Old 04-19-2007, 02:59 PM   #3046
jallshouse's Avatar
Send a message via Yahoo to jallshouse
Originally Posted by trebor
Does anybody use the carbon mudguards from TKO Comp. that protect your hubs and axles?
i havent seen these yet....do you have a link?
jallshouse is offline   Reply With Quote
Old 04-19-2007, 04:26 PM   #3047
freefallmarine's Avatar
I think its tkocompetitiondev.com
freefallmarine is offline   Reply With Quote
Old 04-19-2007, 06:09 PM   #3048
air8's Avatar
Default the car will handel poorly. eather traction roll or push.
My car does push. I thought it was my servo saver too loose. I tightened that up a lot, steering seemed to come back a little. But that was in the main when I figured that out. The next day the push was back. It is very slight. I practiced a little today and I think I am getting on the throttle too soon. If I baby it around the corner it does well. But over 1/4 throttle and it feels like a tank. The other guys just seem to have such a responsive steering setup. I haven't driven them personally. But they get out of the corners much better than me. I have reduced droop 3mm in front, +2 toe out front, 3T3A rear plate, 54 front pistons w/40 Losi oil. I have been racing this car now for about three mo. indoors on high traction track. Tomorrow is race time. Will see. Sorry for the long post.
air8 is offline   Reply With Quote
Old 04-19-2007, 06:40 PM   #3049
trebor's Avatar
8ight Carbon Arm Guards {CF-8}
http://tkocompetitiondev.com/shop/pr...roducts_id=280
trebor is offline   Reply With Quote
Old 04-19-2007, 08:22 PM   #3050
SlobbaTech's Avatar
Maybe try thicker center diff oil, and/or thicker rear swaybar.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 04-19-2007, 08:24 PM   #3051
JWRockman's Avatar
Default Spring Rate Chart provided by Horizon Hobby
Here is the spring rate chart provided to me by Horizon Hobby
Thank you for your recent email. Here is a chart for you:
Spring chart:
Silver .040 wire with 30 degree angle
Gold .040 wire with 25 degree angle
Black .036 wire with 30 degree angle
Green .036 wire with 25 degree angle.
I hope you find this information helpful. If you have any other questions, please reply to this email or call us at 877-504-0233.
Thanks,
Josh Swinford
Product Support Team Member
Horizon Hobby Distributors
4105 Fieldstone Rd.
Champaign, IL 61822
877-504-0233
productsupport@horizonhobby.com
JWRockman is offline   Reply With Quote
Old 04-19-2007, 08:29 PM   #3052
have you guy's read the" post ur hard luck stories" on the onroad electric forum? it's hilarious!!! Make a post to keep it going.
Old 04-19-2007, 08:40 PM   #3053
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
jwrockman- the green and black springs are mixed up. the blacks are softest.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-19-2007, 08:45 PM   #3054
JWRockman's Avatar
Default spring chart
I wonder why Horizon Hobby is misinformed??
Any ideas?
Old 04-19-2007, 09:03 PM   #3055
im giving you the info that Adam Drake has gives many of times. I would take his word over someone who answers phones.
Rob Jensen
Old 04-19-2007, 09:29 PM   #3056
Kcdzim's Avatar
Send a message via AIM to Kcdzim
Any ideas?
quoted from thedrake.net....
Originally Posted by AdamDrake
Originally Posted by Adam Drake
Adam Drake
Member
JellyRacer- The current diff set-up you are running will have very little off power steering, but should have good on-power steering. That set-up won't be good in the bumps. Lighter front diff oil will have more off-power steering and less on- power steering. The center diff does effect steering, but mainly controls the amount of drive or punch the buggy has. Thick diff oil will have more punch. The lighter the rear diff fluid the more steering you will have in the middle of the turn.
Brain Muffin- I usually would shim the diffs with two to three shims on the left (tighter) and one shim on the other side.
CoryD- Yes, I run the stock clutch set-up from the 8ight, but with a 13 tooth clutch bell.
Silver .040 wire with 30 degree angle Hardest
Green .036 wire with 30 degree angle
Black .036 wire with 25 degree angle. Softest
Make sure you scotch bright the inside of the clutch bell if you are running 2 plastic and 2 alum shoes. Also use motor spray to clean the inner clutch bearing. The 13 tooth clutch bell will help with clutch wear, but you may also want try running the following spring / shoe set-up.
2 plastics shoes with 2 black springs.
2 alum. shoes with 2 gold springs.
If the clutch is slipping make sure you stop running the buggy and go to lighter springs before you damage the clutch shoes.
Posted: 2006-10-12 04:54:59
Losi 8ight 2.0 Associated SC10 Associated RC10T Xray T3 2011
Corally RDXΦPhi Vintage Transam
Professor Z Graphics
Kcdzim is offline   Reply With Quote
Old 04-20-2007, 12:49 AM   #3057
drake would know....
Old 04-20-2007, 07:18 AM   #3058
PTP Racing's Avatar
Amainhobbies.com has it listed
Silver 0.040 30 degree
Gold 0.040 25 degree
Black 0.036 30 degree
Green 0.036 25 degree
No offense to the Drake but I take the word of a business over an internet post. Ive made plenty of mistakes when posting.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-20-2007, 09:38 AM   #3059
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
....not this discussion again..... It should be easy to figure out.... put all black in and next use all green.. which has more "snap"
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-20-2007, 10:02 AM   #3060
air8's Avatar
I am using all green springs with four KH alum. shoes. It feels almost like a modified electric motor. Very linear. I did have two gold and two black, but on our short indoor track I was over jumping everything and squirelly off of tight corners. Right now it is good for indoors. Outdoors I will go back to the snappy set up. Our outdoor track now has a FORTY foot single jump. Awesome. First race on it is tomorrow if it doesn't rain.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
