Old 06-07-2007, 05:56 AM   #3991
Send a message via AIM to travymoto1
Originally Posted by Black View Post
The car has about a 1/2 gallon or so through it. This just sucks b/c my last 8ight was freakin awesome right out of the box, and well, this one isn't. I guess all I can do is run it some more and hope it gets better. I just wish I would have never sold my other one. But I have done everything to make this car better but with either no or minimal luck. I guess I am just going to have to run it more and "break it in."
Marcus,
Hey it's Travis. We hung out at the Daytona State race and Losi Race. Go back to box stock setup....diffs camber links and everything. It sounds like you need to play with the droop in the rear. Sounds like the rear doesn't have enough down travel? The car is very sensitive to ride height and droop.
Did you scrap the CEN? Give me a buzz sometime if you want.
904-226-9303
Also just as an FYI to everyone. My 8T got SUPER tight(pushed) during a main after being good all day. When I got it home and took the radio tray out, I realized the servo saver adjustment have backed all the way down to the chassis and was binding the steering movement. Easy fix, but it totaly screwed my main.
travymoto1 is offline   Reply With Quote
Old 06-07-2007, 05:57 AM   #3992
wlfgnggtr's Avatar
Originally Posted by claudacio View Post
Come on?? you are that tall wlf? Holy shite. I have a cousin thats 6'9", one tall dude. I am the shortest male of the family at 6'2", there are some females in my family that are taller than me, so I guess that would make me the runt, LOL.
Yup... I always thought I was only 6'5", but my wife checked a few weeks ago. 6'8", I guess I must have grown over the years
wlfgnggtr is offline   Reply With Quote
Old 06-07-2007, 05:59 AM   #3993
wlfgnggtr's Avatar
Originally Posted by air8 View Post
Yep, same problem when I had an Air 357 too. Like Rezen said, I added a washer and problem solved.
Same thing on my 357... Shim it and good to go...
Old 06-07-2007, 07:18 AM   #3994
xlgraphicspro's Avatar
Originally Posted by Davidka View Post
You could also flip the hardware on that side of the arm so it's on top of the arm.
Won't that cause the linkage to rub a hole in your body?
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 06-07-2007, 09:33 AM   #3995
Default Losi Starter Box
Those of us waiting for this box, in amain has been delayed again
cota348 is offline   Reply With Quote
Old 06-07-2007, 01:38 PM   #3996
joecool's Avatar
Trader Rating: 19 (100%+)
im going to pick up some shims tonight. im surprised the servo lasted as long as it did. i think with the shim fix my new servo will last forever! i ordered my 8ight box from hobbytown. they said it will be in next week. i hope they are right i am anxious to get that baby. thanks with the help guys on the linkage issue i knew it would be an easy adjustment.
joecool is offline   Reply With Quote
Old 06-07-2007, 05:26 PM   #3997
Trader Rating: 22 (100%+)
Default o ring problems
anybody know the size of the 8ight's shock o rings ? i have a kit for the first batch and the shocks are leaking all over the place...i've replaced the plastic spacer and end piece, but i can't find any o rings...they're on backorder, so i was going to try mcmaster-carr and see if they have them...any help would be appreciated
thefnshow is offline   Reply With Quote
Old 06-07-2007, 06:14 PM   #3998
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
i know im prolly gonna get slammed for this one but has anyone thought of an electric 8ight?
check this out from rc-monster.com:
http://www.rc-monster.com/proddetail...rod=rcmlosi8mt
jrr102486 is offline   Reply With Quote
Old 06-07-2007, 06:25 PM   #3999
freefallmarine's Avatar
I want one...
freefallmarine is offline   Reply With Quote
Old 06-07-2007, 06:25 PM   #4000
Matt Howard's Avatar
why would we slam you? there are a couple of guys at my track talking about brushless 8ights and how cool that would be
Matt Howard is offline   Reply With Quote
Old 06-07-2007, 06:37 PM   #4001
joecool's Avatar
ok guys i went to hobbytown and found some clutch shims from an hpi that fit under the servo arm insert. i got the arm raised high enough over the servo case to not cause any problems. can't wait to test i out at the track this weekend. thanks again to all that helped.
I want that brushless 8ight set up. no more engine tunning and clutch set up? why have we not seen more lipo brushless 1/8 scale cars yet? i bet a top of the line electric would destroy a nitro buggy. plus with battery tech getting better and better, you could almost run 30 min mains.
http://www.youtube.com/watch?v=I7c-ieY_VLc
youtube had this video of an electric 8ight that was tearin it up.
Old 06-07-2007, 06:52 PM   #4002
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Even if it does "destroy" a nitro, they would be separate classes. I prefer the tuning, clutch setup and such. However, I would only enjoy an 8th scale or bigger electric. I too would like to buy an 8 kit to switch to brushless sometime, as it would probably be a blast, but I am too afraid to dent a lipo, which I have done several times in my now sold RC18T. Also, I would prefer the Flightpower batteries as they are up to 30C continuous discharge. I know quite a few electric heli guys use some big friggen batteries, AND in series AND parallel, but with 20C they still can't use the batteries all to much as it draws too much still.
rezenclowd3 is offline   Reply With Quote
Old 06-07-2007, 07:02 PM   #4003
Electrics are fine, I just don't care for them. I NEED the sound and smell of nitro. That's it.
satoch is offline   Reply With Quote
Old 06-07-2007, 07:11 PM   #4004
trebor's Avatar
Can you really do that? If so I might try it because I am having that problem and lining up the ballcup will be at a better alignment.
Has anyone did this?
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Old 06-07-2007, 07:14 PM   #4005
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
Yo Travis whats up man. Hey man I have tried everything with this buggy. I put the buggy together and set it up the same way that I did with the buggy that I won the Losi Race with. There is something screwy going on. And on the rear I am running no droop. I have my droop screws all the way out. So I'm not for sure what all is going on. I'm rebuilding the car AGAIN, so hopefully I can figure out what the hell is going on.
Oh and the Matrix is on its way out. I ran it about 8 times and its a good car but it doesnt fit my driving style. So if you know anyone interested in a CEN Matrix FRE let me know.
I'll give you a shout sometime soon. Here is my number 850-819-8732
Black is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
