Old 04-22-2007, 09:00 PM   #3091
trebor's Avatar
Originally Posted by Born2Lose
Im planning on buying an 8 rtr in a few weeks. Can anyone tell me what parts I should get with it to get it ready for the track. Or is that baby ready to go racing!
Get some kit shock towers as the ones on the RTR bend wicked easy. Trust me I have a RTR that is pretty much the kit now. But it doesnt really matter because outta the box is top-of-the-line buggy and has got to be the best RTR ever! With the DX2 and 2 spektrum receivers is an awesome deal. Go have fun!!!
trebor is offline   Reply With Quote
Old 04-23-2007, 05:08 AM   #3092
trebor's Avatar
Does anybody use a Team Orion V6 clutch system? in a OS RG? or a GO.21? or any motor? I want to put it in the 8ight but would like a little insight first. Thank You.
Old 04-23-2007, 06:47 AM   #3093
tex1's Avatar
Send a message via Yahoo to tex1
Wink
TREBOR -
If you have not purchased that clutch yet you might want to consider the Works version. The Orion clutch is not made correctly and has some consistancy issues.
The Works clutch uses 4 shoes. We like the combination of 2 carbon and 2 roulon shoes. Use the gold spring and set the nut to 1.75 mm from flush with the end of the nut.
You will soon find out why all the top onroad racers use roulon in their clutches where they have max traction as well as max horsepower. When set properly you will run a whole season without changing shoes.
JRR -
Your carb barrel is sticking! They do not like to be pulled in a non-linear manner. Some brands are very sensitive to being pulled straight. Take it to a proshop and show them your setup. Tell them you want to get it as straight as possible where you are not pulling accross the motion of the barrel. If you can't get it figured out then you need to get some pictures up so we can help better.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 04-23-2007, 07:02 AM   #3094
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
thanx for the help. when i go into work today at rc performance and hobbies in madison wisconsin i will take a look at it and get'r straitened out. is it that the barrel is just that out-of-aligned from the factory or is it just me?
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 04-23-2007, 07:27 AM   #3095
KARO's Avatar
This is by far the fastest buggy I've ever driven! I raced outdoors for the first time and it was great. I can push this car really hard and it's very easy to control. My average lap was more than two seconds faster than anyone else in the A. The fastest lap compared to my average was also only 1/2 second apart (pit stop included) in a 10 minute main. I could only race indoor offroad a few times in the last half year and didn't do bad but it wasn't all that great (setup wasn't too good). I've relied alot on this forums good info and tips the past couple weeks to get the car ready for outdoor. I started with the Truhe Nitro Challenge setup and changed the center diff oil, rear swaybar, fr & Rr droop, drilled pistons, shock oil, +2 hubs & clutch springs...Ok, I guess that's alot of changes but the car did get faster every round. I'm starting to really learn setup changes and their effects after 5 yrs of racing. Thanks
KARO is offline   Reply With Quote
Old 04-23-2007, 12:21 PM   #3096
Got a question about tires for the 8B I'd like to ask the guys from CA, AZ, TX. Yesterday out track in Joliet, IL was as dry, blown out and chunky as the pictures I've seen of some of your tracks during the A-mains.
I've been to Johnny Cool Guys in Euless,TX with 103 Degree weather and no track watering at the 2005 USMTC race and the track was like that.
What buggy tires/foams are you guys running that last more than one or two races? I'm thinking Knuckle 2.0's or Gecko's. Thanks
Link to some amazing picks of the track and racing: http://www.chitownrc.com/showthread....184#post149184
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 04-23-2007, 12:33 PM   #3097
trebor's Avatar
TEX1- Thanks for the info. Im gonna check it out now. Did you go to Tulsa races that just went by?
Old 04-23-2007, 03:45 PM   #3098
Trader Rating: 83 (100%+)
Tex1,
What clutch bell do you use with the werks clutch? Can you use a stock Losi or Aftermarket?
mrhenning11 is offline   Reply With Quote
Old 04-23-2007, 04:55 PM   #3099
Default My new losi 8 with hotmod 21/5
Heres my new losi 8 with Jim hottinger (hotmod) Novarossi plus 21 / 5.
damo666 is offline   Reply With Quote
Old 04-23-2007, 05:00 PM   #3100
trebor's Avatar
Originally Posted by mrhenning11
Tex1,
Can you use a Robinson Racing bell?
Old 04-23-2007, 05:40 PM   #3101
weezer23's Avatar
Just wondering if anyone has mounted the 8ight kit step pins to proline or other wheels besides losi wheels, or are they only made to be used with losi wheels?
weezer23 is offline   Reply With Quote
Old 04-23-2007, 06:27 PM   #3102
tex1's Avatar
I always use the Losi bells. You can use them on any clutch setup. You just have to shim them correctly.
I have not had a problem with them at all.
The Losi bell allows me to keep the motor futher to the rear so I don't change the handeling or mis align the carb. I like my stuff nice and straight.
TEX
www.indyrcworld.net
(972) 271-4844
Old 04-23-2007, 06:43 PM   #3103
Born2Lose's Avatar
My throttle servo crapped out on my 4th tank of fuel ! what a crock !!!
Born2Lose is offline   Reply With Quote
Old 04-23-2007, 07:14 PM   #3104
Ronny.A's Avatar
Follow this;-) http://www.teamlosi.com/ProdInfo/Fil...e_Addendum.pdf
Ronny.A is offline   Reply With Quote
Old 04-23-2007, 07:59 PM   #3105
Born2Lose's Avatar
Hey Ronnie that link wouldnt work ? Could you tell me some info on it please!
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
