Losi 8ight building and setup
#3631
I still use the power switch. What about everybody else?
I'm going on gallon 7 and never have greased the CVDs. I figured it would attract too much dirt. Around gallon 4 my front set screw did come undone. Red loctite and heavy duty heatshrink that has adhesive inside. It has not moved. I am about to replace the front CVD and outdrive into the front diff. I can't believe the CVD and drive have lasted this long with no maintenance. Chalk one up for the 8ight on durability.
#3632
Beware of certain on/off switch's. There are tall and short one's. I had a regular size airtronic's in my 8 and it pinched the wire's coming in from the servo and transponder. If you can, find a short height switch. like the one's the rtr come's with. And becarefull when you install switch's with the extra lead(charging jack) it's tight but it will fit. Take your time and and organize the wire's and you'll be able to "set and forget".
#3636
I have some info.....
I don't use switches either. They are very prone to failures and me leaving them on. The latter being the bigest reason.
I use the CVD covers from A-Main. They do work good. I cleaned my CVDs out real good and used a little red loctite and they were good to go. I saw the condoms and had to get them. Great product!
Clunk?? You need to replace your fuel line and make sure it is cut straight.
Thanks for the servo horn info.
I want to drive your truck Carl. That thing looks awesome. Haven't driven truck in a while.
I like pancake bunnies too!
TEX
TEX
#3637
CVD "condoms" are the way to go!
Tex-Where did you see Carls truck? Now I have to go searching.
I was thinking about putting a fuel filter on as I havent already but would like some opinions and if yes which one(s), Do I want one with the resonator thingy in it?
#3638
Originally Posted by air8
Oh yeah, has anyone had problems with the clunk in the fuel tank falling off? I can't think of a good way to keep the bronze filter attached to the nipple in the fuel line. My last attempt was CA glue. it stayed on for two weekends.
#3641
Originally Posted by pink_sleeve
does anybody know if the protek or commonsense lipo rx packs amain is selling fir in the 8 rx box with no mods
#3642
Im just showing off...hehe..A great pic from a great photographer Tad, from Tulsa Racing Club.
#3644
#3645
Originally Posted by trebor
FreeFallMarine--Nice, "The Swirl" Hey, do you run the aluminum rear bearing inserts? I bought a set of the plastic ones and gave them to my cousin because hes got tons of 7075 and he said he is gonna make me a set. Hopefully they come out alright because Im trying to smooth out the rear a little bit.
