Old 06-20-2007, 07:15 AM   #4186
trebor's Avatar
Originally Posted by tex1 View Post
Cored motor servos like the cheap ones are do stay at hold when the car is in the stock configuration. Get rid of that inline throttle return spring and get one that is much lighter. Traxxas makes a great one. Aslo use the Losi gas truck throttle return spring. When the carb is closed you should have no spring tension on the servo. Cheap servos will burn their boards and motors if they are left under load.
Still, put a good coreless servo in when you get the opportunity.
My 9451 Futaba has ben flawless racing 2 nights a week.
TEX
Tex- Yeah, Im gonna go ahead and get me a Futaba 9451 and I got some AVID bearings, the ones I needed the most were on order, the 8x14x4 ones, must be popular and they are definitely cheap but great in quality. Thanks for everything.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 06-20-2007, 07:34 AM   #4187
Originally Posted by vroom88 View Post
so you think i would would be perfectly safe installing my ace DS1313
I have used my Ace DS1313 on throttle/brake for over a year on my 8 buggy with no problems.
satoch is offline   Reply With Quote
Old 06-20-2007, 10:46 AM   #4188
air8's Avatar
Originally Posted by tomdav View Post
We need a bigger pic...
http://www.jconcepts.net/news/images...07204435-0.jpg
http://www.jconcepts.net/news/images...07204435-1.jpg
http://www.jconcepts.net/news/images...07204436-2.jpg
http://www.jconcepts.net/news/images...07204436-3.jpg
air8 is offline   Reply With Quote
Old 06-20-2007, 10:57 AM   #4189
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
What wheels are those tires on in the pictures? OFNA?
Stewart Fan is offline   Reply With Quote
Old 06-20-2007, 11:05 AM   #4190
air8's Avatar
Originally Posted by trebor View Post
Someone please post bigger pic of JConcepts .
Ace servos, huh. My buddy ordered 2 of them but said they are oversized he couldnt fit it on his P.O.S.lol.
Yeah, the ace servos are kind of round on each end. They are not straight across on the ends. I didn't think I was going to get the 1015 in place for the steering with out the Dremel. It finally went though.
Old 06-20-2007, 11:06 AM   #4191
tomdav's Avatar
Trader Rating: 42 (100%+)
looks like losi on the right and the new Jconcepts on the left
tomdav is offline   Reply With Quote
Old 06-20-2007, 11:07 AM   #4192
are yall using the servo horn that came with the servo for throttle/brake or using aftermarket?
and those tires believe it or not say jconcepts on them
vroom88 is offline   Reply With Quote
Old 06-20-2007, 11:29 AM   #4193
Dan Reino's Avatar
Vroom.... Go to Amainhobbies.com, part#HAN3570 for throttle
HAN3531 for steering
I got my Losi back in Jan. put these on day one. On the throttle servo use the 4th hole(longest) drill it out just like the stock servo horn. Then use the 1st hole(shortest) drill it out just like the stock horn. You will have no servo issues, no sticky carburators. This gives better Geometry for the servo arm at full throttle. I have ran 3 diferent types of engines about 8 gallons of fuel not one servo issue...... I have done this to about 5 different friends cars and they have all been pleased. The morons that did not try it have lost servos and have had carbs stick......I will try to put up some pictures tonight.
Dan Reino is offline   Reply With Quote
Old 06-20-2007, 12:17 PM   #4194
trebor's Avatar
Dan Reino- Please post pics as I have never drilled holes in my servo arm.
Those tires on the 8ight-T are off the hook. Gotta go check out JConcepts see what they got for buggy tires. Has anybody tried the ones on that truggy?
Feedback
Old 06-20-2007, 01:47 PM   #4195
air8's Avatar
I've been using these with the Ace 1015 as my steering servo
http://www.amainhobbies.com/product_...oducts_id/2027
I just put them on today along with the Losi alum. top servo saver. I'll find out this weekend if there is any difference.
Old 06-20-2007, 01:58 PM   #4196
air8's Avatar
[QUOTE=trebor;3416205]Dan Reino- Please post pics as I have never drilled holes in my servo arm.
Yeah, What size of drill bit would you use? I would like to try this setup also.
Old 06-20-2007, 04:31 PM   #4197
Dan Reino's Avatar
I got my Losi back in Jan. put these on day one. On the throttle servo use the 4th hole(longest) drill it out just like the stock servo horn. Then use the 1st hole(shortest) drill it out just like the stock horn. You will have no servo issues, no sticky carburators. This gives better Geometry for the servo arm at full throttle. I have ran 3 diferent types of engines about 8 gallons of fuel not one servo issue...... I have done this to about 5 different friends cars and they have all been pleased. Some guys that did not try it have lost servos and have had carbs stick......I will try to put up some pictures tonight.
Here are my pics that show the good angles for the throttle horn and linckage...
Losi 8ight building and setup-losi-8ight-2.jpg   Losi 8ight building and setup-losi-8ight-3.jpg   Losi 8ight building and setup-lost-8ight.jpg
Old 06-20-2007, 04:50 PM   #4198
dan
that cant work right, its too clean! LOL!
T Green is offline   Reply With Quote
Old 06-20-2007, 07:01 PM   #4199
trebor's Avatar
Ok, so at that angle it really works without tension? I just never seen anybody do that yet. Maybe thats how its suppose to be done, I havent done it like that, anyone else?
Oh, and I noticed that you have 2 trays, 1CF and 1aluminum, Do you think it feels too stiff? Or is it feel the same?
Feedback
Old 06-20-2007, 08:36 PM   #4200
xlgraphicspro's Avatar
I've got mine at an angle just like that. I also have a v-spec, but I don't think it makes a difference
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
