Old 05-07-2007, 10:25 AM   #3361
MannEdge's Avatar
Trader Rating: 19 (100%+)
I am almost done putting the kit together, did you guys use the servo spacers. I used the grommets.
Manny
Rcgroups feedback -
http://www.rcgroups.com/forums/traderratings.php?u=78357
MannEdge is offline   Reply With Quote
Old 05-07-2007, 10:31 AM   #3362
Anyone got a good setup for a very loose track?I was struggling to get any power down exiting the corners i was spinning out most of the time.
Would i be better changing the rear diff oil or buying optional squat plates etc (what difference do these optional parts from m2c racing make).
Any help would be much appreciated
damo666 is offline   Reply With Quote
Old 05-07-2007, 10:44 AM   #3363
air8's Avatar
Using a lighter clutch spring might help. The power won't be so abrupt. I use two green and two black on our outside track, dusty and hard packed.
air8 is offline   Reply With Quote
Old 05-07-2007, 12:55 PM   #3364
Damo you can't go wrong with that M2C toe block that Mitch sells. It's very nice and bind free.
Try running two greens and two silver clutch springs. It will engage a little lower in the power and hopefully reduce your wheelspin a little.
Good luck...
cwalters is offline   Reply With Quote
Old 05-07-2007, 02:27 PM   #3365
How has the throttle servo's been holding up? I've been talking to people at my local track and they are still burning servos up. It looks like most people here have the problem fixed. Are the people I'm talking to doing something wrong?
Very close to buying an 8ight, that's why I ask.
Thanks,
-Mike
Bohh is offline   Reply With Quote
Old 05-07-2007, 02:29 PM   #3366
R40Victim's Avatar
Read back through this thread, all the anwsers you're looking for are here.
R40Victim is offline   Reply With Quote
Old 05-07-2007, 02:45 PM   #3367
Right i will try the different clutch shoes but what about the m2c squat/toe plate?
Which ones should i get for a loose track?
thanks
Old 05-07-2007, 02:45 PM   #3368
RBMike's Avatar
-Mike
Yes
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 05-07-2007, 02:47 PM   #3369
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
I'm also a believer in the fact that you can't put crappy servos in it. I setup my JR 590 the exact same way I setup the JR 9000T's that are in it now. But I haven't had a single issue with my 9000T's. I'll be putting these things in my 8ight T as well.
XMSRacing is offline   Reply With Quote
Old 05-07-2007, 02:51 PM   #3370
Its defiantly how you set up the linkages.A lot of the pictures i have seen of others racers 8ights who are burning servos the linkages look way off.I set my throttle first then adjusted the brake accordingly.
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
Old 05-07-2007, 02:53 PM   #3371
Anyway back to the loose track setup.Anyone got more tips apart from clutch springs?
CRT.5 SH .12,
Old 05-07-2007, 02:57 PM   #3372
22Racer's Avatar
Trader Rating: 67 (100%+)
The hole in the servo arm that the thottle shaft slides in seems a little tight and might bind. I'm going to drill mine out, it could be alot bigger and still work fine. We finally had some throttle servo issues yesterday but the servo's work fine today. Are most guys having trouble on really rough tracks? this was the roughest we've raced on so far.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 05-07-2007, 02:57 PM   #3373
freefallmarine's Avatar
what's your current set up? Including tire's ,motor, pipe.
freefallmarine is offline   Reply With Quote
Old 05-07-2007, 03:16 PM   #3374
Standard kit setup,Rb ws7 III,Hn 2027 eureka pipe,Tried a few different tires but not much difference.
CRT.5 SH .12,
Old 05-07-2007, 03:26 PM   #3375
Davidka's Avatar
Trader Rating: 75 (100%+)
Lighter center diff oil, softer swaybars.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
