Old 04-25-2007, 09:32 AM   #3136
trebor's Avatar
Originally Posted by R40Victim
The stock setup works great, no need to change it.
is that to me?
trebor is offline   Reply With Quote
Old 04-25-2007, 09:57 AM   #3137
Originally Posted by satoch
I have raced nearly every weekend for over a year and have had no problems in either the buggy or truggy. I couldn't be happier. All of my servo problems ended the day I got rid of my Airtronics 357 & 358 and went Ace DS1313 & DS1015 on throttle/brake and steering respectively. The 2000mah li-po pack is a godsend also.
Which Rx pack are you using?
antman450 is offline   Reply With Quote
Old 04-25-2007, 10:23 AM   #3138
MannEdge's Avatar
Trader Rating: 19 (100%+)
I would like to go to li-po down the road. Could you provide a pic of your setup?
Thanks,
manny
Rcgroups feedback -
http://www.rcgroups.com/forums/traderratings.php?u=78357
MannEdge is offline   Reply With Quote
Old 04-25-2007, 10:32 AM   #3139
air8's Avatar
http://www.amainhobbies.com/product_...oducts_id/9019
OK. Since the Losi starter box doesn't come out for another month here is my plan. The motor above will go into my 8. I have only been club racing at several different tracks. Will this motor be decent for 5 weekends worth of racing? I am buying my 8T tomorrow and the RTR motor from the 8 will go on the truggy. I don't want to buy all the stuff to start two vehicles and then get the losi box in a month. My main question I guess, is does anyone know what I should expect from the OS pull start above. I will have to suffer with the spin start until the starter box comes out. Any remarks or opinions?
air8 is offline   Reply With Quote
Old 04-25-2007, 10:33 AM   #3140
air8's Avatar
I forgot to write that when the starter box comes out, I will step up to good power plants then. Thanx
Old 04-25-2007, 11:17 AM   #3141
R40Victim's Avatar
is that to me?
Yes
I am going to start putting the kit together tonight. Any last tips for me? I have the steps for the throttle setup, but any tips for the diffs, if any?
Get a drill or power wrench, I took 3 days to build mine because my wrists got tired installing screws deeply into plastic. Follow the added instructions on the throttle servo setup, and read through this thread, there's lots of useful info.
R40Victim is offline   Reply With Quote
Old 04-25-2007, 11:21 AM   #3142
R40Victim's Avatar
That's a great motor, but if you plan to use a starter box, you can't use that motor without changing the backing plate, which might mean you'd have to use a dremel and grind the tip off the back of the crank for the new plate to work. Then you'd have to get the motor mounts from the kit, or aftermarket mounts that bring the motor down far enough to work with a starter box.
Old 04-25-2007, 12:49 PM   #3143
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
just buy another brand starter box....
killer89 is offline   Reply With Quote
Old 04-25-2007, 02:05 PM   #3144
trebor's Avatar
yeah, like the
Mugen BII *NOW in gunmetal grey
Old 04-25-2007, 04:01 PM   #3145
http://www.all-battery.com/index.asp...ROD&ProdID=972
I had to cut the back of the battery box and let it hang out a little bit but it's well worth it. It's a 2 cell and is properly wired for balancing.
I tried the HT Batteries HT220. It fit but it didn't last. It's got 4 individual cells that are wired series/parallel to get the voltage and mah but improperly wired for balancing. Since each cell can not be balanced individually it just doesn't last.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 04-25-2007, 07:37 PM   #3146
trebor's Avatar
What are we using for sway bars?
Old 04-25-2007, 08:20 PM   #3147
Suspended
Send a message via AIM to Nay0k
2.3mm generally works well in the front.
2.6mm for smoother tracks, 2.3mm for rougher tracks for the rear generally works ok for me..
Nay0k is offline   Reply With Quote
Old 04-25-2007, 08:57 PM   #3148
Fast question
What tire compound are most people running outdoors?
Dusty,Hard packed, clay/dirt
soft or super soft or maybe M2, M3
Which foam inserts are being used?
Also what is the tire compound chart for Proline?
M2
M3
XTR?
kyracer is offline   Reply With Quote
Old 04-25-2007, 09:10 PM   #3149
R40Victim's Avatar
M3 Crimefighters on hard packed clay, medium or harder inserts. Best thing to do is experiment. I have one of each of the several major patterns available, and try them when track conditions change. M3 CFs work well for me, but wear out too quickly, so most of the time I run the M2s.
Old 04-25-2007, 09:16 PM   #3150
So are the M2's softer then the M3 compound?
What is the softest to hardest in Prolines?
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
