Avatar
Send a message via AIM to Kcdzim
not really. The deeper slot allows you to get the pin in the hole to lock in the shaft from the outside. After that it makes no difference where the bevel gear cross shafts go, as they sit at the same level in the housing
Kcdzim is offline   Reply With Quote
Old 06-26-2007, 09:24 PM   #4257
so either way works?
Old 06-26-2007, 09:34 PM   #4258
draggindrew's Avatar
hey freefallmarine and tex1 where do yall race at? I have just started getting into racing and ive been going to Indy rc world anA friend d am gonna try and go to jcg this weekend just to watch.
But the main ?'s i have are:
1. I have an 8ight rtr that ive done some upgrading to. A friend recently got out of the hobby and gave me tons of stuff including a brand new ofna chrome top starter box. I know this is in this thread somewhere but dont have the time and patience to look ot up. It seems as though the starter wheel is not reaching the flywheel. Do i need tto modify the starter box or is there engine mounts that lower the engine on the chasis? Or do i need to get a larger flywheel?
2. I am looking into buying a modified engine. Which engine in yalls opinion is the best bang for the buck no expenses spared. im looking into a hot mod ws7 III or an OS 21VZ-B V Spec Comp.
3. Where can I find new better orings for my shocks? I just disassembled them and one shock had only a few drops left in it.
draggindrew is offline   Reply With Quote
Old 06-26-2007, 09:45 PM   #4259
freefallmarine's Avatar
Draggin, I race at Indy, Johnny's and all in between...Hopefully ill meet you at Indy soon.
freefallmarine is offline   Reply With Quote
Old 06-26-2007, 09:53 PM   #4260
Registered User
RTR has the roto start on it which uses a taller motor mount. Replace the motor mount with a losi or kings heads engine mount and you can use a starter box.
OS V-Spec is a great motor..don't waste your money on the modded one, yeah they do add a little power; but the v-spec has way than enough power...way more..
Desolas is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
