Old 04-29-2007, 09:30 PM   #3196
Trader Rating: 58 (100%+)
Default clutch
dont misunderstand... I compliment the clutch design, i just think the button head screws need to be revised.....
gporta77 is offline   Reply With Quote
Old 04-29-2007, 09:36 PM   #3197
GTB_USER_Erik's Avatar
No, I understand. After lok-tite and tightining down I have needed to cut slots in them just too remove them.
GTB_USER_Erik is offline   Reply With Quote
Old 04-29-2007, 10:36 PM   #3198
tex1's Avatar
Send a message via Yahoo to tex1
Wink
GTB -
I work with T&T Hobby in Plano, Tx.
Nice shop with lots of know how in most all areas of racing. I have been around Joe for more than 20 years. This guy was racing 1/8 onroad World caliber since the mid - 70s. I race every week with him now in 1/8th off road.
Fun stuff!
Carl -
Shocks need revising to make them less maint.
Steering servo horn.
Batt box should be bigger.
Better rear outer hinge pins.
Wish I could go to half degree toe measurements w/ different rear uprights.
Fly wheel needs larger surface for starting boxes.
Split center diff mount. Although they have it very tight now...??
This is not a rant. I do love this car! Just seems like I have to run maxed on my settings to get the car right. Who knows what would happen if there were more adjustment available?
Front caster adjustment.
More fine rear toe adjustment.
Refined radio tray with enclosed servo on the throttle.
But hey, that is what R&D is for.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 04-29-2007, 11:46 PM   #3199
CaseyP's Avatar
If you guys are interested....when I install the clutch pin/screws I use one dab of blue locktite, then only tighten them untill they stop with very little force. just a tiny bit more than hand tight. then you can get then back off with out stripping the heads.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 04-29-2007, 11:47 PM   #3200
CaseyP's Avatar
I too would love to see a 2 peice center diff mount.
Old 04-30-2007, 12:27 AM   #3201
freefallmarine's Avatar
I have a feeling there's going to be a revised car soon.
i know we were the ultimite test subjects and up to date revision's should follow.
freefallmarine is offline   Reply With Quote
Old 04-30-2007, 06:31 AM   #3202
sport10's Avatar
This is similar to how I do it and do not have a problem with stripping the hexes on the pins. I use a dab of blue locktite and just screw it down to flush with the clutchbell. DO NOT TORQUE. This way they come out easily and the locktite keeps them from backing out. Works great.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 04-30-2007, 07:24 AM   #3203
trebor's Avatar
Well I had the problem with my flywheel and couldnt get them off for the life of me. We tried to dremel a flathead to get them out. I had to go to LHS and they even tried everything but nothing worked. Obviously they didnt have another flywheel and everywhere is backordered so I was left with the option of not running or buying a Mugen Clutch on a OS .21 RG. So I got the Mugen clutch and put it all together and when I went to line it up on the chassis it wouldnt line up for the hell of me, we used everything and finally got it but the screw holding the clutch was right up against the fuel tank so I didnt want to take the chance of damaging anything with the 8ight flexing and all so I took it off. Oh, I tried each of the 8ight, mugen, and Ofna clutchbells.
So basically I need somebody to please help me make a mugen clutch work a OS .21 RG?
trebor is offline   Reply With Quote
Old 04-30-2007, 07:48 AM   #3204
RBMike's Avatar
Ummmm, I'm using the Mugen clutch right now & it fits fine. Last week I used it with a Losi clutch bell & this weekend I used it with a clutch bell from Robinson racing. Both worked fine on a C6.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 04-30-2007, 07:56 AM   #3205
trebor's Avatar
ummmmm, well why dont you give me a little clue in how you did it? I am trying to use it with a OS .21 RG.
Old 04-30-2007, 08:58 AM   #3206
Davidka's Avatar
Trader Rating: 75 (100%+)
I am using a Mugen clutch with a Werks engine and a Losi bell. Mine works with little fuss but I could see the need to put a shim behind the collet to space the flywheel farther forward. The Losi specific bell is key, it reaches farther off the front of the engine. It sounds like you may have pushed the engine forward to get a Mugen bell to reach?
Old 04-30-2007, 09:38 AM   #3207
RBMike's Avatar
Ummm,
1) I put the Mugen collet, flywheel & clutch on the motor.
2) I put the clutch bell on the clutch.
3) I put the motor in the car.
4) I ran the car.
That's my tricky secret.
Seriously: I used no tricks. I just put it in and it's fine. The only roblem I had was my C6 blew a bunch of teeth off the Losi CB so I got a Robinson Racing CB. I have to say the Robinson racing bell is way beefier than the Losi one.
-B44 (Novak)
Old 04-30-2007, 09:55 AM   #3208
R40Victim's Avatar
So, you used the Losi clutch bell, and NOT the Mugen clutch bell, right? Is that the problem, you have to use a Losi clutch bell?
R40Victim is offline   Reply With Quote
Old 04-30-2007, 10:06 AM   #3209
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
Yeah I ran the Jammin flywheel setup on mine. All I had to do was put 2 washers behind the flywheel collet and you also have to use the Losi clutch bell.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 04-30-2007, 10:32 AM   #3210
Also, taper the pins by just barely by sanding the edge and rotating the pin, this helps the pin slide into the bottom of the flywheel while the pressure of the spring is there.
Themajorhobby is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
