Losi 8ight building and setup
#3677
Originally Posted by Jack Smash
I just got a O.S. V-spec and was wondering about the head shimming. It comes with one shim installed and one extra, should I use the extra shim for 30%?
#3678
Originally Posted by freefallmarine
Anyone use the OS Speed Vzb?
#3679
Originally Posted by xlgraphicspro
learning how to paint well has paid off and saved me alot of money. But I got burned out painting for other people, so now I paint on a limited basis. I've got better things to do with my time. It's easy if you do a few simple tasks
1. think about your design and draw it on the body
2. Use liquid mask
3. learn how to cut straight " not crooked, " lines
4. learn to lay down darker colors first
5. master the art of shadowing
6. use materials from everyday life to create cool effects , Checkered Cabinet liners make great carbon fiber effects
Ok back to a relivant topic
Has anyone had problems with their ball links being super tight?
I was plagued last weekend throughout qualifying by traction rolling, turned out that my rear tie rods and ball ends were super tight and wouldn't let my suspension rebound properly.
Because of that I ended up "BQ", I fixed the problem and bumped up to the A, but I loosened my links too much, and one popped off half way through. I managed to get it back on and still finished 5th.
I'm going to buy some new ends tonight and replace all my old ones, I was just wondering if anyone else has experienced this?
2. Use liquid mask
I seem to have the opposite issue...mine ball ends wear out very fast (or I break them). They are the only things I have broken in about 4 gallons of track time (aside from bearing wear...the bearings in the hubs are wearing and I am getting quite a bit of slop)
#3680
Think Im going to take the aluminum brace's off and put thre plastic one's on for a try at the next race. Anyone out there still running the plastic brace?
#3681
#3685
I like the stock shock oil set up with the #54 7shock piston set up. Im going to switch the chassis brace's tonight.
#3686
Originally Posted by mbunker
Does anyone know what the thin white o-ring that comes in the parts bag with the clutch hardware is for? I've search this thread and didn't find anything. Looked in both the 8B & 8T manuals and didn't see it.
Thanks,
Michael Bunker
Thanks,
Michael Bunker
#3687
Spare white oring, mistake? Man, maybe that's why im in the B....Let's see....what part of the car did i put it???????
#3688
Originally Posted by air8
On Neo-buggy, Adam Drake said that they were in there by mistake and you don't need to use them. Weird to me?
#3690
Hey,Trebor You know that o-ring i sent you to make your car faster??? Don't use it. hehehe.....Man it's earley......
