Old 05-24-2007, 09:15 AM   #3721
kjuliussen's Avatar
What clutch setup do i use with the O.S Speed engine? I think i need a realy soft setup, because now i just spin out the rear end.
And have any of you got the center diff lock up?
Mine locked up and when i loosen and retighten the screws on the diff it was fine again, but when i checked it after the qual. it was locked up again. so i changed to new diff gear. and it happend again.
But i fixed it by adding a shim under the pin on the outdrive on both end of the center diff.
kjuliussen is offline   Reply With Quote
Old 05-24-2007, 09:27 AM   #3722
freefallmarine's Avatar
I dont run a OS Speed, but i would use a 7mm restrictor and All carbon shoe's (i currently run a kyosho 3-shoe clutch) with 1mm spring's. It work's great for my Plus-5. But also factor in your driving style. What pipe are you using?
freefallmarine is offline   Reply With Quote
Old 05-24-2007, 10:21 AM   #3723
kjuliussen, I bet your center diff housing (the cup the gears are in) is shot. Open it up, pull the small gears and cross shafts out and inspect the slots that the cross shafts fit in. I bet the spots where the shafts sit are wollered out. Only fix is to replace the housing. When the center diff is locked up the car is a bear to drive. Fix that before you change your clutch setup.
Jared Fournier is offline   Reply With Quote
Old 05-24-2007, 10:24 AM   #3724
kjuliussen's Avatar
I'm allready using the 7mm restrictor.
My pipe is Hong nor PI-809 efra 2047
Link.
http://www.modelsinmotion.co.uk/prod...e=441&tamiya=0
Old 05-24-2007, 10:27 AM   #3725
Link.
Are you currently using the stock Losi clutch?
Old 05-24-2007, 10:27 AM   #3726
kjuliussen's Avatar
I will check that.. Thanks for the info.
But i did fix it with the shimming, but i'm going to try a new diff versus the one with the shimming and see if there is a difference..
Old 05-24-2007, 10:29 AM   #3727
kjuliussen's Avatar
i think it is green spring on alu shoes and black springs on the composite.
Or vice versa.
Old 05-24-2007, 10:41 AM   #3728
I just talked to a buddy who use's a Speed VZB, He said you really can't detune that motor. "It's mad fast" he refered to it. He said it's overkill for the 8, but if you want it in the 8 you gotta be smooth and run 20% in it. Hopefully someone else will have some idea's.
Old 05-24-2007, 10:47 AM   #3729
kjuliussen's Avatar
Ok. maybe i should install a milder engine.. LOL.
But what about that pipe i'm using. is there any other pipe i can use to gett less power out of the engine?
Old 05-24-2007, 10:50 AM   #3730
Stick with the pipe, It looks like a good universal pipe. You could probably find a good os Rg for as much as a new pipe. Just keep the Speed for large,hi traction track's.
Old 05-24-2007, 10:53 AM   #3731
kjuliussen's Avatar
I got a little dent in the pipe. the exhaust outlet is pushed a little back and in.
Do i have to replace the pipe or does'nt it matter?
Old 05-24-2007, 10:56 AM   #3732
kjuliussen's Avatar
But i will try the all composite shoe setup.
Is that with the softest springs?
Old 05-24-2007, 11:00 AM   #3733
Insert a phillips head screwdriver that is as big as the stinger, Then slowly pull the stinger back out. You might want to warm up the dented part with a blowdrier if it's cold.
Old 05-24-2007, 11:02 AM   #3734
The all composite shoe's is what i use with a diffrent (3 shoe) clutch set up. I dont know if it will work in the Losi set up.
Old 05-24-2007, 11:51 AM   #3735
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
2 alum 2 carbon
green on carbon and (sorry i cant rememberr the alum...but it is one softer than kit....gold or silver)
it is what i use....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
