Old 05-09-2007, 07:24 PM   #3406
Born2Lose's Avatar
Default LEAKY SHOCK O-rings
My front shock o-rings are leaking.should i replace them w/stock ones or does someone make an upgraded set? ---Thanks to repliers !
Born2Lose is offline   Reply With Quote
Old 05-09-2007, 08:04 PM   #3407
freefallmarine's Avatar
If you replace it with a losi set, make sure the oring's white instead of black. These are the new up-graded o ring's. If you go an alternate route, then try tkocompetitiondev.com These are the one's im currently using with good sucess.
freefallmarine is offline   Reply With Quote
Old 05-10-2007, 05:55 AM   #3408
Panther's Avatar
Send a message via AIM to Panther
If you're in a pinch and don't have time to get new o-rings, use a clutch shim and place it on top of the o-rings when re-assembling the shocks. I had to do that and it's worked great so far.
-Seann
Panther is offline   Reply With Quote
Old 05-10-2007, 07:45 AM   #3409
R40Victim's Avatar
And green slime them! I've been using that stuff with the stock o-rings, and as long as your shock shafts are in good shape, they will work.
R40Victim is offline   Reply With Quote
Old 05-10-2007, 10:06 AM   #3410
How are the Losi Aluminum shock towers vs. the plastic ones? Are they bending on bad flips or are they a lot better than the plastic ones?
Thanks,
-Mike
Bohh is offline   Reply With Quote
Old 05-10-2007, 10:23 AM   #3411
Thanks,
-Mike
Do you mean the chassis braces?
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 05-10-2007, 10:23 AM   #3412
SlobbaTech's Avatar
Plastic shock towers....on an 1/8 car???? The 8ight aluminum shock towers have held up great, the only thing I've seen/noticed on anyone's car is the anodize wears off at the top from rolling the car over.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 05-10-2007, 10:26 AM   #3413
No the shock towers. Maybe I'm confused, does the RTR come with plastic shock towers and the kit come with aluminum? But while we're at it are most of the optional aluminum upgrades going to hold up better on a rough track and take hard hits better than the plastic ones?
Thanks,
-Mike
Old 05-10-2007, 10:34 AM   #3414
Kcdzim's Avatar
Send a message via AIM to Kcdzim
Thanks,
-Mike
The RTR car comes with stamped aluminum towers, the kit comes with hard anodized machined aluminum towers. The RTR kit also has plastic shock caps, while the kit has aluminum caps. These are probably the first upgrades to make from RTR to Kit standard.
The one option part that I've heard is worth the time is the hard ano aluminum bearing inserts for the rear diff. Other than that, the kit is pretty much good to go. The aluminum chassis braces aren't very helpful on rough track, and it wont be the kit parts that have "upgrades" that you're going to break first. It's more likely to be hinge pins, shock shafts and that sort of thing.
Losi 8ight 2.0 Associated SC10 Associated RC10T Xray T3 2011
Corally RDXΦPhi Vintage Transam
Professor Z Graphics
Kcdzim is offline   Reply With Quote
Old 05-10-2007, 10:39 AM   #3415
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
to bad you can't get the bearing inserts anywhere . does anybody on here have a set they want to sell . if so i'll take them
pink_sleeve is offline   Reply With Quote
Old 05-10-2007, 08:31 PM   #3416
Nitrohouse.com has them.
Old 05-10-2007, 08:36 PM   #3417
not in stock . they just don't have real time inventory on there site because you can put 400 for the quanity and it doesn't say out of stock
Old 05-11-2007, 01:31 AM   #3418
SO, sorry about that. i went as far as the check out and it didn' say out of stock. I didnt know they didnt keep live inventory. my bad.
Old 05-11-2007, 04:55 AM   #3419
Yeah, put an order at nitrohouse for bearing insert.
No news from them at all...
I'm trying to search them in the UK.
Nicolas
kawaz is offline   Reply With Quote
Old 05-11-2007, 06:03 AM   #3420
alb
Trader Rating: 19 (100%+)
Is there any difference between the RTR and kit engine mounts? Not sure if the rtr mounts are taller to accomadate the roto start.
alb is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
