Old 06-01-2007, 05:32 AM   #3886
freefallmarine's Avatar
Leaving for OKC, RC/pro..see you guy's there!!!
freefallmarine is offline   Reply With Quote
Old 06-01-2007, 07:04 AM   #3887
trebor's Avatar
Good Luck and have fun to all.
trebor is offline   Reply With Quote
Old 06-01-2007, 09:34 AM   #3888
RBMike's Avatar
gtsum, I have not in 10 years had that happen and I run alot. The outside diamiter of the big end of most collets is about the same size as the O.D. of the inner race of the motors front bearing. They spin togeather unless your fly wheel is loose. If the collet is warn from the flywheel coming loose it usually is worn on the outside of the collet or the inside of the flywheel (or both). I will use a shim there if the collet is worn to the point that it is sinking into the flywheel too far but I normally will just get a new collet (or flywheel depending on what is worn). I'm not saying that it is a bad practice to put a washer/shim there. I'm just saying that it is usually not required.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 06-01-2007, 12:17 PM   #3889
Matt Howard's Avatar
Losi just announced a bunch of new stuff for the 8ight
http://www.horizonhobby.com/Stores/P...elease&IsNew=1
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-01-2007, 12:33 PM   #3890
trebor's Avatar
LOL!!!
Just like everything else, they are all on "BACKORDER"
BOOOOOO
Old 06-01-2007, 12:50 PM   #3891
Originally Posted by trebor
LOL!!!
BOOOOOO
And they all say mid or late June, but other than about 25 people, the rest of us won't be able to have any of these things until August
glitchy is offline   Reply With Quote
Old 06-01-2007, 01:47 PM   #3892
Hi everybody,
Ran my 8ight for the first time today and have a little question/issue about it.
The thing concerns rear inner pin plastic holders. After some practice for a couple for hours i noticed that it became deformed and unmounted from the alu plate at the end. Back ant home dissambled it and found out that the inner pinds pushed the ends of the plastic holder back, the pins (on both sides) were out about 2-3mm. Is it a common problem, should i ignore it or i pushed it a little bit too hard ?
Thank you
By the way - the clutch shoes already worned out
Taurius is offline   Reply With Quote
Old 06-01-2007, 02:55 PM   #3893
trebor's Avatar
Originally Posted by Taurius
Hi everybody,
Thank you
That sucks!! What are you running for clutch?
Old 06-01-2007, 04:28 PM   #3894
Trader Rating: 42 (92%+)
trebor you should be practicing more less time you on the computer
dont you want to be fassssttttttt
icemandolmite is offline   Reply With Quote
Old 06-01-2007, 05:38 PM   #3895
trebor's Avatar
yeah, in the rain????????
Old 06-01-2007, 10:11 PM   #3896
Today i'll be racing in ligh rain, it gets only more interesting
And the clutch was the stock one, put everything by the manual and wanted to give it a shot, 1/4 of a gallon maybe and out of business. Been driving a werks, changed the bearings and didn't knew what clutch shoe wear is for a whole season, too bad it doesn't fit
Now i installed king headz shoes, will see how they work.
Old 06-01-2007, 11:05 PM   #3897
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
werks does fit. try it
killer89 is offline   Reply With Quote
Old 06-01-2007, 11:41 PM   #3898
hmm this may sould like a odd question but i just thought of it, isnt the RTR buggy supposed to have both of the steering ackerman arms?, because mine just didnt come with the other one that is if thier supposed too.
car:losi 8ight
engine:werks B3, Novarossi P5XS
radio:DX3R,Ace DS1313
vroom88 is offline   Reply With Quote
Old 06-02-2007, 12:39 AM   #3899
you must lube your clutch bearings when you first build the buggy with a good quality bearing oil, they will last twice as long.
it is also wise to maintain your bearings & clutch either after or before each race meet.
flysti is offline   Reply With Quote
Old 06-02-2007, 06:48 AM   #3900
trebor's Avatar
Nope, the RTR comes with only the long ackerman.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
