Old 04-23-2007, 09:14 PM   #3106
Trader Rating: 11 (87%+)
I tried to use a differant clutch on my 8 buggy i had a problem with the clutch bell not reaching the center diff is there a after market motor mount out there that will let you get away from the stock one
srs64 is offline   Reply With Quote
Old 04-24-2007, 12:39 AM   #3107
Is that new Losi starter box for the 8/8t out yet? Anyone have info on this? Thanks in advance
mikezap is offline   Reply With Quote
Old 04-24-2007, 03:21 AM   #3108
Matt Howard's Avatar
Originally Posted by Born2Lose
Hey Ronnie that link wouldnt work ? Could you tell me some info on it please!
It worked for me, it's a rather large PDF file explaining how to set up your throttle and brake linkages on the 8ight so you won't fry servos. there were probably 5-6 8ight's running in Omaha last week and no one had any servo problems. I'm going to try and make it out to Lincoln next week so if your there look for me and I'll try and help you out
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-24-2007, 04:25 AM   #3109
colonrc's Avatar
Originally Posted by damo666
Heres my new losi 8 with Jim hottinger (hotmod) Novarossi plus 21 / 5.
Dude I like your rear drive shaft (CVD)protector do you custom made those?
Serpent U.S.A , Maxy's Pro Racing Fuel , Murnan Modified Motors,Nexus Racing,Mike Desing,Member of GO-R/C
colonrc is offline   Reply With Quote
Old 04-24-2007, 04:43 AM   #3110
My throttle servo crapped out on my 4th tank of fuel ! what a crock !!!
Hum, almost 2 gallons through my eight and no servo problem.
Use servo gommets, and king headz plate.
The servo does not touch the frame.
Setup is done correctly (be careful with EPA).
Setup is the issue for servo problem.
No heard of any problem here in France.
Nicolas
kawaz is offline   Reply With Quote
Old 04-24-2007, 06:08 AM   #3111
tex1's Avatar
Send a message via Yahoo to tex1
Red face
SRS64 - You can use other clutches on the 8ight. You need to use the Losi clutchbell though. You can change the bell but you would probably want to go with something like the King Head motor mount. It has an option to move your motor forward 2+mm. I don't like doing this due to it making you run the carb at an even more extreme angle. You will have problems with you throttle servos if you are not extra careful.
Just run what ever clutch you want and use the Losi bell. Clean the rear bearing out and lightly oil it and you should be fine.
We have Mugen, Kyosho, Werks and Losi clutches in all of our cars. All of the guys are using the Losi clutch bells and they work great.
Good luck!
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 04-24-2007, 06:54 AM   #3112
amen Kawaz, the car is not to blame for the servo issues. Some cars are a little more forgiving as far as servo setup goes. On the 8ight it is very important you take your time and setup the linkage correctly. A good throttle servo doesn't hurt either. Maybe someone could link Supermaxx Rich's explanation and guidlines here for people who are having problems. I have it in my favorites but don't know how to link it???
cwalters is offline   Reply With Quote
Old 04-24-2007, 07:27 AM   #3113
trebor's Avatar
CWALTERS-
or ANYBODY- Hey, if you could email me how to setup the linkages that would be awesome. Im still new to this and I still have lots to learn. The reason Im asking is because my motor mounts apparently loosened up and it caused my clutch bell to get chewed up so I had to reallign the motor and it seems the ball cup on the carb is pushed more toward the brake and I know its probably not a good thing but that is how I had to finish the day. But if anybody has a link or anything on a lesson about the linkages it would be great. Or send to me at desireegianna@yahoo.com Thanks.
trebor is offline   Reply With Quote
Old 04-24-2007, 07:57 AM   #3114
tomdav's Avatar
Trader Rating: 42 (100%+)
Losi 8ight building and setup
OR go to losi site.
http://www.teamlosi.com/ProdInfo/Fil...e_Addendum.pdf
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 04-24-2007, 08:02 AM   #3115
Hi,
I'm considering getting an 8ight and was told that they require a lot more maintenance than other 1/8 scale buggies. Is this true? If so what kind of stuff is that in reference too?
Thanks a lot,
-Mike
Bohh is offline   Reply With Quote
Old 04-24-2007, 08:58 AM   #3116
trebor's Avatar
Tomdav- Thanks for the link.
Bohh-I honestly think ALL 1/8 need alot of maintenance. But personally I like it! Its what makes it part of the hobby. Cant just expect to buy one and it to be bells & jewels. And it was probably someone that doesnt own an 8ight that said that. The 8ight has already proven to be the one of the best 1/8 buggy. And maintenance is guaranteed no matter what you get. The 8ight definitely would be a good choice for a durable buggy.
just my .02 cents.
Old 04-24-2007, 09:10 AM   #3117
I agree, all buggies need a lot of maintainence if you race and plan on finishing races.
I'm constantly amazed at the "bad luck" of certain racers who have terrible maintainence practices. Every week it's something going wrong for them and yet I very rarely have anything break during a race.
If I do, it's always because I was lazy and didn't catch a problem before it cost me a race finish.
That stated, the Losi 8 shocks are the best and worst part of the vehicle IMO. They have to be checked after every qualifier.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 04-24-2007, 09:46 AM   #3118
trebor's Avatar
Satoch-How do you like the ACE servos?Any problems yet?
Old 04-24-2007, 09:48 AM   #3119
i have to say the car is just as bad for maintainence as any other car, i use the same prep method on this as i have on all my cars.
My only gripes with the car are the original shock seals and the center diff mounts are solid not split. The shocks are easy to cure using aftermarket seals (think there tko). The center diff mounts could be cured with aftermarket alu versions but i think losi could have made a much better moulded design something like the jconcepts bj4.we slipper mount
chuckyegg is offline   Reply With Quote
Old 04-24-2007, 10:01 AM   #3120
MannEdge's Avatar
Trader Rating: 19 (100%+)
Originally Posted by tomdav
I am getting my 8ight today or tomorrow. I got my starter box yesterday - Mugen Pro Starter BII 1/8 Off-Road 1/10 Touring A lot of parts.
My came in the grayiest color. Now, I am ok taking it out at the track.
Manny
MannEdge is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
