Old 06-02-2007, 10:38 AM   #3901
thanks for letting me in on that info trebor
vroom88 is offline   Reply With Quote
Old 06-02-2007, 10:58 AM   #3902
22Racer's Avatar
Trader Rating: 67 (100%+)
Someone needs to put this in the nitro forum!
Rex
22Racer is offline   Reply With Quote
Old 06-02-2007, 05:33 PM   #3903
xlgraphicspro's Avatar
Hey guys I found out that if you have your rear camber link in the 2-A position, or shorter 3-A or 5-A that it will cause your tie rods to bind and not allow your suspension to rebound properly.
I fixed this by using a set of front tie rods in the rear since they are shorter. now I can explore all the rear camber link positions.
Just thought I'd add that in if someone else hasn't already.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 06-02-2007, 05:38 PM   #3904
Originally Posted by RBMike View Post
gtsum, I have not in 10 years had that happen and I run alot. The outside diamiter of the big end of most collets is about the same size as the O.D. of the inner race of the motors front bearing. They spin togeather unless your fly wheel is loose. If the collet is warn from the flywheel coming loose it usually is worn on the outside of the collet or the inside of the flywheel (or both). I will use a shim there if the collet is worn to the point that it is sinking into the flywheel too far but I normally will just get a new collet (or flywheel depending on what is worn). I'm not saying that it is a bad practice to put a washer/shim there. I'm just saying that it is usually not required.
Gotcha...thanks for the info...I will have to try it sometime.
gtsum is offline   Reply With Quote
Old 06-03-2007, 09:50 AM   #3905
guys, one thing I noticed, about the screws and o-rings under the radio batt box(RTR) is, its making the chassis hole big...do you think i should tight it and just buy a stiffiner so there will be no movement on the radio tray?
Laysander is offline   Reply With Quote
Old 06-03-2007, 09:55 AM   #3906
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
no dont tighten it down all the way. I saw a few people at the cen race that didnt pay attention to how far their screw was in and it accually shorted out their rx battery. I personally do not run the orings under my radio bod and im on the same servo since day one (and I had preordered the car, so I have been having it since day one).
micrors4guy is offline   Reply With Quote
Old 06-03-2007, 11:19 AM   #3907
Hmmm, I am running the 5-A on the T and it seems to have the binding effect on that also. I'll have to try the front camber links on this, it also seems like I cant get enough camber using those postions, they are maxxed out and I actually think I may have stripped them going to far. Something felt up when I put this setup on, I had no thoughts that going to the shorter link would be the issue. Thanks for posting that.
claudacio is offline   Reply With Quote
Old 06-03-2007, 12:02 PM   #3908
im thinking of using the standard screw..that will just fit the box, not the long one that will go through the box...
Old 06-03-2007, 07:25 PM   #3909
For people using Bowties or Crimefighters and mounting them on the Losi wheels, what inserts are you using?
Stealth_RT is offline   Reply With Quote
Old 06-03-2007, 07:38 PM   #3910
Trader Rating: 26 (100%+)
anyone know how to convert xray oi weights like 700 into losi weights
eddie10 is offline   Reply With Quote
Old 06-03-2007, 07:46 PM   #3911
this should help
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
sjenkins97 is offline   Reply With Quote
Old 06-03-2007, 08:52 PM   #3912
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
If anyone knows the guys over at SGrid can you tell them there is something wrong with the registration as it kept giving me an error message when I payed and got redirected to their site. They also do not have ANY Type of contact info for themselves on their front page....So I paid but cant log in
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-03-2007, 09:12 PM   #3913
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
EA
YGPM. I sent you some emails of people that can help you.
killer89 is offline   Reply With Quote
Old 06-03-2007, 10:44 PM   #3914
air8's Avatar
I used the Pro-line grey foams that came with the tires. Seemed to work good for the little run time I had on them.
air8 is offline   Reply With Quote
Old 06-03-2007, 11:05 PM   #3915
Anytime, I was stumped for a day trying to figure it out, luckily I did. I think that using the rear tie rods is a mistake because you can't use every camber position. Ghetto if you ask me, but was easily fixed with a new set of front tie rods.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
