Old 05-16-2007, 08:01 AM   #3511
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Originally Posted by Themajorhobby
air8 - One easy way to check the outer pins is to insert your wrench into the head and spin the pin, if the nut is too tight it will be hard to turn, and if the pin is bent, the hub will wobble really bad. Check that after every run.
To check if a hinge pin is bent - I prefer to take it completely out... take two allen drivers in my hands and make a level surface between the two to set the hinge pin on. Then I rock the drivers back and forth to cause the hinge pin to roll back and forth along the drivers. By watching it roll - you will easily be able to tell if its bent or not.
XMSRacing is offline   Reply With Quote
Old 05-16-2007, 08:02 AM   #3512
RBMike's Avatar
I did not come from the R but I did come from the pro-spec. I think the Losi is better than the Pro-spec for my driving style. I have run the R & feel it is a great improvement over the pro-spec. Had I owned an R, I may not have gone to the Losi or at least it would have been a much tougher decision. Bottom line, Both great cars. The decision to me is more about driving style & "the feel" you like in your car. The Losi is also lighter & I like light cars.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 05-16-2007, 08:05 AM   #3513
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
when one is bent it binds the whole rear end up
pink_sleeve is offline   Reply With Quote
Old 05-16-2007, 08:05 AM   #3514
R40Victim's Avatar
Neat idea, but it's alot easier to just roll it back and forth on a flat glass surface...lol I just checked mine after 7-8 months, and countless runs and impacts... they are still perfect.
R40Victim is offline   Reply With Quote
Old 05-16-2007, 08:38 AM   #3515
you can also spin the pin with your wrench and see if the hub moves around while you are turning the pin.
T Green is offline   Reply With Quote
Old 05-16-2007, 08:56 AM   #3516
XMSRacing's Avatar
I haven't bent one yet either. And for laughs I've got a Lunsford one in one side - and a stock one in the other. Both are still perfect.
And yes - you can just roll it on a flat surface. But I have found that not all heads of fasteners are on it perfectly true. And I reall dont care if it is - as long as the rest of it is straight. Call me anal. lol
Old 05-16-2007, 09:30 AM   #3517
trebor's Avatar
I bought the Lunsford pins but havent had to use them yet. Do you think I should change them anyways?
Anyone know when the aluminum rear bearing inserts should be ready?
trebor is offline   Reply With Quote
Old 05-16-2007, 09:55 AM   #3518
maybe july
Old 05-16-2007, 10:13 AM   #3519
XMSRacing's Avatar
I'd just run it the way you have it.
Old 05-16-2007, 10:18 AM   #3520
trebor's Avatar
Thats what I figured. Thanks.
PINK SLEEVE- JULY??? Are you serious? aluminum rear bearing inserts?
Old 05-16-2007, 10:21 AM   #3521
i work at a hobbyshop and horizon's expected date is 6/28 and anytime the expected date is an even number it's just a guess not a solid date so i'd say maybe in july . i don't know why fioroni or king headz isn't just making them
Old 05-16-2007, 10:26 AM   #3522
Todd has it right, no need to remove the pin to see if its bent, just spin it with the hex driver. on e clip pins, the above mentioned methods are good, but no need to with the captured, your hubs will do a dance if the pin is bent at all.
Themajorhobby is offline   Reply With Quote
Old 05-16-2007, 10:30 AM   #3523
trebor's Avatar
Well that stinks, thanks for letting me know.
I wish they would make them too.
Old 05-16-2007, 10:39 AM   #3524
maybe if enough people emailed them they would kingheadz@kingheadz.com
Old 05-16-2007, 10:52 AM   #3525
trebor's Avatar
Good Idea. Just did, maybe we can get enough people to put a request in it might happen. I like KHZ, they make real nice products.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
